Question about Braun MX 2050 PowerMax Work Top Blender
Seal/Gasket missing on Braun Blender
Hi. I recently purchased a second hand Braun blender, but the seal/gasket seems to be missing. We are based in Wellington, New Zealand. Any idea where we can get a new one, and determine which one is required? (we don't know the model no or anything).
Thanks
  • 276 Answers
Hi. There's only one common blender made by Braun, which has a triangular jug in either glass or plastic, but the locking ring and gasket are the same. It'd be a 4184, either a MX2000 or MX2050.
Auckland has a Service Centre:
Seal/Gasket missing on Braun Blender - 0.gif Key Service Ltd
7D Echelon Place, East Tamaki, Manukau City Auckland
P.O. Box: 38569 Howick
Manukau City
Phone Country Code: +64
Phone: 09-916 0960
Fax: 09-916 0970
Service for: All products
Otherwise, you can locate Service Centres in Australia.
Posted on Apr 14, 2009
I need 0914084 Blender Sealing Ring Diameter 2 1/16"or its substitute.
Unfortunately that gasket, part number MS-0914084, has been discontinued.
Here is a link to the part online: Seal MS 0914084 for Krups Appliance eReplacement Parts
Unfortunately the gasket is obsolete, and there are no known replacements. The gasket is very perticular and i do not know of any other gaskets that have a similar shape.
-Colleen@MendingShed
Apr 02, 2015 | Krups 572 Power Xtreme VI Work Top Blender
Blender is leaking
As we all know that blender is an electronic device from which you may face some problems while using it. One of the main problems is leakage, the neckline and gasket are the first problems that will give some inconvenience to you, it is a most critical part of your blender because they keep it sealed or water tight. I would suggest you the Best Blender Under 100 which is on your budget also.
Sep 18, 2013 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
GE single serve blender 898679--need replacement plastic gasket for grinding jar. I am told by Walmart, where I purchased it, that I need to return it. I don't want to return it. The blade chewed up the...
I had the same issue. i took the gasket from the other blade to use with the blade i use everyday. one trick is, don't remove that gasket to clean it but make sure it stays in there. Just soak it and scrub it good, to make sure it stays seated in there.
If the gasket comes loose while you are grinding, the lid will come loose in the base and sometimes causes you to not be able to get the jar from the base. you have to turn the jar the opposite direction to get the lid to tighten up, then you can remove the jar from the base.
I am trying to get replacement jars since those plastic nobbies that run the blender have broken off. It is down to one of 3 nobbies, so it can't be run anymore. I mght just have to buy a brand new blender but it seems so wasteful.
Mar 15, 2011 | GE Blenders
Blender seems to run right until you put glass jar on.runs very slow.
Disassemble the base from the jar, and check the placement of the gasket. Reassembly, with the jar upside down is gasket, blades, then base. While disassembled, rotate the blades by hand just to make sure that they aren't in a bind. Replace if defective.
--W/D--
Mar 06, 2011 | Hamilton Beach 50754 WaveStation 10 Speed...
My 5 speed KSBS kitchenaid blender is stuck together (glass and underneath part that would fit into motor base.
Have a look at the pictures here.
I think you are describing the blade unit's gasket being stuck. This can happen over time and especially if bits of food get stuck and harden. Try soaking for a long time in warm soapy water then keeping applying pressure until the seal between the gasket and jar gives.
Feb 12, 2011 | KitchenAid KSB560 5 Speed Blender
We have the Hamilton 12 speed blender and we can't figure out how to put the blande and the seal on the botto of the jar.
The rubber gasket goes between the jar and the blade assembly, and then the base screws on to hold them all in place.
Jun 24, 2010 | Wolfgang Puck BIBC1030 Blender
Leakage
a second seal seems to be necessary make this blender leak free.
Dec 25, 2007 | Blenders
Braun MX 2050 PowerMax Work Top Blender Logo
527 people viewed this question
Top Braun Blenders Experts
Ross Keen
NOEL
NOEL
Are you a Braun Blender Expert? Answer questions, earn points and help others
