I have asus motherboard p4s800d-x i have two apacer pc 3200 ddr400 512 ram and bought two kingston pc3200 ddr 400 512 ram. when i installed the kingston ram to get 2 gigs of ram instead of one i get to windows screen then get a blue screen and it just keeps rebooting. what do i need to do to get this to work
Did you try to uninstall the 2 Apacer RAM modules & test only with the 2 Kingston modules to see if your PC will boot up?Did you try to uninstall the 2 Apacer RAM modules & test only with the 2 Kingston modules to see if your PC will boot up?
You can't post conmments that contain an email address.
You are correct, this motherboard can use either 333mhz DDR (PC2700) or 400mhz DDR (3200) chips.
You may have a bad chip. Also make sure you are not mixing this chip with another of another speed. Its not good practise to mix 333mhz and 400mhz though some motherboards will still work like that.
Your best bet for compatibility is crucial DDR PC3200 • CL=3 • Unbuffered • NON-ECC • DDR400 • 2.6V • 128Meg x 64 •
Personally I have had bad luck with kingston ram myself.
Chris
The Asus P4S800-X MB can use Dual channel DDR memory and single channel memory. The dual channel memory which comes in matching packs. (Normally 2 DIMMS per pack) is the faster memory. In other words if you are installing, 4- 512MB DIMMS of PC3200 all memory should be matched, or you're MB may not see all connected DIMM'S. See page vii in you're manual. If you're running windows XP, Home or Pro edition the bios will show up to 4GB of memory installed but windows XP 32bit will only show 3GB of memory. As mentioned above all 4 of you're 512MB of memory should be dual channel and run at the same speed. You can run both single channel and dual channel but you must follow Table 1 in you're manual. (1-9). Example; PC3200 400MHz. Or 4-512MB PC2700 333MHz. See page 1-9 for memory configurations and the QVL list supported. Check out Asus FAQ's; http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=P4S800D-X&product=6&os=17
This should help you configure the memory. Good luck! Mike
You do not say what memory you are trying to install.
The ASUS P4S800D motherboard has four memory slots that hold DDR PC2700 or DDR PC3200 with a maximum of 1GB per slot, so the installed maximum is 4GB.
DDR memory is generally available in 128MB, 256MB, 512MB and 1GB modules. If you already have memory installed, it must be at least 128MB so you cannot add modules to 'bring memory to 128'.
Either you have a different motherboard and posted in the wrong section, your memory calculations are wrong, or you have used older PC-133,PC-100 or PC-66 memory instead of DDR. The last is unlikely as older SDRAM has two notches and won't physically fit into a DDR slot that only has one notch.
Please re-post with the specific motherboard model just to confirm and a list of the memory modules you are trying to use.
This is the memory specs for your board
4 x 184-pin DIMM Sockets support max. 4GB unbuffered non-ECC
PC3200/2700/2100/1600 DDR SDRAM memory
Dual-channel memory architecture
