Question about Westinghouse 26" LCD Flat-Panel HDTV
No video/audio when pressing remote control or on the TV set
Had video/audio until my hand hit the remote accidentally. Then no Picture or sound. tried every button on the remote and on the side of TV.
Ger
Moved my TV to another satellite receiver.
I received picture & audio.
Then I moved the TV back to its original position.
Now it works OK.
I probably hit a button that shut off my picture & sound.
I am mystified.
Thanks anyway.
Gerry............................;-))
Posted on Apr 14, 2009
I accidentally hit a button on my remote - I'm not sure which one - and my tv screen went blank.
You hit the OFF button Lori? lol
No, you probably hit the Input or Source button. Press it again until the picture comes back.
Feb 06, 2016 | Televison & Video
TV screen went black, sound is intact, can I fix it?
This sounds like you accidentally hit the input button on your remote. It will either be INPUT or SOURCE on you remote. Turn on your TV and source(cable box) and hit one of those buttons until your picture comes back
Mar 02, 2015 | Televison & Video
Red lamp light comes on and TV turns off model # WD 60735 what's the reset procedure but it shows a good picture after a few minutes it turns off
With the remote control in your hand press the power button to turn it on. Hit menu check sleep settings some one might have accidentally hit the timer .set it to 00 clear it.
Dec 12, 2014 | Televison & Video
I have a RCA Truflat tv model 20F420T and serial number H494E2526 and accidentally hit a button on my digital cable box remote which sent the tv into a mode showing FRNT. In trying to solve the issue, the...
Using the remote control hand unit that came with the TV turn on TV. Then go to the set up menu. Locate the entry for Front Panel Lock (FPL) and select no. Once you have done that exit the set up menu then on the same remote push the "input" button while watching the screen. Push button once wait a few seconds for a picture to appear, if not then push the button again, continue until you have selected the input that provides a picture. Right now you are in the Front inputs you should look for Video 1 or 2.
Feb 18, 2011 | RCA 20F420T 20" TV
No picture
Instructions
  1. 1 Make sure the power cord is properly plugged into a wall outlet if your TV is not powering on.
  2. 2 Make sure the video and audio cables connecting your TV to external devices are secure if you are experiencing a fuzzy picture or no picture.
  3. 3 Reset the parental password if you forgot the password and are unable to view certain programs. To do this, click "Menu" on your remote control and use the arrow keys to select "Parental Controls." Enter the master password, which is "4357" to reset the password.
  4. 4 Turn off the caption vision option if you are seeing a large black box on your screen. To do this, click the "Menu" button and select "Setup." Select "Caption vision" and press the "Plus" button on your controller to set the option to "Off."
  5. 5 Check the "TV/Video" setting if you're not getting a picture on your screen. You may have inadvertently selected a video input that isn't active. Press the "TV/Video" button on your remote to cycle through video inputs.
  6. 6 Alter the brightness settings if you are experiencing a poor picture or no picture. To do this, press "Menu" and select "Video." Increase the brightness settings to see if the picture begins to appear.
  7. 7 Make sure the volume is not muted if you are experiencing a clear picture but no sound. Press the "Mute" button on the remote control to turn mute on and off.
  8. 8 Power cycle your Sony Wega if it's frozen or not responding to your remote control. Unplug the power cord and wait a few seconds. Plug the power cord back in.
Dec 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
When I turn on TV I get a message no video input. We never use video with this tv. Only have it for looking at satelite. The other main tv is working fine. I pressed all the buttons but nothing works.
Sounds like the input accidentally got changed. On the remote that came with the TV, push the INPUT button until you get your satellite picture again. If your SAT. remote is programmed to your TV, push the TV button, then the input button until you see your picture. If this doesn't work then the sat. cable is not securely attached or no longer works.
Aug 30, 2009 | Philips Magnavox 27MS343S 27" TV
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
Lost picture on my AVR-2807
There is a video select button on the receiver. Press it and it toggles through all of the video sources. Keep pressing it until the display says video=source.
Jul 23, 2008 | Denon AVR-2807 Receiver
Westinghouse 26" LCD Flat-Panel HDTV Logo
200 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
