Question about Hoover F7431-900 SteamVac Vacuum
Brushes not working
Tried taking the bottom part off but couldnt get it off...how do i take it off???
  • 1 more comment
  • Anonymous Nov 13, 2007
    grrrrrrrr it like my brushes are stuck... i am going crazy
    F7431-900
  • Anonymous Dec 10, 2007
    I have the same problem. I have totally dismantle the turbine inside that make the brush work to find out that there is a little gear shaft with 2 little bearing that were totally jammed. I've tried to clean them and I was able to make them rotate again but after putting everything back together I work only for about 10 min. Hoove doesn't seem to sell those part separatly anywhere. so if you found a site let me know.
  • Anonymous Dec 28, 2007
    Sometimes the brushes turn, sometimes they don't. How are you supposed to clean the brushes? Does the clear plastic part that holds the brushes come apart?
My filter was fine, but after disassembling the front end of the unit, and taking apart the turbine/gearbox for the brushes, I found the bushings for the main turbine to be severely corroded. I just cleaned eveything up and ran some scotchbright through the bushing, and now it works. Talk about planned obsolescence.
Posted on Dec 10, 2007
  • 625 Answers
Go to thehooverstore and do a search for your machine. they have exploded diagrams for most of hoover machines
Posted on Sep 22, 2007
SOURCE:
Hi, I tried to register my vacuum online and couldnt. Need help . Thank you
sadly we can not do it for you , even if we had the make . go to the MFG's website .
Nov 25, 2016 | Vacuums
My brand new dyson dc33 vacuum ($399.00) is making an annoying sound when applied using a carpet setting. This only occurs on my thinner carpets, not on my thicker carpets. Do I have to inspect the...
If there are no obstructions and it still makes the grinding noise here is something to try. When you take the bottom plate off which is real easy to do (3 plastic screws turn 1/4 turn with a coin) there is also on the bottom of the vacuum a rubber seal. This is located just above where the screws are inserted. Take a butter knife and remove this seal...it is very thin and runs the width of the bottom of your vacuum. Put plate back on and try vacuuming again..problem should be solved. The suction on the machine is tremendous...with the seal in place the vacuum literally sucks itself down on the carpet causing the brush to stop spinning. This wwill not hurt your vacuum in any way. Hope this helped.
Reply
Jan 05, 2011 | Vacuums
Got pipe out - can't get it back in
The pipe should have a plastic holder at the bottom of the hose, providing its still in tact.
If it is then do the following:
1 take the wand off the hose so the hose is bendy
2 the plastic holder at the bottom of the hose should slide in to the main body and clip in if you are still having problems take off the inspection valve where the hose fits in and then try again.
If the plastic on the hose is broken, then buy new hose.
Sep 18, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I recently cleaned all the filters in my Bissell powerforce, now instead of suction I get all blown back instead.
take all the filters out put the dirt cup back in then try it again.3 filters 1 on the bottom of the dirt cup and one above the dirt cup and one in front at the bottom behind the little door.if thats not it at the bottom on the right side you will see a clear hose thats your intake hose,one screw holds it on,take it out and bend a coat hanger so the tip is rounded ,then work it down into the clear hose ,you should be able to push the clog out through the bottom
Apr 28, 2009 | Bissell 6594 PowerForce Bagless Upright...
I have no suction at all what do I do?
take all of your filters out then turn it on and see if you have suction.if so the filters are dirty.talke your hose off and blow throughit if you can't the hose is blocked up.also go to the intake hose which is located at the bottom ,it should be kind of clear.it comes up the backside at the bottom.theres a connector it is attached to that is held in be 1 or 2 screws take them out and you should be able to pull it away from the back a little ,take a coat hanger and bend the tip so it is round then work it down into the intake hose and see if you can push the clog out though the bottom .those are the things that will keep it from having suction.try the filters first,then the hose,then the intake hose.good luck
Apr 13, 2009 | Vacuums
Fitting internal bin catch on dco7
Yea I can definitely help you. On the tope of the cyclone there are three screws that will allow you to take off the top off the cyclone. You should see a long black rod going down the middle of the cylcone. It is difficult and you may have to detach it from the top i cant remember as usually i just replace the whole thing and only done that 3 times. You take a flash light and you can see where the rod goes in and just push it down and it should pop open. ill check back on monday to see if you replied or need more help.
Dec 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson upright
hi this is an expensive repair and would probably be cheaper to buy new one the problem you have is with the motor bearings seizing its expensive to repair because when dyson made thes vacs they were made so you need special tool to take them apart so replacing the motor would require calling a dyson bloke out as i found out with mine when my switch failed i tried removing and replacing myself but when the bloke came out he used a thin piece of metal down the side of switch to press button to release switch after i payed him to do this 2 months later i got your problem and called them back they tryed selling me new one as the repair was 50 quid more than a new vac.
Hope this is some help sorry i couldnt give you good news
Jan 08, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Water leaking from bottom and hose not connected
The hose just pushes on. You will have to take the top cover off to rehook up the hoses. There are scres on the bottom, then where the dirty water tank sits, there tabs that you have to unhook, then the cover will come off. Note: the filter inside the ditry water tank, leave a gap at the top to the filter. If you push the filter all the way up, it won't spray or suck up.
Jan 05, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Vacuums Logo
111 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
