Ruud heat pump
Compressor and large line from top of compressor freezing.
  • badboy101 Sep 11, 2007
    how do you get access to the inside coil on ruud heat pumps.
Hello do you have a Soleus KFR-18w/d mini/split
If so I have the same problem
Posted on Jan 26, 2008
    Novelist:
  • 114 Answers
THE LAST THING TO SUSPECT IS "LOW ON REFRIGERANT". MAIN CAUSES IN ORDER: "OVERCHARGED",DIRTY FILTER, DIRTY COIL, BLOWER MOTOR IS HEATING-UP AND SHUTTING OFF ON INTERNAL OVERLOAD PROTECTOR, ANY THING THAT MAY BE RESTRICTING AIR FLOW IN THE AIR HANDLER, NON-CONDESEBALES, LOW REFRIGERANT. I FIND ON MOST LOW CHARGED UNIT THE "SUCTION" LINE IS WARM AND THE EVAPORATOR COIL IS FROSTED. YOU ONLY GET ICE BACK ON THAT LINE ON THE COMPRESSOR IF YOU VISUALLY LOOK AT THE EVAPORATOR COIL. A COIL THAT IS ICED UP IS LACK OF AIR OR A OVERCHARGE. A LOW SECTION OF SOLID ICE INDICATES A LOW CHARGE.
Posted on Sep 27, 2007
  • 1,420 Answers
If the top of the compressor is freezing you either have low refrigerant or a restriction in the coil. Check the air filter and change if necessary. Turn the outside unit off using the outside disconnect found a few feet away from the condenser. Let the indoor unit blow air for a few hours to melt the ice off of the coil. Turn back on the outside unit and after about a half hour, you should feel the cool air from your ducts. If the cool air gets warmer over the next hour, you will need a tech to look for leaks and recharge your unit. If it continues to blow warm air even after the 3-hour wait, you have other issues. To answer your original question, on the indoor unit you will find access panels that can be removed for inspection and cleaning. They are commonly located where a 3/4" drain pipe exits the cabinet. While the unit is off, remove these panels and inspect for a buildup of debris. Good Luck!
Posted on Sep 12, 2007
  • Chandler Ede
    Chandler Ede Sep 27, 2007
    Did you discover anything?
SOURCE:
Is a RUUD UBHC-14J11NFH a heat pump?
Ruud UBHC-SERIES is a HEAT PUMP AIR HANDLER
AND FAN COIL UNIT
Compressor and condenser not included
Spec sheet go here
http://yaunco.com/pdfs/rheem/ubhc_specs.pdf
Jul 04, 2014 | Ruud UBHC Air Conditioner
Model Number: UACC-036JAS The unit works fine. The problem is it doesn't shut down after the specified temperature has been reached. The furnace blower shuts down, but the ac unit keeps on running....
Hello, usually a stuck contactor coil will cause this on the outside unit. When the outdoor unit runs continously and the indoor blower does not run no heat is being absoebed by the evaporator coil and thus the line freezes. Replaceing the contactor will fix the problem.
Aug 30, 2011 | Ruud Heating & Cooling
I moved into a house and the previous owner knows nothing about the heat pump and I don't know if its works or not......how much would it cost to do a diagnostic???
First of all, you confirm with your model whether there is heat pump. If it's with heat pump definately RV (Reversing valve) near the compressor will be there.You can see from top angale in your condensor unit. And also keep 80 degree setting and "heat " mode in your remote and check the heat air comes from indoor.
Dec 13, 2010 | Ruud UAMB Air Conditioner
Condensor fan went out on 1999 ruud heat pump.
Did you try pushing in the contactor to see if the unit will even run?
Jul 18, 2010 | Ruud UBHC Air Conditioner
Aux heat always comes on in heating (Ruud heat pump)
what type of system is it, if it's it Rheem the o/b needs to be set for B, if not check the freon charge, or thermostat, there will be a point where the aux. heat comes on when you turn it up, poss. only 4 degrees, is it a mercury stat or digital ?
Feb 01, 2010 | Ruud UAMB Air Conditioner
Why does 0ne of the compressors on my ruud rkkb a240dl40e ice up
possible low charge. has this compressor curcit had past problem .
condenser clean / condenser fan ok . heat pump?
Jan 21, 2010 | Ruud Heating & Cooling
Outside compressor is frozen - shut the fan down. Will it defrost and be operational
Is the unit a heat pump? Did this unit freeze up during A/C mode? Only if it was due to mild weather and thermostat turned down to low., past 68 degrees. Filter could be dirty or coil dirty or low freon charge.
Jan 10, 2010 | Ruud Handle Air Conditioner
Ruud 5-ton 10 SEER heat pump compressor turns off after 20 minut
First turn it to cool and see how cold the big cooper line is if it is not real cold you could be low on freon but if it is cold your compressor is bad
Nov 12, 2008 | Heating & Cooling
RUUD Central Air/Heat Pump
Start with the simplest first it,s not fun but it's necessary EVERY TIME. Clean your evaporator and condenser coil, change your air filter. Getting to the evap. coil is often a real headache and a result doesn't get done often. When its clogged as you probably know the refrigerant can't absorb heat at the coil so it tries to absorb heat on the way to the compressor freezing the hot gas line the safety circuits that protect the heat pump compressor from getting liquid refrigerant back to the compressor almost immediately will take the compressor of line (looking somewhat like a defrost cycle). I hope this helps it's a tough repair GL!
Apr 10, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
590 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
