Question about Whirlpool Duet GHW9150P Front Load Washer
Washer frontloader whirlpool
I got a whirlpool frontloader washer i keep getting a F11 dont know what that means?
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 28, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Whirlpool duet washer error code F11
    The F11 code means that the CCU (central control board) and MCU (motor control board) aren't communicating properly. This can be caused by poor contacts between the wires in the wiring harness and one of the boards. Someone reported a simple fix of carefully adding solder to thicken the contact area on the board where the wiring harness plugs onto the board.
    First unplug the washer. You need to check the wiring for any broken conductors. Try wiggling the wiring harness on both sides to see if that helps the connection stabilize. If wiggling works, then the solder solution may work. Warning: make sure to keep the new layer of solder directly on top of the previous contacts. If the solder spreads sideways, you can short the unit. Otherwise, the solution is to replace the CCU. If that doesn't solve the error, Whirlpool recommends replacing the MCU.
    If you add the model number for your washer, I may be able to point you to the parts list. I hope this helps.
    Aug 02, 2015 | Whirlpool Washing Machines
    I have an F11 error code on my maytag frontload washer?
    It sounds like a control unit has burned out. There is a computer that speaks to the motor to tell it what to do. If you reset it and a part is bad the computer will still recognize the problem and thus resend error message.
    May 04, 2014 | Maytag Washing Machines
    Whirlpool Duet F11
    Seems that the fault is within the main control panel board. It can be due to failure of the drive relay or semiconductor within and might need a board level service or a replacement of the board.
    Jul 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    My Whirlpool Duet front load washer is giving a F 11 error.
    power failure--------unplug the unit for 5 minutes and see if it clears that code
    Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    F11 code on kenmore frontload washer HE3t
    My f11 code is repaired! I got a clamp from Home Depot put it on the ccu unit on the right side tightened it shut and haven't got the stinking f11 code ever since. No more banging it again! I can finally do my wash without the horror beeping sound going off every time.
    May 23, 2010 | Kenmore Washing Machines
    F11 Kiss of Death!
    f11 is in my experience has been a faulty rear board, its really a communitcation error betwwen the control board, the latch and the lower motor control board(rarely an issue with the motor controller, but have seen faulty wiring(in which case had to replace the entire wire harness, as well as ann occasional door latch. keep after it under warr, so when it does runn out youll have records of attemps to fix while underwarr and make them make good on repairs after warrr expires
    Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    F 11 code
    check the connections between the main control board and the motor control board, make sure that the connections are tight, might bee good to remove the blue and black wired terminals and reseat them if you still have an issue then one of the boards will be bad
    Apr 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    F11 Code
    Plug off the wall. Shaking & vibration of your washer causes circuit board connections to become loose; due to faulty manufacture. Remove the 3 or 4 screws from the back & take off the top cover to secure the connections, make sure they are tight. This applies for the F11 & F dl codes. Dont forget to rate me &, merry xmas!
    Dec 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    47 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
