Question about IBM E74 17" CRT Monitor
Attention out of range is displayed on ibm 2 74 monitor
I changed my display setting and i am geting message as monitor out of range. i pressed tab key during boot and got option as stand alone mode. i booted system in thaqt mode and no display. how can i fix thisn problem.
  • 271 Answers
To resolve this behavior, either change the refresh rate, or change the video adapter settings.
To change the refresh rate:
  1. Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
  2. Right-click the desktop, click Properties, and then click Settings.
  3. Click Advanced, click Adapter, and then click Adapter Default from the Refresh Rate list.
  4. Click OK, click OK again, and then click Yes to restart the computer in Normal mode.
You can set the colors and screen area to your preferences under Display Properties.
To change the video adapter settings:
  3. Click Advanced, click Adapter, and then click Change.
  4. Click Next, and then click Display a list of all the drivers in a specific location, so you can select the driver you want.
  5. Click Next, click Show all hardware, and then click Standard display types under Manufacturers.
  6. Click Standard Display Adapter (VGA), and then click Next.
  7. Click Yes, click Next, click Finish, and then click Yes to restart the computer.
  8. After the computer starts, right-click the desktop, click Properties, and then click Settings.
  9. Click 256 colors, click Apply, and then restart the computer.
  10. After the computer starts, click Start, point to Settings, click Control Panel, and then double-click System.
  11. Click Device Manager, click View devices by type, and then click Display adapters.
  12. Click Standard Display Adapter (VGA), click Remove, and then click OK.
  13. Install all updated monitor drivers.
Posted on Apr 13, 2009
SOURCE:
Just installed a ZR24W monitor, screen blacks out after 10 minutes with a message saying 'Input signal out of range, change settings to 1920x1200-60hz'. The monitor was set to this resolution &...
You will need to adjust the refresh rate of your system.
1) Right click on the desktop and go to properties.
2) When the Display Properties window opens go to the Settings tab.
3) The go Advanced.
4) Once ni the advanced screen go to the Monitor tab.
5) Under screen refresh rate select around 60Hertz. (Make sure the box next to "Hide modes that this monitor cannot display" is ticked.
6) The click OK. And OK again to exit Display Properties.
May 26, 2011 | HP Smart Buy ZR24W LCD Monitor
I gives me the message that it is out of range. What do I do?
hello
it is because the vga you have and monitor you have is not compatible at the first use, you have to press F7 while booting up. or if did not work you have to use another monitor to change your resolution into 800X600 and plug it again into the monitor which is out of range to be able to work.
just leave a comments
thank you
Mar 14, 2011 | Sceptre X5g-Komodo VII 15'' LCD Monitor
How can I fix an "Out of Range" display?
It means that your display card settings are too high for your monitor. Boot your system into safe mode (press F9 as it boots up) and set the display settings lower. Right mouse button click on an empty space on your desktop and go to properties. Then settings->advanced->Monitor and you should be able to adjust the vertical frequency down to 60hz or 72hz. If you get the out of range message on boot up then you will need to try out a different screen on your system, boot into Windows, change the settings and then plug in your original monitor.
Feb 09, 2011 | Westinghouse L1975NW Monitor
ATTENTION OUT OF RANGE 74.7 kHz v:59.8 KHz
This means either your Refresh Rate or the resolution has been set (usually in the display settings of the operating system) beyond the monitors display capability. On a windows OS, go to START == CONTROL PANEL == DISPLAY == SETTINGS (for XP) or R click on the desktop and select SCREEN RESOLUTION for Windows 7 & VIsta. Use the slider to reduce the screen resolution to one that both looks good and fits within your monitors capability.
Hope This Helps FixYa! Please leave us some feedback if you found this information helpful.
Apr 08, 2010 | IBM E74 17" CRT Monitor
Out of range message on my monitor.
Boot your computer to safe mode and change the display settings to either 800x600 or 1024x768 then save and reboot once it comes back up you can change the display setting to what you prefer.
To get into safe mode press F8 on you keyboard every second while it is first booting up.
Mar 08, 2010 | Computers & Internet
Attention out of range monitor H:95.1KHZ V:59.8HZ
You can solve this by choosing "Last known good configuration that worked" instead of going into safe mode. This will take your old display settings that worked.
Jan 09, 2010 | Computers & Internet
Monitor displaying out of range message
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Source:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
http://support.microsoft.com/kb/311403
Kindly rate me if i was helpful.
Regards,
Waqar
Aug 25, 2009 | Hansol Computers & Internet
Out of Range message displays when PC boots
The settings that you have for you tower needs to be changed if you have a old monitor connect that to the tower then right click on your screen go to settings and set it real low once this is done connect the new monitor up and set where you would like it,
The out of range is just letting you know that the settings thats set the monitor can see
Mar 12, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Showing message out of range
Your monitor settings within windows are set too high for the monitor to display... When computer first boots.. be ready and press the F8 key...
Enter safe mode.. Reset the display properties in control panel to 800 by 600 for a start. Setting the resolution too high past the monitors ability will give you that message.. Most monitors are able to display 1024 by 768 just fine.. Out of range.. means the display settings within windows are out of the monitors range of ability to display the screen resolution you have set... Good luck!!
Feb 18, 2009 | Dell Dimension 8200 PC Desktop
IBM E74 17" CRT Monitor Logo
890 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
