Question about Car Audio & Video
Ist ik for capacitors to be expose on heat inside my room when i am out because all the windows are close? the heat is about 40 to 45 degrees celcious.
IS IT OK FOR POWER CAPITORS TO BE EXPOSE IN HEAT THAT GENERATES INSIDE MY ROOM FOR ABOUT 40 DEGREES CELCIOUS WHEN ALL THE WINDOSW ARE CLOSE BECAUSE IM OUT OF THE HOUSE.?IF MY ROOM IS CLOSE FOR THE WHOLE DAY THE TEMPERATURE INSIDE RISES UP TO 40 DEGREES CELCIOUS AND THE CAPACITORS WHEN YOU TOUCH IT YOU CAN FEEL THAT IT IS SLITHLY HOT BECAUSE OF THE ROOM TEMPERATURE THAT IS 40 TO 45 DEGREES CELCIOUS WHEN THE ROOM IS CLOSE FOR A WHOLE DAY? OLS HELP ME SIR,THANK YOU.....
    Novelist:
  • 90 Answers
Most capacitors are designed to have an effective heat usage range before they start to change capacitance values. They will normally run in an environment of below 32F to 120F without any variation in the capacitence rating of the capacitor. Beyond these points the capacity may start changing.
Posted on Apr 13, 2009
My thermostat is set on 68 degrees and it shows room temperature is 68, but the furnace still kickson, Honeywell said it has a 1 degree difference. so what's the problem then?
Yes there is a one degree tolerance, in fact my heater just kicked on and it is set to 67 and the inside temperature reads 67. It is also a Honeywell.
Dec 28, 2016 | Heating & Cooling
Freezer not working properly, when engineer came out he said that it won't work in the shed because the product needs to be in a room of 16 degree C to function properly
that is strange--consider this
16 degrees c is 60.8 degrees f
45 degrees c is 113F
the technician states that it will only work in a room of 16 degrees yet many houses in dry heat conditions experience a room temperature of 45 degrees c yet still work effectively
it could possibly be that the difference is that in a room , the air can circulate freely but in a shed ( probably closed up then the air cannot circulate
leave a door open or windows or make it so that it is properly ventilated
move the unit away from the wall so that radiated heat from the wall will not affect the unit
Feb 29, 2016 | Candy CSC 1365 WE White 173 l Freestanding...
Remote is inaccurate
did you change the batteries ?
Dec 07, 2013 | Mitsubishi Heating & Cooling
It is 94 degrees out side and inside air 78 i got the troastat set on 72 what does it meen that it want get 72 in the house
depending on the current conditions inside it appears to be wotking fine with the heat load. what I am saying is -is that the air coming out of the unit shuld be about 15-20 degree lower than the temp of the room .. close all unused room s and it will do its job.. Hope this helps let me know Jon
Jul 27, 2011 | Haier Energy Star ESA3183 Air Conditioner
It is hellishly hot outside these days, something close to 40. I bought a 6000 Haier at Best Buy and wanted it to lower room temperature to 25 Celsius. Vain hope: working non-stop day and night at high...
This window unit cant keep up in temps above 100 degrees farenheit its not going to happen. 28 degrees celcius is all your going to get in that heat Im in St. louis MO and its the same way
116 degrees farenheit heat index
Jul 21, 2011 | Haier HWR08XC7 Air Conditioner
The AC doesn´t work when outside temp goes 100 degrees and above
Try using a garden hose to wash down the condensor coil (the coil that is exposed to the outside air).
During the cooler times when it seems to be working, check the temperature difference of the air coming out against the temperature of the air coming in (room temperature air). The temperature should be approximately 16 to 22degF difference. If you are not getting at least 16degF air, you most likely need to have your unit serviced to see if professionial cleaning or a recharge is needed. If you are getting the temperature difference but not getting the amount of cooling you need during hot weather, it could be a capacity problem. You can perform a quick test by using the calculator on this site:
http://www.goodhousekeeping.com/home/air-conditioner-calculator.
I hope you find this information helpful. Good Luck! :-)
Mar 08, 2010 | LG Heat cool Window Air Conditioner
Electric baseboard heater
this is a tough call but with 2000 watts in each room there should be more than enough heat .the rooms should maintain a average temp of 73 to 78 degrees temp without weatherazation and that is of course there is no drafts coming from any windows or near a front or back door that opens and closes alot . Basiclly you have it covered but definatley get the house winterize/insulated real good.I would keep 1 or 2 space heaters on hand just incase the person in house feels there cold just to cover yourself ,usually it the female complaining its cold if its not warm enough but there have been some males that need that temp to be 80 degrees all the time.good luck but im sure it will be ok!!
Sep 29, 2009 | Fahrenheat Electric Convector Baseboard...
How long will my AC work for, if placed inside the room
I assume that we are talking about a "window" unit. No, you cannot just place it in the room. The machine is actually two parts; one part delivers the cool air to you, the other part ejects the heat out of your house. If you just had the whole unit inside, the room wuold actually get warmer, not cooler. The reason for this is that the compressor and motor generate heat also. The "heat of compression" generated has to be ejected from the room in order for the air conditioner to work. Put it in the window.
Best regards, --W/D--
Aug 10, 2009 | Heating & Cooling
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
