Question about Del-Rain 1500-V 1500 Watt Ceramic Heater
  • 2 more comments
  • Anonymous Nov 03, 2007
    where is ceramic element?
  • Anonymous Apr 10, 2008
  • Anonymous Nov 29, 2008
    Mine is the modelvb2-iva original disc furnace working fine shut off moved to another room plugged in and nothing tried in other outlets and still nothing no light no anything.
  • Anonymous Feb 02, 2009
    Del-Rain Original Disk Furnace Model 1500 IV It has bad Thernost or Current limiter
  • 625 Answers
Can you read resistance across the ceramic element?
Posted on Sep 11, 2007
I need to program my garrison convection heater 1500W
i want the spects for the 1500w garrison plug-in convecton heathger
Nov 05, 2013 | Heating & Cooling
Sparking-i have 2 model lt-1500vi
I have had the same problem. I took it apart and found that one of the metal discs was corroded and little fragments were chipping off causing it to spark. I am looking to find a place to buy the disc.
Nov 01, 2013 | Del-Rain 1500-V 1500 Watt Ceramic Heater
A ERR comes up on my American comfort heater
Remove power for some time and switch on after few hours , this might reset any error on the processor , if not the error could be due to fault indication of a failure within the heater, could be the infra or the element.
Oct 02, 2013 | AMERICAN COMFORT ACW0035WE 1500W Infrared...
Does anybody out there have an owner's manual for Lifetime Furnace Model # 1500 VI by Del Rain?? PLEASE contact me!
I have used one of these for years and was looking to find a new one and came across your question. I don't have the manual but here is how the programming works:
On/Off (obvious)
Heat/Fan (if lit it makes heat if off it just runs fan)
Auto/Manual (if off the temperature slider causes the fan to run on high or low)
Preset on (I don't use this but probably can be used to set it to turn on after a selected number of hours)
Preset off (if lit the heater will turn itself off after the number of hours shown on the right)
Time select (press this button to change the number of lights shown vertically ... each is labelled and you add them up to get the hours you want from 1 to 15 ... so if bottom two numbers are lit (1+2) then heater will run for 3 hours then turn off)
Feb 17, 2012 | Del-Rain 1500-V 1500 Watt Ceramic Heater
Del-rain model lt-101 does not blow hot air only cool air!!
most likley the high limit,you can check with ohm meter,or simply short it out,but thats a fire hazard.if element is burned out is junk.again check with ohm meter.
Dec 22, 2010 | Del-Rain LT-101A 1500Watt Ceramic Heater
How many amps is this model
Like all 1500 watt appliances, 12.5. You divide the watts by the volts to get the amps (except for reactive loads like motors etc.). Why do you ask? Is it popping breakers?
Nov 15, 2010 | Del-Rain 1500-V 1500 Watt Ceramic Heater
Del-Rain 1500V ceramic heater switch.
is it a little rocker switch ? if so any local hardware store, like HD, or Lowes, or any appliance wholesaler will carry these switches, or try online to the manufacture, hope that helps
Jan 20, 2009 | Del-Rain 1500-V 1500 Watt Ceramic Heater
I need a switch for Pelonis 4 Disc Ceramic Space Heater Furnace 1500W
generally a primary power swich can be obtained at your local hardware store. A switch rated for at least 15 amps will be needed. Unplug the heater remove the bad swich and take it with you, match up a replacement and install.
Dec 18, 2008 | Heating & Cooling
Electricity cost per hour
1500w / 1000w = 1.5 kwh. Every hour you run (assuming it is at 100% peak power) you use 1.5 kw. Just multiply that rate by how much it your power company charges per kwh.
Estimating high at 10 cents per kwh it would be $1 for every 10 hours you run the heater, or $2.40 per day, or about $72 per month if you ran it 24/7 for 30 days.
It is FAR cheaper to use these types heaters to heat one small room than an entire apartment or house if you are only in one room the majority of the time.
Dec 12, 2008 | Lasko Ceramic Heater
Heater smells like it got too hot!
check for dust in the air path through the heater. the fan forces air through the element.  if you have an air blower - blow air in a reverse direction through it.
Oct 15, 2007 | Del-Rain 1500-V 1500 Watt Ceramic Heater
Del-Rain 1500-V 1500 Watt Ceramic Heater Logo
243 people viewed this question
Top Del-Rain Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Del-Rain Heating and Cooling Expert? Answer questions, earn points and help others
