Looking for manual or instructions for disassembly/reassembly so that I can replace the damaged power jack.
Trying to find a service manual or at least instructions on disassembly/reassembly of a Balance Digital laptop model CN6555/557S.
  • Computers & ... Master
  • 5,660 Answers
I repair a lot of laptops. I have found through the years, that they all seem to follow a basic disassembly pattern. Although access to the cooling tube/heatsink/fan combo, and processor, for some of the laptops, is through the bottom, it is just for those hardware components.
To disassemble these type of laptops, you still have to come down from the top.
One laptop I have so far not had the fortune of working on, is a Balance Digital Technology laptop.
I 'googled' a few models just now, and they look to be the same as many HP, or Compaq, or IBM, or Toshiba, or on and on, models I have worked on.
The first thing you need to do, is remove the AC adapter, (if plugged in), and the battery.
Then turn the laptop over, and remove the harddrive, the memory compartment cover, and memory modules, (ram sticks), and any other removable compartment cover, or removable device.
I use a clean egg carton, and label each egg holder as to where what area, the screws came from, and put the various screws in these egg holders. There may be as many as ten or more, different types of screws, and could be up to 50 screws or more.
(Doesn't sound very 'Techie', huh? I work on a lot of laptops, and can just throw these egg cartons away when done)
I also suggest you use a digital camera, or video camera, and good lighting, as you go along. (If available) Helps to reference later as to what went where, and in what order. I also suggest making notes and drawings. Make them legible enough so that you will understand them later.
Turn the laptop over to it's normal position. There is a plastic strip above the keyboard. It's under the LCD screen. This strip may have speakers in it, and/or LED lights.
This plastic strip has tabs going around the edge of it. These tabs keep it snapped in place. I take a flat tip jewelers screwdriver, and ease it in a little bit, where the plastic strip meets the body of the laptop. Just get it under the edge, and carefully pry up. If you can't get it in, move over. You might be right at where one of those tabs are.
You may only be able to ease it up just a little bit, and have to use another small flat instrument to hold this raised part up. Then take your flat tip, and go to another place close to it. Try to pry that part of the edge up.
When the strip first pops up, it comes up with a "Crack' sound. You'll think you broke it, but you could run a truck over this plastic part!
Each time you get the strip up, and a tab comes up, 'Crack'. Kind of unsettles your nerves until you get used to it!
Work around the edge of this strip. Keep popping it up as you go around. Eventually it will come up and off. Look for wires. There are small plastic White connectors. You can ease these little connectors apart with your fingernails. The connectors are different sizes, and have different pins. There's no mixing them up when it's time to reassemble.
The hard part is over now. You should see a screw, or screws to remove the keyboard. It comes up at a 45 degree angle, and is removed at this angle. NOT straight up! After you get it up a little, BE careful! There is a tiny wire harness that the connectors need to be taken apart.
Now you should see a metal shield. This has screws. After this, you remove all the screws you see, and remove all the case screws from the bottom side. Look for 'hidden' screws in the memory compartment area, and the other compartments.
The LCD screen hinges will have plastic covers on them. There may be ascrew that holds each cover on. Most of the time they pop off, like the flat plastic strip did. There will be screws on the front side ofr the LCD screen hinges, and screws on the back side. They may have rubber covers over the screws. They are usally held on with a type of rubber cement. You just take your flat tip, and ease them off.
Posted on Apr 13, 2009
How to replace cv boots on atv
  1. First jack up vehicle.
  2. remove tire/rim
  3. remove cotter pin and castle nut from the end of the axle.
  4. disassemble spindle from upper/lower ball joints'
  5. separate spindle from axle by pulling spindle away from the vehicle.
  6. with two hands grasp axle and pull firmly to remove axle assembly from differential.
  7. remove torn cv boot, clean all old grease from cv joint.
  8. apply new grease and install new boot.
  9. secure clips on cv boot.
  10. Reassembly is reverse of disassembly.
  11. Consider purchasing the service manual for your make /model of atv from amazon. This manual will have step by step instructions and pictures for any repair or maintenance that you will need to perform.
May 15, 2016 | ATVs
How to replace faulty power jack
Essentially you will need to disassemble the laptop almost down to the main board, desolder the bad jack and replace it then reassemble. I can't provide a step by step as there are very many steps. But will suggest that this will be an involved repair and if you aren't comfortable disassembling the laptop, have a repairman handle it. If you choose to forge ahead, take it slow and take lots of pictures as they can be helpful when it comes to reassembly.
Dec 01, 2014 | Gateway M6307 Notebook
How to remove the bottom of a laptop to tighten the power supply outlet
You will probably have to strip it right down to get the motherboard out.
The socket might need resoldering. if you are not technically minded you would be better off taking it to a repair shop. You can do more damage than good if you are not careful. Youtube have a lot of videos about disassembling laptops / pc's if you want to do it yourself.
Feb 12, 2012 | HP Computers & Internet
How do i replace the battery on gateway cx200x
remove main battery by sliding battery lock to unlocked position, then slide battery release latch and slide battery out. If you are looking for how to disassemble the notebook to change the bios/cmos battery, you can get the service manual at mpcdriver.com with complete disassembly, reassembly instructions and pictures
Nov 09, 2009 | Gateway CX200X Tablet PC
Nx6310 wont stay on
HP is notorious for this problem. The problem is that the power jack that is connected to the motherboard has come loose. This is an easy fix is you are comfortable taking apart your notebook and are able to solder the jack back to the motherboard. I have 2 HPs and my friend has 2 and we have done this with ours as well as others. This is the link to the HP website that has your manual for disassembly .http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=1839143 When you get to the page, download the Maintenance and Service Guide. (It is all the way at the bottom!) You will need Adobe Acroabt to read it. PRINT the instructions. They will do you no good if they are on the laptop that you are trying to disassemble!
While it may seem daunting, it is really not hard to do. Just be careful to follow all of the disassembly and reassembly instructions and you will have no problems. I promise!
Please remember to rate my solution! Thanks
Feb 02, 2009 | HP Compaq nx6310 Notebook
Gateway mt6707
This link shows you step by step with PICTURES and awesome instructions how to completely disassemble and repair keyboard, motherboard, dc power jack and more.
There are links within the instructions for other repairs.
AWESOME site and AWESOME instructions!!!!
http://www.insidemylaptop.com/take-apart-gateway-nx570x-laptop-disassembly-guide/
May 21, 2008 | Gateway MT6707 Notebook PC
Replacing the Power Jack on my labtop
Sepi, Here is the service manual for your laptop: http://h10032.www1.hp.com/ctg/Manual/c00636251.pdf You can probably get your replacement part from Ebay, I saw several listed. The real issue is probably going to be if you have the skills, tools and time to successfully disassemble, repair and reassemble your laptop. Expect to spend about 1 or 2 hours during the process. Be sure to protect the system board and other parts from static charges and slips of the screwdriver. Good luck and please don?t forget to rate this post.
Feb 22, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
220 people viewed this question
David Payne
David Payne
