Question about Canon GL2 Mini DV Digital Camcorder
Zoom Control The zoom function is not working when I press the control. Eventually, the camera will zoom in/out by itself. It's usually a very slow zoom in/out movement. Is this due to a certain camera setting that I'm unaware of, or will I need have it repaired?
  • Anonymous Aug 11, 2008
    The zoom controller directly on top of my GL2 works but will randomly not operate when either/or 'T' or 'W' is pressed. The top 'T/W' function forward of the keypad works great.
    I've pulled the cassette assembly apart and ensured the ribbon cable was seated properly, but that hasn't helped. Could it be the actual switch is dirty or out of alignment? And if so, how do I repair/clean it?
    Thanks
  • Anonymous Apr 23, 2009
    I have the same problem, zoom not able to operate and sometimes it sudendly zooms in and out by itself
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • Canon Expert
  • 65 Answers
The problem that you are experiencing is a common complaint on the Canon Gl2 camcorder. There are two different common parts that can cause zoom problems. One is that the zoom control on the side grip goes faulty and will need to be replaced, this repair parts and labor is $199. The second problem is a bad flex PCB and this repair parts and labor is 306. Both of these repairs include cleaning and servicing. The return shipping is free. We also guarantee the entire camcorder for 6 months parts and labor. If you have any other questions please feel free to call, email or post you questions here.
Sincerely,
Sheryl Bahr
888-283-2228
Posted on Dec 19, 2011
  • 64 Answers
On the gl2 it is supposed to be slow its not broke theres two switches that can lock the camera and the one by the mic is very slow but ok
Posted on Nov 17, 2007
SOURCE:
Function set don't function, and zoom in function even not press
The non-functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck. You can spray a degreasing spray on the lens hood sides and also assist the lens as it tries to come out, attempt to pull it out slowly while powering ON the camera. Also in some cases you can slid a thin film/paper on the lens hood sides to wipe out any dirt.
Tips to open and check for common faults: http://www.youtube.com/watch?v=v2Mj3Qp3xYU&feature=related
Use some air to blow between the lenses to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must you try and open. If so check the voltage on the motor drive check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Nov 15, 2011 | Canon PowerShot A495 Digital Camera
Zoom Buttons stopped working,manual ok
Your problem is most likely one of three things: the zoom rocker (or wires connecting it to the main control) have gone bad, the zoom motor has failed, or you have bad capacitors in the camera which are causing the controls to not operate as they should. In any case, the camera will probably need servicing to restore it to complete function.
Nov 30, 2010 | Panasonic AG-456 Camcorder
During operation, my DSR-200a intermittently starts a very slow zoom all by itself, without my hand touching it. When I zoom back out, it starts zooming in again by itself...any ideas? Thanks
This is a malfunction in the zoom control switch and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 04, 2010 | Sony DSR-200A Mini DV Digital Camcorder
Auto zooming on power up, intermittent problem
Possibly a intermittent connection in the control buttons or the ZIF (Zero Insertion Force) connector from the controls to the main PCB.
Take it in for servicing, they will do a trial by substitution (swap out control) and lubricate the connector.
There isn't really anything you can do to fix with this sort of problem.
Cheers.
Sep 28, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Top control touchpad not working plus zoom extending.
Its problem of that loading flap (technical name is control switch block) and requires replacement.
control switch block is included play-stop-rew-ff-eject etc switches including zoom-wide switch.
Jun 21, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
Cannot zoom in or out while taking pictures. trackball and volume control keys are also not working for this
When my camera stops zooming, I take the battery out and put it back on... this usually solves the issue.
May 21, 2009 | RIM BlackBerry Bold 9000 Smartphone
Zoom problem
I have the same problem. I hoped it was down to the zoom button on the top of the camera. I dismantled it and eventually got to the button but couldn't find anything loose/damaged or needing cleaned.
Did you ever find a solution?
Nov 04, 2007 | JVC Handycam GR-DX77 Mini DV Digital...
Difference between the D-460 Zoom and the D-490 Zoom digital camera
The D-490 Zoom shares the following features with the D-460 Zoom: •Olympus 5.4mm to 16.2mm (equiv. to 35mm to 105mm on a 35mm camera) lens: all-glass, 8 element, 6 groups, 2 aspherical lenses •Automatic TTL focus system •Macro mode allows the camera to auto focus as close as 8 inches •Automatic aperture selection: f2.8 to f8.0 wide, f4.4 to f12.6 tele •3x image magnification inspection mode •Panorama mode: Allows multiple pictures to be "stitched" together to create wide views •NTSC video output to TV •12-second self-timer •8MB SmartMedia card included •Built-in, pop-up intelligent flash: Auto low & backlight, red-eye reducing, off, fill-in, slow-sync •Automatic white balance control or 4 manual settings (daylight, cloudy, tungsten light, fluorescent light) •Automatic ISO sensitivity or manual selectable ISO settings •Uses 4 AA size batteries. AC Adapter is available as an optional accessory In addition, the D-490 Zoom has the following functions and features: •2.1 megapixel resolution (1600 x 1200) •Sequence mode - up to 5 shots in HQ and up to 45 shots in SQ mode (1.3fps) •Motion picture mode - up to 60 seconds of QuickTime movie (.mov) format (w/o audio)
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
Canon GL2 Mini DV Digital Camcorder Logo
836 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
