Question about Dell 1600n All-In-One Laser Printer
Non Dell cartridge
I have bought a cartridge from a third party and my printer says non dell cartridge and I can't get it to print. What do I need to do to get the 1600n accept this cartridge?
Posted on Dec 12, 2008
    Problem Solver:
  • 5 Answers
Pleaz chane genuine cartridge
Posted on Sep 13, 2007
SOURCE:
Dell printer 1250c , printer in Error state
The indicators provide information on the status of the printer and help you locate each problem. Following are the Indicator Status Condition and what they signify.
  • Jam Orange on A paper jam occurred.
  • Orange blinks The rear cover is open.
  • Toner Orange on The specified toner cartridge is empty or not installed when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • Orange blinks The specified toner is low when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • All toner indicators blink when the printer is in the non-Dell toner mode (Non-Dell Toner is set to On).
  • Error Orange on A fatal error occurred.
  • Orange blinks An error occurred.
  • Ready/Data Green on The printer is ready to print.
  • Green blinks The printer is processing or printing.
  • Orange on The printer is in the power saver mode.
  • Orange blinks The printer is canceling.
  • Start Green on To continue printing, press the (Start) button.
  • Cancel - To cancel the current job or clear the error, press the (Cancel) button.
For detailed information, please click on the link below for Manuals & Documents for the Dell Printer 1250C. Check Chapter 11 - Page 69 to 77.
http://dell.to/1at80gm
Feb 24, 2017 | Dell Office Equipment & Supplies
My Dad bought new ink cartridges ( black and color) and installed them in the printer and it is not registering that they are installed. What are some things I should check for and how can I fix this????
After installing new ink cartridges in your Dell all-in-one 926 printer, you may receive an error message telling you the print does not recognize the new cartridges. Refilled or third-party cartridges, which Dell does not recommend using with the 926, often trigger the error message. You may also receive this error after you have been using the same ink cartridges for some time. Whether the cartridges are new or not, the error can be caused by a number of sources. Following the steps below should clear up print cartridge problem.
  • 1
    Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
  • 2
    Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
  • 3
    Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
  • 4
    Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
  • If your Dell 926 fails to recognize the print cartridges after following the above instructions,
    take it to a repair shop for servicing.
    Good Luck and Happy Printing
    Jan 26, 2011 | Dell 926 All-In-One InkJet Printer
    I changed the toner drum in my Dell lasaer printer and now all I get is an error message with a flashing toner. How can I get the printer to print? Thanks,
    Did you use a factory new toner cartridge or a refilled/third party cartridge.
    If it is a factory new cartridge, contact Dell and let them know you were issued a defective cartridge.
    If it is refilled or third party, try to get your money back and hope that you have not damaged your printer.
    Then go get a factory new cartridge.
    Don
    Oct 20, 2010 | Dell 1700n Laser Printer
    Dell Laser 5100
    Means the Yellow Toner Cartridge is not communicating with the printer. If you've installed a third party yellow toner cartridge, go to the Dell Printer Configuration Web Tool to set the toner to non-Dell toner. If it is a Dell cartridge, the procedure is to turn the printer off, wait 10 seconds, and turn the printer back on.
    Feb 24, 2010 | Dell 5100cn Laser Printer
    Dell all in one 946 printer
    I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
    Please consider the following:
    If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
    They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
    If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
    Don
    Feb 20, 2010 | Dell 946 All-In-One InkJet Printer
    Dell V305W printer says ink is low and it's not!
    I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
    If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
    They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
    If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
    Don
    Dec 01, 2009 | Dell V305w All-In-One R840635AU InkJet...
    My yellow toner is empty but I would like to print in black and white. How can I do that?
    in the menu options on the printer screen the will be one that says "maintenance" in that menu there will be another that says "non-dell toner" set your printer in the non-dell toner mode. this will deactivate the toner level reading and allow you to print what ever you want.
    Nov 19, 2009 | Dell 5110cn Laser Printer
    Dell J740 won't print black text - the page is blank - have reinstalled it and put in new ink - goes thro motion of printing but only prints any colour parts (its 5 yrs old) PC is dell inspiron (1yr old)...
    Don
    Nov 18, 2009 | Dell J740 InkJet Printer
    I have a 962 that USED TO accept non-Dell cartridges and print. Now the printer will not allow me to print with FULL color and black cartridges. Is there an open source driver?
    Don
    Nov 10, 2009 | Dell 924 All-in-One InkJet Printer
    Dell 720 won't print color, color ink cartridge missing
    check to see if the color cartridge has the plastic tab on the cartridge. Remove and reinsert cartridge.
    Sep 13, 2009 | Dell Inkjet 720 Printer
    Dell 1600n All-In-One Laser Printer Logo
    364 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Ekse
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
