Question about Pioneer Audio Players & Recorders
Stereo Receiver producing static
Hello, I have a Pioneer Elite VSX-35TX Receiver that is producing static being heard through the speakers. It used to just occur when playing the stereo after it has been playing awhile, but, recently starting happening when playing CD's. The static starts out gradually, but, eventually overtakes the signal and all you hear is static. I thought it might be caused by a multi-room amp connected to the receiver or the subwoofer, but, have disconnected them and it still produces the problem. Thanks for your help!
petraman7
  • 1175 Answers
SOURCE: Pioneer Audio/video Multi-channel receiver Mod#VSX-D710S
Have you tried a 2nd source like the CD input or AUX input?
Have you tried the headphones..same static?
If nothing works then the output amp is broken. There could be internal fuses but only open a stereo when the power is DISCONNECTED. Then check for fuses
Posted on Feb 02, 2008
SOURCE: Pioneer SX1980 Stereo Receiver/Amplifier. It
Hello there;
This might be painfully obvious but to be on the safe side check to see if the jumper pins are in the 'Main Out / Pre-In' jacks. If there is no jumper pins you found your problem. Second option, after turning on unit in a QUIET environment with the volume at the lowest setting do you hear a click coming from the inside? If yes, this is good. If no, you have problems.
give the guys at Innovative audio a call. They are the best place for vintage audio on the planet.
www.iavscanada.com
Posted on Jun 19, 2008
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Posted on Jun 24, 2008
proton77
  • 1183 Answers
SOURCE: broken connector in subwoofer connection on receiver
As per the user manual , the receiver has only one sub-woofer connector. The other alternative is to use the digital audio output for the speakers . That would mean either you have to change the speakers or get a conversion box that would connect your analog speakers to the digital output.
The other thing that can be done is to replace the sub-woofer connector. The same can be done by a radio repair guy or you can take it an authorised pioneer repair centre.
Thanks
proton
source:http://hometheater.about.com/od/avreceiversreviews/gr/piovsx91txhs.htm
Posted on Jul 27, 2008
  • 121 Answers
SOURCE: Surround sound system is not producing sound through the subwoofe
Several things could cause this, to make sure the sub woofer is working at all disconnect the cable from the back of the receiver. You should hear some sort of output from the subwoofer when you handle the plug. IF so replace the plud and go into your settings menu (press the A and B button at the same time) and go through the speaker set up. It may be that the receiver has not retained the memory that there is a sub woofer connected.
I hope this helps.
Posted on Feb 27, 2009
Where can i find diagram for bad soldering for pioneer elite VSX-27TX stereo receiver?
You really should be an expert to do repairs on these recivers but if that is the case, you can get the maintenance manual here:
http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-24_26_27_29_D908S_RRV2133.pdf
Jan 02, 2016 | Pioneer Audio Players & Recorders
No sound out of the pioneer vsx-1121-k
Try removing all the speaker and the HDMI connections; then use a headphone to listen to music from the tuner or a CD in stereo mode. Better in direct mode. If you hear your music correctly the receiver could be working correctly. If no music is heard, you may need to have it repaired professionally.
If you can hear music, connect the main FL & FR speakers and verify you can hear music that way, without the headphone connected.
If you can hear music that way, connect the center and rears. Try a mode that uses all channels to verify all sound channels are working.
Then, and only then start adding your HDMI connections.
Good luck
Jan 19, 2015 | Pioneer Vsx-1121-k 7.1 Home Theater...
My pioneer av receiver vsx1020 produces same sound in front and back speakers
Try changing surround modes. You might be in 5 channel stereo mode.
Mar 14, 2013 | Audio Players & Recorders
My power went out while watching TV. Now there is no sound when I turn my receiver to TV/SAT. If I put the receiver on CD there is sound but no picture. The receiver works fine if I go to DVD; there is...
It would seem the TV/SAT source is where the problem lies. No picture with CD? Really?
How about bypassing the receiver to prove what is failing?
Apr 21, 2011 | Pioneer VSX-35TX Receiver
Pioneer VSX-01 TXH receiver turns off
Sounds like the speaker circuit is overloading or the receiver is overheating.
Check to make sure all speakers are in phase. Pos to Pos. Neg to Neg.
Make sure receiver has plenty of cooling room.
Hope this helps.
Apr 16, 2010 | Pioneer EliteĀ® VSX-01TXH 7.1 Channels...
Pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Sep 08, 2009 | Pioneer VSX-818V-K Receiver
I have bad static from my Pioneer vsx 49 Elite
sorry no easy solution as it sounds like the output transistors blew out or the emmitter resistors. you will need a service manual and an multimeter to measure the resistors on or around the audio output transistors they are a low value resistor usually around 1 to 2 watts in size. Do not replace any bad , burnt or discolloered resistors around the audio output transistors as if tou do you might just cause more damage to the output transistorsor audio output stage including the audio driver stage of the amp!!!!!!
Larry Dillon
Aug 27, 2009 | Audio Players & Recorders
Sub woofer
The subwoofer is totally independent from your Pioneer VSX-D412. You can check if it works like you did with a finger on the hot point of the RCA cable (not very good test, as you will hear noise and can't say if that means it works OK) or better connect a known receiver to the speaker connections in the sub and test to see if it’s working properly.
Regarding the receiver, you may not have enabled the VSX to output to the sub. Read the manual on how to check for that. Only Dolby Digital 5.1 signals will allow the sub out, in a receiver of this level. It normally will not let you use the sub in stereo mode. Some more complex units will allow you that, but I believe not this model.
Good luck
Nov 01, 2008 | Pioneer VSX-D412 Receiver
I have a Pioneer VSX-35TX receiver when connected to the subwoofer there is no sound questions on what I am doing wrong.
Set front speakers for small and make sure sub is turned on in setup mode. If Front speakers are sent to large I believe the only time sub will work is with Dolby Digital Lfe signals. If sub is turned off of course it will never work.
Feb 10, 2008 | Audio Players & Recorders
Feb 10, 2008 | Pioneer VSX-505S Receiver
110 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
