Question about Toshiba 46HM95 46" HDTV
Vertical lines across the screen
I bought a Toshiba 46HM95 about 1.75 years ago. After 1 year my lamp dimmed and then exploded. Toshiba sent me a replacement lamp that was installed 6 months ago. Everything was working fine until this morning when vertical lines appeared evenly spaced across the screen. I called Toshiba and they told me that they dont know what it is and then gave me a number for a local service center. Is there a simple solution to solve this problem or will it require major mechanical repairs?
  • 2 more comments
  • Skydogg Dec 02, 2007
    I wrote everything on the blog then saw the link. Hope to hear from ya.
  • edubaby12 Dec 12, 2007
    I have a toshiba 52" I have had the tv for 3yrs this month, had the lamp replaced 6 weeks ago everything has been great. Last night I turn on the set and in about an 1/2 hr. verical lines appeared top to bottom across 90% of the screen. This moring, the same.
  • medic78 Dec 28, 2007
    I have 72'' toshiba with same vertical line problem. It started happening then stopped and one day the lines stayed permanently. I have called customer support numerous times without any luck. Any help would be greatly appreciated.
  • jscully08 Nov 28, 2008
    i have lines from top to bottom about 3/4 right to left
I now have the same problem. Lines are on the left side of the screen almost have way across the screen, with a thicker line int he middle which is the same length. It started last week and stopped after fiddling with it. Now it comes on fine then about 5 min . in the lines appear. I have had the tv for 1.75 years myself and have had to deal with bulbs popping numerous times (3). Was this the same as yours? Did solutions work? Please do tell.
Posted on Dec 02, 2007
  • 34 Answers
Posible a line acoos check the chasis for any hiar line crack if none resolder the chasis that may work..
Posted on Oct 01, 2007
    Genius:
  • 1,694 Answers
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Posted on Sep 28, 2007
I have a 6 year old 32" Toshiba tube .tv. I have
thir is somecondensers on the tv needs to be changed especialy on pwer supply and vertical circuit it is easy fault but needs technication,,,but first be sure thir is no floresent lamp common with the same supply of the set
Dec 23, 2010 | Toshiba 32A14 TV
Our Samsung Model HLP5063WX/XAA - dark images
I suspect that you may need to replace the ballast for the lamp and the power supply board.
Oct 30, 2009 | Samsung DLP HL-P5663W 56" TV
TV has a line across the screen when I turn it on.
You have a vertical deflection problem ; probably a shorted vertical output IC.
Mar 30, 2009 | Televison & Video
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Vertical lines in my laptop screen
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Samsung 42" HCM4216W Dim Horizontal line across screen
THIS HAS NOTHING TO DO WITH CONVERGENCE or any of the stk integrated circuits.There are few capacitors close to the vertical output ic, they are usually blue or red (could be 1000uf 50volts for e.g.)That where the problem is
Nov 03, 2007 | Samsung HCM4216W 42" Rear Projection...
Toshiba 46HM95 46" HDTV Logo
216 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
