Aircon stops every 20 minutes - Heating & Cooling
    Guru:
  • 587 Answers
If the a/c is shutting off every 20 minutes then you want to check the condenser motor and make sure it' s running and putting out a lot of air and not stopping every 20 minutes causing the high pressure switch to trip.If it is then turn the power off to the unit and spin the fan blade to see if it turns freely if it does then check the fan capacitor to see if it's good. Then check the condenser coil and make sure it's not dirty. If both of those are ok
check the suction line ( the big line at your outdoor unit) and make sure it's cold, if it's not then you might be low on refrigerant and need to recharge the unit.
Posted on Aug 02, 2009
06 Grand a vitara v6 overheating on open highway. Didn't do it in traffic or stop lights. Had aircon on as it was a hot 38 degree day. Aircon would get warm as temperature gauge went to red. Went back to...
bubbling when the coolant is full indicates a head gasket problem. have a compression test done to check for gasket/cracked head. have a flow test done on the radiator as the cores may be blocked reducing coolant flow.
Nov 07, 2014 | 2006 Suzuki Grand Vitara
Nissan d40 airconditioner stops after while driveing
get the gas in aircon checked may well be low on pressure
Jan 16, 2014 | 1994 Honda Accord
A error code E154 appears, then I shut down the unit, and restart, no problem a few minutes, then the error code appears again. have you the solution?
Hello there, I guess your Running capacitor is leaking already, when you start your aircon it will run after a minute the aircon will stop with errors, because the fan is stop running due to busted capacitor. thanks
Apr 25, 2011 | Heating & Cooling
Car aircon
Your problem is most likely in the closed gas system of you a/c unit. You mostly need to regas the system . Also have the system checked by a qualified a/c technician.
May 14, 2010 | 2003 Toyota Corolla
Car aircon
try adjusting the thermostat of the A/C , that is one of the main reason of the change of condition...
reply if it will do the same thing
Mar 23, 2010 | 2003 Toyota Corolla
Unwanted fumes gas in ford falcon futura
is the car on recirculate or fresh air? air from your aircon comes through the bottom of your front windscreen, make sure its clear and free of leaves or anything that can cause blockage to stop it from become damp inside the aircon ducts. if it is definately petrol fumes you may have an exhaust leaking from your engine bay, releasing the fumes into your cabin, that is the most common reason for petrol fumes in your aircon.
Jan 03, 2009 | 2005 Ford Futura
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
