Question about SanDisk Sansa e250 MP3 Player
I can't get my sandisk e250 mp3 to connect with my computer.
I've formatted the mp3, and
I've set all of the settings to the factory setting.
Go to settings then go to usb mode and change the mode.
Posted on Apr 13, 2009
I have the sansa e250 mp3 player,and i want to format it,how can i do that?
Hi!
Please follow this:
  • Disconnect the device from your computer and turn it on
  • Go to Settings > USB Mode > MSC
  • Connect the device again
  • On My Computer, look for Sansa E250 (Removable Drive)...
  • Right-click on the E250 and choose Format
  • Click "Start" and agree to start the formatting process
  • Done!
If you are satisfied, rate my solution with 4 "thumbs" or (even better) add a testimonial.
Good luck and Best regards,
Pelu.
Apr 28, 2011 | SanDisk Sansa e250 MP3 Player
How do I reset my Sansa e250?
For resetting Sansa e250 to factory settings:
Start from Main Menu.
Next select:
Settings (image of an equalizer)
Reset All
Yes
Having problems reading the language first choose yours, select:
Language is the 5th option after Settings
Change the language to the language you prefer
Jun 20, 2010 | SanDisk Sansa e250 MP3 Player
Sansa E 250 bad track
On your e250, go to the "Settings" menu, select "USB Mode", and set it to "MSC". Then connect your e250 to your computer. It show up under My Computer as a "removable disk". Right click on it and select "Format". Click on the "Start" button, making sure that Quick Format is NOT checked. Wait for the formatting to complete, unplug your e250, wait for it to reboot (or force it to reboot if necessary), plug it back in, and copy your songs back onto it.
Jan 27, 2010 | SanDisk Sansa e250 MP3 Player
How can i format my e250 drive?
http://www.sansa.com/download
If it cant open on your computer change your usb settings from MTP to MSC and try connecting again.
Jul 18, 2009 | SanDisk Sansa e250 MP3 Player
Formatting a Sansa e250
Plug it in, open "My Computer" right click your device and click "Format" a window will pop up with the settings on how you want to format it, make sure it's set to FAT, then click "Format."
Hope this helps!
Oct 13, 2008 | SanDisk Sansa e250 MP3 Player
My Sansa e250 is only playing in MOno
Hardware issue - call Sandisk to find if you are still in warranty.
May 22, 2008 | SanDisk Sansa e250 MP3 Player
Formatting
If for some reason the Format option is gone, then perhaps some of the firmware or settings have been drastically changed or worst, corrupted.
A couple of things you can try:
a. do a soft reset - press on the Power/Menu for 15 seconds;
b. do a full settings reset - Main Menu/Settings/Reset All;
c. do a Format - Main Menu/Settings/Format but all in the internal memory will be erased;
If the above will not work, you can also try:
1. download and run in your PC Sansa Connect Recovery Tool
2. read the How to use the Sansa Connect Recovery Tool and follow the instructions carefully;
3. doing #1 will erase the corrupted files, unfortunately so with everything else. It will then restore the device software to an uncorrupted state.
Hope this be of help/ Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 07, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
Do you know if windows media player recognized your device? if windows media player does, i would recommend you to format the device using windows media player...to format your device have it connected and open up WMP,click on the sync tab the your device will be listed on the left side..then all you have to do is right click and format the device..that should work..
Jan 03, 2008 | SanDisk Sansa e250 MP3 Player
Wont turn on
If you use the my computer setting to format your player, you need to update the firmware on the device..to do so...go to
http://sandisk.com/Retail/Default.aspx?CatID=1376
Dec 31, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk sansa e200
I had this same problem on my sansa and tryed the previous solution with no luck. Out of frustration i email the sansa technical support. Try these steps to format the player: -Turn on the player and access MENU > SETTINGS > USB > MSC - Once the player is set to MSC mode, reconnect it to the computer and open the My Computer window. - Once you see the Sansa icon in the My Computer window, right-click it and choose FORMAT - In the Format window, choose FAT 32 and make sure that Quick Format is NOT selected, then choose START -Once the format has completed, disconnect the player from the computer to allow it to refresh. If you plan on using Windows Media Player to transfer files, return to the USB menu and set the player to MTP mode. Otherwise, leave the player in MSC mode and you can now resume transferring files. Formatting your player will deleate all files but you can putt them back on!!! Best of luck!
Apr 25, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
55 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
