Question about Kenwood KD-291RC Turntable
My KD-291RC has power but my turntable wont turn. I touch the needle and I can hear its on and when I move the arm towards the record or set it on it it will not turn. Help?
  • rentsu Apr 16, 2009
    My belt fell off -- any idea or better yet pictures to show how to put it back on?
    Genius:
  • 1,175 Answers
    Problem Solver:
  • 18 Answers
Your turntable is belt-driven, it's likely that the belt just fell off. The belt lives under the turntable. On my turntable (a totally different model) the turntable lifts off.
Posted on Apr 13, 2009
I have a Kenwood KD12R turntable. How do I set the arm and needle. I have a weight with an adjustable dial at the end of the arm and a separate anti skating dial on the base of the turntable? Regards -...
The weight should be set to the position recomended by the cartridge maker. Typically 1.5 to 2.5. If you don't know the makers setting, set it at 1.5 and work upwards. The stylus should track nicely in the record groove and not jump. But not too heavy as to cause rumble in the sound. Set the skate control low and again try the record out, if the stylus starts to skate accross the record increase the force. It's a case of experimentation with no fixed rules on these settings. Some records might need adjusments afterwards.
Feb 15, 2011 | Kenwood KD-291RC Turntable
Needle skips
A needle is a precision part. Look to see if the needle has a conical point descending from the cartridge needle carrier. If not, replace the needle.
*Always protect the needle while you adjust things!
Pressure is essential for the needle to track. Turn the weight down until the needle just floats above the record. Zero the weight by turning just the weight indicator, not the weight. Now turn the weight to add 1.2 to 1.5 grams. (Always use the manufacturer's recommended weight if different!)
A level surface is important. Make sure the turntable is level.
Test the arm bearings:
Adjust the weight until the arm floats. With a feather, gently push the arm towards the center. Now gently push it back. The arm should move smoothly with no hesitation and easily. Reset the weight to 1.5 grams or less.
If your cabinet is moving when you walk around, the records will skip. Find a different place for the turntable or don't walk around. In severe cases, raise the weight to 1.75 to 2 grams, but this wears the needle fast an can cause distortion.
Mar 22, 2010 | ION Audio Vinyl Recording Turntable
I,m trying to replace my kenwood KD 47F turntable V68 catridge & N68 needle stylus with an Audio technica set due to non availibility of N68 stylus in my home country- singapore. Audio technica...
hi, any cartridge are posible in every turntable as long the needle is available...the wiring is the same the position ,, but the only thing that im not sure is the sensetivity of the needle ..some are not good but some is compatible..u
Jun 30, 2009 | Kenwood KD-291RC Turntable
Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
Mar 10, 2009 | Technics SL-BD22 Turntable
When i backspin the arm is forcing itself off the vinyl
IMO the problem can be solved in 2 ways, either move the counterweight on the back of the arm towards the turning point of the arm ( by just adjusting it 10 - 20 % of an whole spin you can adjust a lot), or buy an other needle which is heavier then this one...
Jan 29, 2009 | Technics SL-1210 Turntable
Turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
Jan 24, 2009 | Kenwood KD-291RC Turntable
Turn table on hifi does not turn what is the problem
turntables are belt driven..... the belt could have snapped or come off.......
Jan 17, 2009 | Kenwood KD-291RC Turntable
Difficulty balancing the tone arm on kd-1033 turntable.
A new stylus should not change the tone arm balance setting if it is the correct stylus.
Does your arm have a sliding balance weight at the rear of the arm? If so you can slide this slightly towards the cartridge to regain the correct playing weight.
I would suggest you get a repair shop to do this for you, or you could finish up damaging your records.
Jan 01, 2009 | Kenwood KD-291RC Turntable
KD-67F fully automatic turntable--servo mechanism has suddenly stopped
I wish to help but I "NEED MORE INPUT". mgfr, model, type,ect.
Sep 08, 2008 | Kenwood KD-291RC Turntable
Kenwood KD-76F Turntable Problem
There is an adjustment in the postion sensor switch of the tone arm located under the support housing. BE VERY CAREFULL in lifting or fliping the unit over. If you can lock the arm in postion please do so before proceding. There may be some dust in a optical sensor or the postion sensor switch may be loose and just need repostioning to the correct location. If your not technicaly inclinded I suggest a strong blast of air in this area may solve your dilemma, possibilty hair dryer(NO HEAT), air compressor(max 20 to 40psi) or a good seat of lungs.
Jul 10, 2008 | Kenwood KD-291RC Turntable
Kenwood KD-291RC Turntable Logo
628 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
