Question about GE PSS26SHRSS Side by Side Refrigerator
Appears there is a bad connection or switch
GE Profile refrigerator model no pds22mbraww. Some times when the door is opened the inside light and gages will not turn on. If you hit the side, shake the refrigerator or trip the inside switch, lights and gages turn on (compressor also starts). Manually pushing the switch may or may not turn on the unit. If the door is open and I bang on the upper panel around the switch, lights come on and the unit starts cooling. The problem just started and happens every few days, not continously. I have cleaned the power connectors at the lower bottom of the unit, but this did not fix the problem.
I have the exact same problem. Except mine will go out of temperature range. I have replaced the thermistor in the fridge and it hasn' resolved the problem. The temporary solution I have come up with so far it to unplug the fridge from the outlet to clear the motherboard and then plug it back in after 10-15 mins. It sometimes lasts weeks, then acts up again. I'm guessing it's a motherboard. (my next step)
Posted on Jan 13, 2010
Gsc3pgxcfss warm fridge, freezer working fine, lights off in fridge
James, not sure I understand your message when you say both lights go off, but later say lights begin working. Do you mean they go off when you push the buttons at the door? And when you say no cold air comes from the freezer, is the freezer door closed? See if air begins flowing with freezer door open. If so it would indicate the return air path from the refrigerator to freezer is blocked.....damper staying closed or evaporator coil frozen up. The return air path has to be open to allow the freezer to keep sending out cold air to refrigerator when freezer door is closed. You might thoroughly defrost to make sure coil is not frozen.
If the door button for the refrigerator light is bad it can signal that the door is open all the time, so the freezer will never send cold air to the refrigerator. And that will be good news. Door switches are cheap. If you don't have a volt meter and know how to check switch, just remove the door switch from the refrigerator, leaving wires dangling, and close the door with a thermometer inside to see if it begins cooling (or just wait a while) I had that problem a year ago and was happy to find a bad door switch. More often it's a frozen coil, and that can be more expensive to fix. Sometimes you can discover a bad switch by pushing in the door button and the light stays on, but it doesn't sound like your situation.....sounds more like a frozen coil. If so, maybe all this extra information will help someone else.
Mar 23, 2014 | GE Profile PSW26P Stainless Steel Side by...
All of the lights in the refrigerator side are out.
Can you provide the model number found somewhere around the fresh food section door? When you say LED lights it call to mind the GE Monogram but it does not have LED lighting. Here is a link to that Service Manual HERE I need your correct model number to look up the wiring diagram. From looking over other diagrams the problem could be a bad door switch, loose connection or a defective relay on the motherboard. I will be here to answer any questions, Thanks Sea Breeze 792bf8b3-72e7-4ea7-b313-81ae6db327a8.jpg
Apr 25, 2013 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
Ge profile 2004 open door and temp controls off shut door open they come back on light was staying on sometimes to bottom half of coils in freezor froze freezer working but temp in frig 50s on off fri
It is possible the refrigerator is low on Freon. You will need to remove the back panel inside the rear of freezer to examine the evaporator coils. If only a few rows have frost it will be time to replace the refrigerator. If the control panel in the freezer dispenser are coming on and off there may be a bad connection in the plug under the top left door hinge cover. Check that the plug is tight. Let me know what you see first behind the freezer wall, Thanks Sea Breeze
Dec 12, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Light wont shut off, heats up to 88 degrees
Most times this is a defective fresh food section door light switch located in this photo as location number 609. Click Here=> PSC23NSTESS Fresh Food Section I am going to send you the service manual for your model and the information that explains how to change the switch is on page 19. If you do not already have the new free Adoobe Reader installed on your computer click here=> Adobe Reader X (10.1) Just make sure to uncheck the items not needed during the download. There also could be another problem related to the mother board that can also keep the light on while door is close but not likely. The part number for the light swirch is=> WR23X10175 Light Switch Information on how to test the switch is also on that page. Until we have repaired the problem please unplug and remove the lights because this heat will keep the refrigerator running and possibly melt the plastic housing holding the bulbs. Click here for the=> GE Artica/Profile Service Manual
Here is another page with information and wiring diagrams=> GE Artica/Profile Technical Information
I will be here to assist you if you have any questions so feel free to let me know, Thanks Sea Breeze
Please rate this solution and as always Thank You for using Fixya!
Jun 21, 2011 | GE CustomStyle PSC23NSTSS Stainless Steel...
My alarm keeps going off saying a door is open. IT is not. I tried to push the off buton on the beeper but it will not allow me to. How can I turn this off. It continues to go off every 5 min
DEFECTIVE DOOD SWITCH CONNECTION OPEN THE ELECTRICAL DEPARTMENT LOOK FOR THE CONNECTION OF THE INSIDE LIGHT AND THE DOOR SWITCH THEY SHOULD BE ON THE SAME CIRCUIT
Oct 24, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile refrigerator panel on front has stopped responding to requests for ice. It give water, but no ice. Any ideas on what is needed?
Yes, we will need to check the wiring from the motherboard to the dispenser controls. Also we need to test the door switch. The door light switch works two ways by turning on light when open and turning on dispenser controls when closed. Sometimes the door switch is bad. I have a link and will work with you to solve this, Let me know, Thanks, Sea Breeze
Apr 18, 2010 | GE Profile PSS26NGS Side by Side...
Ice maker not working
OK, that should be no problem. Test your ice maker and fill with water if empty of ice. If full of ice and not moving to dump tell me. I need to help you locate the problem doing that and answering will tell me the problem. Also look around the door frame and inside for the model Profile that you have. and get back with me as soon as possible, Thanks Sea Breeze
Nov 19, 2009 | GE Profile Stainless Bottom-Freezer...
Light switch appears to have failed. Light sometimes come on when the door is opened but now, it does not come on regardless of toggleing the switch.
This may be as simple as changing the bulb and not the switch. There is a good chance the bulb was loose and barely making a connection or the filament in the bulb was about to burn out. If this has been helpful please rate the solution.
Apr 23, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Refrigerator
If you have heating in the freshfood side there is only one possible. The light inside is staying on and allowing the bulb to heat up the refrigerator. To fix this you will need to replaced the door switch. To check simply unscrew the light bulbs and see if the problem goes away, or open the door and push on the door switch and see if the light is going off. Please let me know if this is not the problem and I will be happy to help. Please let me know if this did FixYa.
Mike
Sep 07, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE Profile Spacemaker 2.0 Microwave
If it goes dead or blows the breaker or GFI when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 16, 2008 | GE Profile Spacemaker Over-the-Range...
GE PSS26SHRSS Side by Side Refrigerator Logo
101 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
