Question about LG VOYAGER VX10000 Cellular Phone
My LG Voyager has been flashed to Cricket, but the MP3 player is saying , I have no application in my music and music area .
  • 4 Answers
All you have to do is have your voyager reflashed back to the v05 firmware and then have them or you to flash it back 1 firmware at a time v07, v09, and v11 and this time donot mess with brew settings and this will fix the problem. by the way important note: YOU WILL NEED TO CHANGE ALL BREW SETTINGS BACK TO VERIZONS' BREW SETTINGS FIRST OR THIS WILL NOT WORK!! i have a voyager and i made the same mistake but i fixed it if u need help email me at badboy038128@yahoo.com
Posted on Jul 12, 2009
Can't get the usb port to work
If you expect the music files on the flash drive you plugged into the USB port to start playing by themselves, good luck with that. You have to open a media player application (say Windows Media Player), open the removable disk that is your flash drive from within the application, select an .MP3 file from the flash drive and play it.
Feb 03, 2015 | Audio Players & Recorders
Whenever I download something it says format err
perhaps you do not have the audio player for the music.ext you are downloading. Look at the file name. It should say something like music.mp3 or some other 3 letter extension. Make sure you have the proper application to run it.
Mar 30, 2014 | Polaroid PMP120-4 4GB USB 2.0 MP3 Digital...
Have a lg vx1000s that was verizon flashed to cricket. It has been hooked up through cricket previously, however i spent 12 hours trying to hook it up yesterday, finally got far enough that they took my cc...
Try *22804 it seems to work for verizon phones that are failing on *288 more often than not.
However if your phone was fully flashed you may need to have it reprogrammed since these phones need to be programmed to your number, without this most likely you will only get talk and text.
Dec 26, 2010 | LG VOYAGER VX10000 Cellular Phone
I recently put new music on my player and it can't get past the "finalizing update" screen. i can't listen to music, any help
the mp3 player has corrupted due to an application or music you transferred into the mp3 player.that's why the screen displays static finalizing update.
To restore the mp3 back to normal, you need to flash the mp3 player it will restore back the memory that was affected.
Take care.
Apr 20, 2010 | SanDisk Sansa m240 MP3 Player
Flashe sprint lg to cricket
Once the device is flashed not all services are guaranteed to work. You will want to call cricket technical support to see if they have insight on why this may not be working and have them check your acccount.
Sep 20, 2009 | LG Sprint Fusic LX550 Cellular Phone
How to put music on lg voyagr
Use uitunes if you have it and drag sonds you want to a new folder on the desktop. Then used the MIcro SD Memory card to load songs and then put the card back in your phone to add to your "MY Music" section. When you save songs to your cartd save in the "MY Music" folder. not "PIX" or FLIX" ort anything else!
Apr 18, 2009 | LG VOYAGER VX10000 Cellular Phone
LG Voyager will not play music
im having the same problem at the moment :/
it says that it isnt able to play any of the songs that are on my music card and i dont understand i formated it made sure that there were no viruses on it they are all in mp3 format and iunno.. its not working D8
please help..
Apr 02, 2009 | LG VOYAGER VX10000 Cellular Phone
LG Voyager, Music won't play.
Play music files - LG enV: At the main screen, press OK to select Menu. Select Get It Now, then press OK. Select Music & Tones, then press OK. Select My Music, then press OK. Select Songs, then press OK. Select the desired song, then press OK to select Play.
Aug 13, 2017 | LG VOYAGER VX10000 Cellular Phone
Verizons LG Voyager fully flashed to cricket but internet not wor
If a dealer is knowedgeable enough to claim that an LG Voyager is fully flashed, then he should know that he must activate it on its intended phone #, at the time it is flashed. Otherwise, the web will not work. This is known and common problem with the LG Voyager, and if you are able to fully flash this phone, you're aware of this problem and know how to deal with it.
Sound like this dealer did not do the flashing themselves, and were not properly trained on how to activate and refresh wap settings on a Voyager at the time of sale.
The LG Voyager must already be activated on its intended phone #, at the time the phone is flashed. This is unique to the Voyager. None of the other verizon LG phones have this requirement.
The reason is because the simple act of dialing *228, or manually programming the phone#, erases the WAP settings on this particular LG phone. Specifically, it is the WAP Gateway that is erased, and this can only be fixed by somebody who knows how to flash this phone.
This is the only verizon LG phone that will automatically erase its WAP Gateway when the phone # is programmed into it, by dialing *228.
If your Voyager is working, DO NOT DIAL *228, EVER, Keep in mind, if you call cricket for any type of billing/tech support on your account, they will tell you that you must dial *228. DO NOT DIAL *228, if you have an LG Voyager. *228 is similar to restarting your computer. It's good advice, but is usually not required.
If you are going to pay somebody to fully-flash your phone, that person should offer, even require, that they transfer service to your phone for you, at the time it is flashed. The only way to know for sure your phone was properly flashed, is to test out the web and picture messaging features, when your phone is done being flashed. I *always* test out the web browser, and incoming/outgoing picture messaging, before I consider a customer's phone to be ready.
There's is no 24hr waiting period for web/picture messaging. Basically, if it works for voice/text, there is nothing to keep web/pix from working immediately. A dealer or experiened flasher has the tools/resources to make sure the customer's account has the proper features for web/pix to work.
My last piece of advice, is that you do not have to be paying for web, in order to use the web browser on a fully-flashed cricket phone. That is right, cricket offers free web-portal access to Cricket's homepage, which doesn't include much, but does give me a page or two to load, to make sure the phone is working correctly. If you have picture messaging, you should be able to visit this page, even if you don't have web on your account: http://wap.cricket.motricity.com, and http://search.wap.mycricket.com.
There is an easy way to test if your Voyager has simply erased its wap gateway. If you can send and receive picture messages, but just cannot use the browser, then your phone is flashed properly, but needs to have its wap gateway settings refreshed. You can verify this by visiting http://www.accuweather.com, because if picture messaging works, accuweather.com will load in the browser as well. This is because accuweather.com is unique, it's the *only* website that will work on a cricket phone, without going through Cricket's wap gateway.
Well, hope this help and is not too much information. I will say, though, everything I've written is 100% accurate. I have been doing "full flashes" on Cricket phones for almost 3 years, before most people even knew you could do basic flashes. The best resource on the internet for learning about the capabilities of flashed Cricket phones is at howardforums.com, in the Cricket subforum, located here: http://www.howardforums.com/forumdisplay.php?f=336
Jay
Denver, CO
aka beezlewaxin
PS - I cannot wait for the day when my answer is proven wrong, which can only happen when somebody figures out how to flash the Voyager so that *228 is safe, and no longer erases the wap gateway. Tougher problems have been solved, maybe someday this one will be solved too. Until that happens, DO NOT DIAL *228 IF YOUR VOYAGER IS WORKING!!! can't say that enough....
Mar 28, 2009 | LG VOYAGER VX10000 Cellular Phone
LG VOYAGER VX10000 Cellular Phone Logo
761 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
