Question about Dell A940 All-In-One InkJet Printer
Faxing I have a Dell All-In-One-Printer A940 printer. I am having troubling faxing. I have read the manual and have followed the Installing BVRP software instructions and still it saying I have no dialtone. What can be my problem?
    President:
  • Dell Master
  • 2,022 Answers
Just check the phone line is connected to the fax if your ans is yes then pls connect one ordinary handset and chek you are geeting the dial tone and you are able to make call chek the socekt connecton also whtether it is conncetd to the proper line socket not in ext. bye
Posted on Oct 01, 2007
SOURCE:
How does the fax work in this machine?
Hello and Welcome to FixYa!
It will be difficult to describe the process in words only, so I've provided a support link below, got pictorial representations also, which will guide briefly on setting the fax capabilities on your Printer. I've also provided the download link for the User Manual as that will have a more detailed description. Even though if you aren't able to set it up you can ask me, or can also contact Dell support directly here.
I hope you will definitely come up with some solution.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: About faxing, Download Printable Guide
Jul 25, 2010 | Dell A940 All-In-One InkJet Printer
Using the scanner and fax on the Dell A940 printer
You can download the user manual from
support.dell.com/support/edocs/systems/a940/a940en1.pdf
Have fun!
Please make sure to rate this solution. Thanks.
Jul 16, 2009 | Dell A940 All-In-One InkJet Printer
Dell printer A940 fax trouble
Unless you have 'VOIP' telephone service with Comcast, your FAX will connect through your home's telephone line, not the internet (or modem). You would connect your phone line to the all-in-one printer, then follow Dell's instructions for use. Good luck!
Apr 18, 2009 | Dell A940 All-In-One InkJet Printer
I cannot get my fax to work, how do I send and receive faxes ,I am not sure how to connect the phone lines, which line goes where? bewildered not so much a computer whiz
Do you have the user's guide? That usually has all the information you need to install and set up the unit. If you don't, you can always go to the website and download a copy. Then follow the instructions.
Mar 10, 2009 | Dell 810 All-In-One InkJet Printer
Setup as fax
What you need to do to set up fax on most printers is use a standard phone cable. ( Cat 3 )
Plug one end intor the printer and the other end into a phone jack.
Then follow the instuctions on the manual to set up the fax number on the all in one printer.
With this printer you can also fax by using the microsoft software.
Here is the manual and it has step by step insturctions on how to set up faxing with software.
http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf
Nov 13, 2008 | Dell 924 All-in-One InkJet Printer
BVRP Fax Software for a Dell? A920
that comes bundled with the printer. It's NOT available for FREE outside of original install disk approach
Mar 06, 2008 | Dell A920 InkJet Printer
Lexmark X6170 fax bvrp
it's supposedly bundled with that printer..
here are some instructions..
How to Install BVRP FaxTools Software on the Lexmark X6130/X6150/X6160/X6170/X6190 Pro ID:ENUS8694 null.gif null.gif null.gif
The FaxTools software is on the Lexmark X6100 Series Installation CD. During installation of the printer driver, you will be asked whether you want to install it. If you choose to cancel this option during the installation process, you can install the software separately as follows:
  1. Insert the Lexmark X6100 Installation CD into the CD-ROM drive.
  2. When the Install Software screen appears, click Cancel.
  3. Right click on the Start button and select Explore.
  4. Click on the plus sign (+) beside My Computer .
  5. Click on the plus sign (+) beside the Lex X6100 CD.
  6. Double-click on the FAX folder.
  7. Double-click on the relevant language folder on the right-hand side.
  8. Double-click on the Setup executable. (Note: The correct setup icon is the one with two white arrows on a grey foreground.)
  9. Follow the on-screen instructions to complete the installation.
Feb 18, 2008 | Lexmark X6170 All-In-One InkJet Printer
The Fax software on my a940 seems to be gone
gotta get the Vista friendly printer management update, from the printer mfg page.
Feb 05, 2008 | Dell A940 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
104 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
