My ECS P4S5A REV. 1.5 motherboard will not turn on. Power LED flashes on then off, after I press the power button. I changed the power supply, still same problem. I need a copy of the repair schematics. Thank you.
    Sergeant:
  • 449 Answers
Usually repair schematics are not provided by the manufecturers. Try requesting the manufecturer from Contact Us section of the manufecturer's website. (ehteshamhusain@gmail.com)
Posted on Jul 19, 2009
2 Suggested Answers
SmartAviator
  • 449 Answers
SOURCE: I need schematics for ECS P4S5A REV. 1.5
Usually Schematics for motherboards are not provided to download. Try sending request in the Contact Us section of manufecturer's website. (ehteshamhusain@gmail.com)
Boot up
did you put the 4pin power in the board and 24 pin in then check the cpu fan in the right place make sure that all plugs are in the right place as well put in video card
Jun 10, 2013 | EliteGroup ECS A740GM-M Motherboard -...
Switch Wiring for P4S5A/DX+
go here download manual http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=39&MenuID=24&LanID=0
Apr 19, 2013 | EliteGroup P4S5A/DX Motherboard
ECS RC410L/800-M (V2.0) motherboard won't boot up. lites the fans and system lights, but no go. replaced video, CPU with 800 fsb from 533 existing and cleared cmos, still nothing. 533 processor creates...
A bad Power Supply with a weak voltage rail, will produce the symptoms you've just described.
1) IF all of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use from 51 to 125 Watts.
Just depends on what Processor it is.
You press the Power On button. The first chipset (Integrated Circuit) to receive power is the BIOS chipset.
BIOS detects what devices are installed, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
(Windows XP is one example of an O/S)
Have you tested the main voltages of the Power Supply?
A) The 3.3 Volt power rail
B) The 5 Volt power rail
C) The 12 Volt power rail
(12 volt rail must be 11 volts or more. Less = new Power Supply)
Post back in a Comment.
Regards,
joecoolvette
Oct 28, 2011 | EliteGroup RC410L/800-M (V2.0)...
Apr 14, 2009 | Computers & Internet
Motherboard ECS P4S5A Capacitor value
you can usually get caps at radioshack for less than $5.00 but soldering them in in out takes talent time and a steady hand.
Oct 22, 2008 | Computers & Internet
ECS P4M800-M V 2.0 wont POST
may u have a grouded DVD drive, did u try another DVD or CD drive? may be it will help.....
Aug 14, 2008 | EliteGroup ECS P4M800-M Socket...
EliteGroup P4S5A - Motherboard - ATX - SiS645 - Socket 478 - UDMA100
try to do the ff:
before you replace your Mainboard.
1.did you try to set your bios to default settings ,then save and restart.
2. try to clean your memory and memory slots ,
3.try to remove your other hardware except the video card and restart your unit.
4.try to reformat your hardisk.
Mar 30, 2008 | EliteGroup P4S5A/DX Motherboard
No power supply activity
check all wiring connections going to the board, also check that the bios jumper is not set to clear bios.
Jan 14, 2008 | EliteGroup P4S5A/DX Motherboard
Power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Jan 02, 2008 | EliteGroup L7VMM2 Motherboard
My notebook ECS G733 do not wake up ( do not turn ON)
if you know how to dismantle your laptop, then look for the 1500uF 6.3V capacitor that blown..
it looks like this
4bfe304.jpg then you need to replace it.
Sep 10, 2007 | EliteGroup ECS G733 Notebook
Computers & Internet Logo
1,073 people viewed this question
David Payne
David Payne
