Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
160,not 250 won't work. comp won't even see it, even after disc install
  • 1 more comment
  • occdoc Nov 05, 2007
    I have a SimpleDrive 500 GB SimpleTech hard drive that worked fine for about 2 months. Now the computer will not recognize it. I am not sure how to solve this problem. Thanks.
  • thecloser Nov 06, 2007
    I get a bubble stating,
    Power Surge On Hub Port
    A USB device has exceeded the power limits of its hub port.
    For assistance in solving this problem, click this message.
  • tracyrenee5 Nov 29, 2008
    i have the same problem
I couldn't find drivers for this peice of **** on the simple tech website, just try plugging it in over and over again until the drive sees it. I have problems with this too and that seems to work... Make sure you don't have all your eggs in this basket.
Posted on Aug 11, 2008
What is a BIOS setup? Where do you go to find? How do you do this. ?
Posted on Apr 15, 2008
  • 67 Answers
Go to bios setup select to boot cdrm or cdrw and install windows
Posted on Sep 19, 2007
SOURCE:
PC won;t boot after memory upgrade
your comp can only handle so much ram,you also need to use the same ram,check how much ram it recognizes with only two,then 3,then 4,64 bit comps only recognize 4 gb,32 bit recognizes any gb ram.
May 22, 2015 | Computers & Internet
My comp won't read a game disc i'm trying to download, no on screen directions, no nothing. Can I reinstall this DVD ? If so, where and how can I find installation downloads ?
im not sure which dvd you are referring to will need a name for me to lacate the specific dvd
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)but don
Sep 04, 2011 | Computers & Internet
I have a Boggle Interactive disc WINDOWS 95, 99021, made by Hasbro and it will not load on to my new computer. It played ok on my old comp but won't load. In fact the comp. doesn't even act like it...
TRY DISABLING YOUR VIRUS PROTECTION FIRST...THEN INSERT YOUR DISK, GO TO SOFTWARE PROGRAMS, CLICK ON INSTALL NEW SOFTWARE...OR YOU CAN TRY LEAVING YOUR DISK IN AND RESTART YOUR COMPUTER, TO SEE IF IT WILL DETECT YOUR SOFTWARE...MORE THAN LIKELY YOU'LL HAVE TO DISABLE YOUR VIRUS PROTECTION FIRST, UNTILL YOUR ABLE TO INSTALL THE SOFTWARE.
DO NOT HAVE YOUR GAME HOOKED UP, UNTILL SOFTWARE IS INSTALLED.
REBOOT YOUR COMPUTER, WITH GAME HOOKED UP, SO THE COMPUTER CAN DETECT YOUR HARDWARE.
HOPE THIS HELPS!
Aug 31, 2011 | Video Game Consoles & Games
Ocr i have lost my disc a long time back imy comp crashed and lost most of my comp. i need the ocr software to scan things on lexmark pro205
If you lost your installation disc to install the Lexmark OCR scan software, please contact Lexmark Technical Support Center to request for one.
Jul 22, 2011 | Lexmark Prospect Pro205 Wireless...
My cisnet computer keep reading disk errors.i tying to install window xp. it also system window 32 problems. is a missing files. how do you fix it?
u need to format using a windows 98 sec boot disc. place the floppy in to the comp. switch on the comp. let the disc run, making sure your bios is set to boot floppy first. when disc is finished setting type fdisk then when finished delete drive by pressing 4 .add drive when finished by pressing 1 and following the insturctions. when finished press crtl+alt+del let the comp, reboot the when the disk as finished loading type format c: press yes let it run press crtl +alt+del again then take out floppy disc and put in winpx . as this sounds like you have a virus in your registery
Aug 03, 2009 | SimpleTech 320GB SimpleDrive External by...
NEED HELP!!!!
You can download the PC Suite of LG KU990 from Rapid Share. Its in two Parts.
Part 1 Part 2
If I was helpful, kindly do Rate! Regards.
Jul 29, 2009 | LG KU990 Viewty
No installation disc, but apparently i didnt need one
I bought the same product, I noticed that connecting the device to the USB ports at the back of the PC body and using shorter cable solved the problem, try each of the ports at the back of the PC.
Jan 25, 2009 | Western Digital Elements powered by WD 320...
Lost installation disc
IF you have lost your installation disc to your computer, you can always download the drivers and software online from Lexmark's Support and Download Page.
Go to:
http://downloads.lexmark.com:80/perl/downloads/downloads.cgi?ccs=229:1:0:479:0:0
After, Select your operating system and then and download all the recommended and optional drivers.
Dec 29, 2008 | Lexmark P4350 All-In-One InkJet Printer
Search for driver
Hi Malak,
Regarding your issue you may try to call your computer manufacturer and get a cd copy for your system driver. All drivers can be found on that disc. When you have the disc just run it and it will automatically give you the drivers you need to install.
Keep me posted.
Regards,
Jeff
Oct 10, 2008 | Microsoft Computers & Internet
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
Top SimpleTech Computers & Internet Experts
Ekse
GFXTech
Marvin
Marvin
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
