Question about Toshiba Satellite A85-S107 Notebook
My dog peed on the screen/keyboard of my Toshiba Satellite laptop. Now we can't turn it on. Is there any hope of rescuing this machine?
  • Fahr Quad May 11, 2010
    I have to wonder about the behavior of your dog. Have you been spending a good bit of time with the computer and not paying any attention to him? This might be why he chose to pee on the computer in the first place. If you don't address the cause of this behavior issue, he will do it again.
    Sniper:
  • 66 Answers
There are a couple of things that probably got wet.
First of all, if it is still wet, you need to get it upside down, and get it open to dry it out, use alcohol to clean off the stained areas.
If you remove the screws on the back, and get the power strip with the lights on the top of the keyboard off. It pops off very carefully, but you need to unscrew the retainer screws poss in the battery compartment, or just on the bottom.
Also, once that strip is off, you should be able to unscrew a couple screws to get the keyboard off. There might be a screw or two on the bottom again, holding the keyboard down.
My guess is the keyboard is hosed, literally. I just had a customer who has a wine spill, and after clean up, everything but the keyboard worked.
Make sure you clean out the power area, up by the power switch, speakers, and whatever else is up there.
Worst case, you might need to take it to a repair shop to get the whole body cleaned out down into the motherboard.
Lastly, you can carefully remove the monitor faceplate with the screws hidden by rubber buttons, and then look at the electronics on the bottom and see if they are stained and wet. Your inverter could have gotten wet. That is the slim little metal/covered device at the bottom of the screen.
Get it dried out, and cleaned with alcohol. Many times the keyboard has to be replaced, but it still should start up if the rest of the computer is working ok. It depends, some models will not start up with a keyboard that is bad.
Posted on Apr 13, 2009
  • Toshiba Master
  • 32,281 Answers
Not much, if you are lucky the hard disk may be OK and you can use it as an external hard drive if you insert it into an USB hard disk adapter case.
My keyboard wont work on my laptop com what causes this to happen and can it be fixed
I assume this is a seperate keyboard. If it's USB, it should fire right up. If its the old PS2 (round) connector you can get a ps2 to usb converter for about 5 dollars. Did you try this keyboard on another machine? If it won't work on any other machine, then the keyboard is defective. Could of had a spilled beverage on it, or cat peed on it (lol ... I have a Logitech G11 gaming lit up 80$ keyboard and the outside cat snuck in and peed on it, then the lady cats peed on it too to cover smell so I am being serious), or it may be wore out, been beaten on when mad, thrown at room mate or just defective from the box. So to sum it up, try the keyboard on a couple other machines (friends or family if you only have one) and if it refuses to work on those, just replace it. You can get a cheap one for 10-20$.
May 29, 2013 | HP Hewlett Packard 2000-369Wm Notebook Pc...
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
How do i turn on the keyboard backlight on my toshiba satellite p200-1fc laptop?
Hi registrat342,Look on your keyboard & there should be 2 pictures that look like a sun on your function keys and 1 that is next to those but it has eyelashes and a box under it. Every keyboard might differ-but hopefully you get my point-as in 3 total 1st=dimmer, 2nd=brighter & 3rd would be the backlight. With mine-all I do is click it. Yours might be a little different. Hope that helps. Sherry
Apr 11, 2012 | Toshiba Satellite Computers & Internet
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
Cant get my toshiba L675 to do print screen no mater what i try
- reinstall your keyboard driver
- go to device manager and uninstall the keyboard driver
- restart the system (system will install the keyboard driver automatically
hope this resolves your issue. cheers!
May 22, 2011 | Toshiba Satellite P105-S6197 Laptop
How do I activate the back lighting of a Satellite E105-S1602 laptop?
Go to: >Start >Toshiba >Utilities >HWSetup >Illumination >then under "Keyboard Backlight," click the radio button "FN" then check the box "On." After you reboot, you'll be able to turn the keyboard on and off by using the "FN" + "Z" keys.
Mar 28, 2011 | Toshiba Computers & Internet
Toshiba satellite - Letter "N"
First check to see if NumLock is turned on. This is usually indicated by a LED somewhere either above the keyboard or possibly at the front of the machine. If it is currently on, you will want to toggle it to OFF in order to type in your password. This is usually done by pressing the blue FN key located at the lower left corner of your keyboard, along with one of the function keys at the top of the screen. I believe on Toshiba laptops, this should be FN + F11, but check the keys themselves. Look for a blue picture, usually of a calculator. Holding the FN key down and then pressing this key should turn off NumLock and allow you to type the password.
Note: It is also possible that the 'N' key on your keyboard has gone bad. If this is the case, open the On Screen Keyboard, accessible through Start > All Programs > Accessories > Ease of Access, and type your password using this.
I hope this helps!
Feb 28, 2011 | Computers & Internet
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Big screen Toshiba
there should be 2 plastic removable inserts below the screen that cover the screws. remove rhem with a fine bladed instrument
then you should be able to remove the screen.
Guy9
Jun 11, 2008 | Toshiba TZ50V51 50" Rear Projection...
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite A85-S107 Notebook Logo
1,154 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
