Home | Hotpoint | 24 in. HDA2000Z Built-in Dishwasher | Does not drain. Wat...
Hotpoint 24 in. HDA2000Z Built-in Dishwasher
Problem for Hotpoint 24 in. HDA2000Z Built-in Dishwasher
Does not drain. Water stays in the bottom.
By simons_allen on Apr 13, 2009
Have a 1980's Hotpoint dishwasher that has stopped draining. What is the problem? Allen Simons simons_allen@yahoo.com
Solution #1
posted on Jun 19, 2009
Not Rated)
localwonder
Rank: Guru  Hotpoint Expert
Rating: 92%, 2676 votes
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Was this helpful?
Yes
No
Popular Solutions for Hotpoint 24 in. HDA2000Z
Questions and Unsolved Problems for Hotpoint 24 in. HDA2000Z
Do you recommend Hotpoint 24 in. HDA2000Z Built-in Dishwasher?
Answer
Answer
wash cycles not working, load machine, select wash cycle, it then runs but does not clean
Answer
will not wash- not sure if it is the same model, but i turn it on to wash, and it doesnt start a... (More)
Answer
when i turn the dishwasher on the water comes in and it sounds like it is washing but when i open... (More)
Answer
My hotpoint dishwasher leaks every time it starts to drain the water.
Answer
dishwasher starts filling with water, but starts emptying a few seconds later
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hotpoint 24 in. HDA2000Z...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
