Question about Toshiba Satellite A305-S6845 Notebook
Router working fine, but can't access internet
Using my wireless system online with old computer, so no connection problem on this one. Newer computer with Vista worked fine until today, but now I keep getting message that the program cannot display the webpage.
  • Ryan Stiers
    Ryan Stiers May 11, 2010
    What anti-virus software do you have on the computer, and what is the status of it?
Trouble connecting from a toshiba satellite Pro with an atheros AR5007EG wireless network adapter - get an ip from the router - fails first time and then gets ip. using mixed mode, wpa, wpa2. An...
if the new laptop able to connect to the wireless connection then definitely there's something wrong with the old computer.
1) do this on IE7:
A) click tools - internet options - under browsing history click delete then make sure that the first 4 tick boxes have a tick mark - then click delete - then click on apply or ok - then close IE7 then open it up again then try connecting.
B) click tools - internet options - connections - LAN settings
under LAN SETTINGS make sure that there is no tick mark on the PROXY SERVER, if there's one remove the tick mark.
( ONLY A VIRUS CAN PUT A TICK MARK ON PROXY SERVER WITHOUT YOU NOTICING IT.)
try using this steps first and if this wont work try sending me a message so that i can give you some more steps.
(ramiroreulin@gmail.com)
Apr 10, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Cant access internet but can connect to wireless TP-link router
Your friend is able to go online using the same wireless network. that means the wireless network is working properly and there might be a problem with your computer .
You said that you can connect to the wireless network but you can not go online.
Check the IP address and the default gateway of the computer.
Try to ping the router and DNS server and check what happens.
Make sure that there is no static IP address on the computer.
Click Here for more information about the routers and Internet.
Jan 31, 2010 | Computers & Internet
The router is running fine all hook ups are fine changed the wireless card took that to a computer place and it was running fine at the shop when I got the pc home unable to access the internet even though...
The cable internet is not "seeing" the computer. The router is blocking it. That is why it works if you plug it into the modem directly. How to solve this is to turn everything off and unplug power to modems and routers for 3-5 minutes. Then replug in routers. Then restart computers.
That is why it worked at the computer store. Everything was shut down and restarted.
Also, sometimes it is necessary to call the ISP (for example Comcast) and have them re-send the signal. Also going to Control Panel Network Connections and choose "repair the connection" will reset the signal.
Be patient it will work.
Aug 15, 2009 | NetGear RangeMax WPN824 Wireless Router...
I have a Netgear WGR614 V6... It was working fine yesterday but for some reason, My wireless router is not working properly. My laptop shows it is connected to my wireless router but i am not able to...
Hi, Confirm if you can go online through the modem direclty. If yes then please connect te modem to the internet port on the router and a computer to one of the 4 ports on the router and check for internet access. if this works then the issue lies on the wireless configuration of the router.
Please let me know if you can go online wired to the router or not and also specify the operating system installed on the laptop.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 27, 2009 | NetGear WGR614 Wireless Router
Wireless internet
Basicly the wireless router needs to be connected into the internet, then you will be able to connect to it. You need to install the card and make sure it works in your device, then connect into the router and it should work fine.
Oct 27, 2008 | NEC MobilePro 900 Handheld
Can't connect home comp to laptop
how many wireless computers do you have?
is it a dekstop or laptop?
if desktop have you installed a wireless adapter? if laptop, is it using a built-in wireless adapter, have you enabled the wireless adapter or have you installed a wireless adapter?
please make sure first that the wireless adapters are installed properly or enabled on your computers, if everythings OK.
access the setup page of your router and change the wireless settings of it.
how to access the ui
- open the internet explorer
- on the address bar type in 192.168.1.1 hit enter
- enter admin under password, leave it empty for the username and click ok
- click the wireless tab
- set the wireless mode to mix, change the wireless network name or ssid with any preferred name you want to use, make sure to enabled the ssid broadcast and then click save settings.
- after that, under wireless tab, there are sub tabs, click wireless security
- set wireless security to WPA-PERSONAL, and under passphrase, enter your desired password for wireless connection, take note of it and please be reminded that its case sensitive.
- click save settings.
for your wireless computers, if adapters enabled and working fine, on the system tray you should have an icon for the wireless connection, doubles click on it and it will pop for the wireless connection window wherein you can see the name that you set on your router, all you have to do is select the name click on connect and it should ask you enter a password, enter the passphrase you set on the router and click connect. then check if you can go online, if yes do the same thing with other computers.
Have a great day ahead.
Sep 28, 2008 | Linksys WRT160N Wireless Router
I'm having problems going wireless
What process have you followed to try to connect to the network and access the Internet? Where does this process fail?
Apr 13, 2008 | Belkin (F5D7230-4) Router (587009)
I have purchased a Belkin Wireless G Router for a cable modem. I have installed however i am unable to see the wireless network. What have i done wrong ??
Hello experts....
My problem is not being able to work wirelessly with my laptop. My answers to your questions are underlined(I've used your questions to someone elses problem)
One possible issue is your router's wireless radio is not enabled- the light on the router is lite on the symbol for wireless
or the wireless radio is not enabled on the computer you are attempting to connect to the router with - there is a switch on the front of this machine which is switched to wireless.
There are many other possibilities as well. That is why we need you to carefully answer EACH ONE of the following questions.
(01) Which of the following is your router?
-->> F5D7230-4 (Wireless G Router)
(03) Are ANY of the computers connected to your Belkin router able to access the Internet?
YES
(04) If there are other computers connected to the router that are able to access the Internet, how are they connected? (in each case, please)
only this machine is connected but it is by....
(b) wired (using an Ethernet patch cable connected between the router and the computer)
(05) What is the manufacturer and model number of the computer you are attempting to access the Internet via the router on?
HP Pavilion dv2500
(06) What operating system is installed on the computer you are attempting to access the Internet via the router on?
This machine is operating on Vista but the internet access I have is with talktalk
(07) Have you ever successfully connected (wirelessly) to the Internet from the computer you are attempting to wirelessly access the Internet through your Belkin router on?
NO
I hope you don't mind me using your questions to someone else, I thought you might be able to figure out what I'm doing wrong. I am connected to the internet but don't seem to be able to work wirelessly. Lorraine
Apr 09, 2008 | Belkin (F5D7230-4) Router (587009)
Toshiba Satellite A305-S6845 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
