Question about Samsung Dishwashers
Changing a drain hose on a samsung
I'm trying to change the drain hose on my
Samsung dishwasher. Is there any easy way
to access the drain hose to change it. There
is side access, but if you have larger hands
you cant get to the hose clamps. Is there
a back panel that you can remove to get to
it easier?
  • 1314 Answers
SOURCE: Drain hose replacement - Hotpoint dishwasher DF61
have you removed the bottom kick plate
Posted on Feb 15, 2008
  • 351 Answers
SOURCE: Whirlpool dishwasher not draining
blockage in the drain hose somewhere
Posted on Mar 20, 2008
SOURCE: Siemens Avantgarde - Water remains at the bottom.
I have now managed to remove the side panel. The removal of the top was needed before the side could be dealt with. The top remaval is shown in the instructions for the unit. Two ligs at the rear need to be pressed in using a screw driver. The top then will slide to the rear and lifts off. This procedure is for the Siemens model SE25T850GB08 however I suspect that the model this case is attached to would be the same. I've now resolved my issue in this case. I still however have not been able to resolve the water draining problem.
Posted on Jul 27, 2008
rickzilla
  • 706 Answers
SOURCE: drain hose problems
Hello Teri,
If you have access to a Home Depot or Lowes or any other home goods store, they should be able to provide a hose for you .. You may need to use a hose clamp to attach it but most of these types of home goods stores sell all the components for this... Since its a Kenmore ( you may be able to go to Sears and get a drain hose kit..but most drain lines are pretty much the same as long as they have the right ID and you have hose clamps.. Hope this helps you..
Regards,
Rick
Posted on Nov 29, 2008
voodoomox
  • 1689 Answers
SOURCE: GE Dishwasher not draining the water out
hi eddavid,
thank you for using fixya.
with regard to your issue, here is the possible cause. The check valve is worn and letting water back in the tub while it is draining there for not draining all the water out.
Can temporarily be repaired with a cork until i can get a new check valve.
You may also try to restart dishwasher with rinse only and as soon as it starts push reset and it will drain water out.
Going deeper into the appliance, the dishwasher has a rubber flapper style check valve located between the soil collection chamber and the drain line. These go bad and restrict the water from draining out. Also some models have a valve under screen in back called a piston valve if this has debris keeping it from opening and closing or is deteriorated you will need to change this also.Start washer let fill initiate pump out water should exit rapidy into drain if its slow check both items above
Hope this helps, if you have other question, please do not hesitate to let me know.
Regards,
voodoo
Posted on Apr 26, 2009
How to fix samsung dishwasher code se
The code is 5E
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose.
If the drain hose is kinked, there will be an excessive amount of water in the bottom of your dishwasher after a cycle has been completed.
In order to access the drain hose you need access to the back of the dishwasher. If your dishwasher was recently installed, contact the installer to move the dishwasher and inspect the drain hose.
If the drain hose is not kinked, but your dishwasher is still not draining, service is required.
Apr 21, 2015 | Samsung Dishwashers
When I start my dishwasher it start to run then it stop and flashes se code what causes that
Se code Samsung DW80F800UWS What should I look For?
Theres a 5E I can't find a Se
Nov 22, 2014 | Samsung 24 " Built-In Top Control...
I have a Samsung Dishwasher DMT800RHS, dishes have brown film, tried Lemon Magic, fixed 9e code, still dirty dishes. Used liquid detergent, still dirty dishes. Sometimes white film.
Sounds like its not draining properly between cycles. Its time for an appliance engineer I'm guessing. Can you access the drain pump hose area to see if its clogged.
Nov 06, 2014 | Samsung 800 Series DMT800RHW 24"...
5e or se code on samsung dishwasher
The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose check out okay.
Sep 07, 2014 | Samsung Dishwashers
What does samsung dishwasher error code se
SE (or 5E) on a Samsung DishWasher means Drain Error - Water not draining. Check the drain pump and drain hose for an obstruction; If that's okay, you will probably need to replace the ECS sensor.
Apr 21, 2014 | Samsung 24 in. DB5710DT Stainless Steel...
How do I replace the drain hose on a Samsung dmt300 dishwasher?
Flip the unit onto its face (put down towels first to protect the face and catch the water that will spill out. Remove the square white access cover on the bottom by removing the 2 screws and gently prying the tabs. Now you see the connection to the drain pump. Disconnect here and route the hose out by removing the metal side cover and snapping open the plastic hose guides. The hose is 13 feet long and routes up the side to prevent water from draining to your d/w from your sink, so a universal replacement won't work, you have to get a new one from samsung.
May 02, 2012 | Samsung DMT300RFW Builtin Dishwasher
My samsung DB.710DB dishwash has standing water after a complete cycle, I've removed the baskets and arm to try to get to the drian screen what next
Check your drain hose and the house plumbing the drain hose enters for blockage. make sure your drain hose isn't severely kinked.
Feb 06, 2011 | Samsung Dishwashers
My new samsung dishwasher is not draining. What
Make sure the drain hose is not blocked.
Look at the hose from the connection on the dishwasher to the sink to be sure its not pinched or squeezed tight.
And,remove the hose from the sink drain connection and check that connection for a blockage in both directions.It my have a sink drain blockage.
Have a bucket and towels ready for a possible water mess.
Oct 29, 2009 | Samsung Dishwashers
SE error code on Samsung dishwasher
5E code. If your dishwasher has been running fine for awhile then throws a 5E code chances are it could be the pump or a blocked hose or filter but chances are its not. 1. Does the code come on after it has gone through the wash cycle and released the soap dispenser? or 2. Does the code show afer 1 or 10 minutes of running without the wash cycle completing, soap dispenser still closed?
Number 1 is easy to check just diconnect the drain hose and run the hose into a bucket to see if the hose or filter is clogged or pump is working. These machines only use about 2 gallons of water and the pressure is very low its easy to do in a bucket. If number 2 occurs, its not a clogged hose or filter or pump issue the machine is not even cycling.
If number 1 checks out ok you have water flow but shuts down and number 2 has occured, its your Case Level Sensor its the electronic solid state float, DD94-01006A its either sticking due to water impurities or its bad.
Its actually pretty easy to trouble shoot or fix. You have two choices but the machine has to come out. The sensor is located behind a metal plate on the lower left side ofthe machine. You can;t miss it it looks like a float, has a black float inside a clear plastic housing and some wires going to it. You can pull it out and clean it (The float should go up and down with no sticking at all). Or just buy a new one $35.00ish and put in. Also check the inlet hose to the float make sure its clear and clean DD67-0057A.
There is one catch to this that can cause lots of grief if ANY water at all comes out of the float while changing it. If any water gets in the bottom of the catch basin underneath, the very very sentive probes will detct it and throw a LE code and the washer will not work. that is not a big deal just need to pull the basin off and dry it out. The smallest amount of water can cause the sensors to react since its a protection system.
Samsung dishwashers are very quite and wash extremely well but there technology and engineering sucks along with their warrenty and repair manuals there are no manuals for the home owner or much for the repair guy.
That float will have problems again and again and again either its dirty or broken and will cause another 5E code situation.
Side note; food grinders in a dishasher are stupid! All dishes places in a dishwasher should be rinsed! A domestic dishwasher should not be used as a disposal. It makes your house stink and tons of bad bacteriea will grow in places you do not want it to, not to mention they are not made to work like you would think.
Best dishwasher with the least trouble, easy to fix, easy to dignose, easy to work on, good manuals, few problems, good warrenty, best built, quite running, washes great, very well engineered is BOSCH.
Terry
Apr 15, 2009 | Samsung 24 in. DB5710DT Stainless Steel...
Dishwashers Logo
472 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
