Question about LG Vu CU920 Cellular Phone
Bluetooth passcode i try to use my bluetooth to send pics to friends or what not. however, i find their device i try to send but then it asks for a passcode... how do i get the number to that passcode? & if it is there passcode i need & they give me the correct passcode, why won't it go through??? help plz!
  • 700 Answers
Usually we use one 1 as a passcode. It is should be set from your cellphone then if the receiving unit ask for it enter 1 as passcode. But if security is also priority enter more digit to it.
Posted on Apr 13, 2009
How do you pair a jawbone to a samsung t259 phone?
To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Jun 15, 2011 | Cell Phones
Cant pair device without passcode
Hi, to set up Bluetooth on your phone
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
Hope that helped...
Thanks for using fixya...
Feb 07, 2011 | Cell Phones
Cant figure out the bluetooth code
Look on the back of your device for the Bluetooth passcode for the device. Typically the pairing code for headsets is printed on a sticker that is then placed on the underside of the accessory.
Go into the Settings menu for your computer to find its Bluetooth passcode. Some laptops will randomly generate a new Bluetooth passcode for you each time you want to pair them with a new device. In that case the menu setting you're looking for is something like "Generate new pairing code."
Look in the instruction book for your Bluetooth accessory if you cannot find the passcode attached to the device or in its menu. Many manufacturers will print the passcode for devices in their instruction book. If you still can't find the passcode, try using all zeros
Jan 10, 2011 | Polaroid PoGo Digital Photo Printer
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
application.
Hope it helps .
Fill free to pass your comment.
Jan 08, 2011 | Sony Ericsson W508i Cell Phone
How to send using bluetooth on blackberry 8520 phone
If you wnat send files or pictures using bluetooth, you need to on both the devices. Then it will ask for passcode. Enter the passcode as 0000 and then you can share any files.
Nov 10, 2010 | Cell Phones
Hi i just bought a lg gw300 and i can't set up my bluetooth i don't know how to set up the "passcode".
Your "Passcode" is setup when you "Pair" with another Bluetooth appliance.
e.g If you want to connect to your friends phone via bluetooth to send a picture you would send via bluetooth and search for bluetooth device. When you select the one you wish to connect to it will attempt to "Pair" with it. At this point a "Passcode" maybe asked for if the bluetooth device you are pairing with has one set. If it does then you need to ask the person who owns the device for the "Passcode" before your picture can be sent/recieved.
Normally if you wish to set a passcode for your device it will either be in your bluetooth settings. Possibly even in "Security" in the bluetooth settings or it may just be in your "Security" settings.
Jul 10, 2010 | LG GW300 Cell Phone
WHEN I want to pair with a using bluetooth device it asks me for a passcode for that device I have no idea what that code is. Nor Do I know what the bluetooth pass code is for my phone an LG Ku990i. Where...
OH IT NOTHING ! PASS CODE IS TO ADD YOUR DEVICE TO ANY OTHER FRIENDS MOBILE,
STEP 1:SWITH ON BLUETOOTH
STEP 2:TRY TO SEND SOMETHING
STEP 3:WHEN ASKED PASS CODE TYPE ANY NUMBER SAY 00
STEP 4:ON FRIENDS MOBILE IT WILL ASK SAME QUESTION HE MUST TYPE THE SAME NUMBER 00.
THATS ALL
YOU CAN SHARE ANY STUFF
Mar 18, 2010 | LG KU990 Viewty
Bluetooth pairing
ur divice has a special type of bluetooth facility .Because of this u will not connect to some other devices.
May 31, 2009 | LG RUMOR Cellular Phone
Kindly help me!!
What bluetooth software are you using on your computer?
if you are using Bluesoleil,then:-
1)start your software
2)In your phone,go to the image you want to send,and then from options,select send via bluetooth
3)your phone will search for bluetooth devices
4)when it shows your computer,select it.your computer will ask you to allow it,click yes.
5)your phone and PC,boyh will ask for passcode,enter anything,but you should enter same code on both of them
6)your phone will send the pics.
7)open "my documents/bluetooth/inbox/" here u will find your pics.
if you have any problem you can ask me.
Oct 30, 2008 | Motorola Mobility L6 Cellular Phone
Don't know the pin to set up my bluetooth
Most Motorola bluetooths have a default passcode of 0000 and cannot be changed.
Mar 14, 2008 | Motorola Mobility RAZR V3
LG Vu CU920 Cellular Phone Logo
557 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
