Question about AT&T Blackberry Curve 8300 Smartphone
Cant recharge my BBcurve
My curve fully died for about 2 days. When i tried to hook up a charger - nothing happens. Wont turn on - tired to remove battery. No luck. Any ideas
    Brigadier General:
  • 7,752 Answers
You could take it to a mobile reapir shiop and have them try to revive it for you or you can try the following steps below.
When your device fails to start, it show one of these symptoms:
1. Totally dead.
2. Trying to restart, LED activity only.
3. Failed to start, a white screen with an error message.
__________________________________________________ ________
1. Physical damage, water is the worst enemy of delicate electronic device. Try drying it with a desiccant and replacing the battery. If there is no activity, you can still try the last ditch technique, nothing to loose anyway.
2. Your device is not able to start, something has gone wrong and the OS is corrupt.
3. Geeks call this an "Uncaught exception error". That is a polite way of saying, the last thread has terminated, the OS has halted because it is corrupt.
In many cases, the Application Loader can be used from Desktop Manager or Windows,
If that fails to connect, there is one final solution. Go Old Skool ...
The good news, starting from scratch, you will be back in service in a couple of hours. cant recharge my BBcurve - biggrin.gif
2. You need to install a BlackBerry OS file that is specific to your device. The original version, as supplied by the carrier, is the safe choice, but you can use any model specific version.
3. Once the OS has been installed, you have to prepare it for the device.
Select Start / Computer and select the Drive C: Icon.
Open Program Files / Common Files / Research in Motion / AppLoader.
Navigate to the bottom and delete the file Vendor.XML file.
4. You are now ready to restore your device. Verify that BlackBerry Desktop Manager is NOT running. Plug the device directly into the computer's USB port.
Posted on Feb 04, 2010
Battery died, recharged it now it wont turn over
Your battery is toast. It may read 12.6volts but does not store the power it needs start the car. Get a new battery.
Dec 27, 2017 | 2008 Hyundai Santa Fe
Included in my Ryobi printed instructions are the statements: 1-"Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode. 2-"To obtain the longest...
Any battery left in a charger is still hooked up to a circuit. Depending on the charger this can mean a slow discharge is possible. Ryobi's Maintenance Charge Mode means the charger will 'refresh' the battery at regular intervals, usually every 30 days. A battery's lifespan is determined by how many times it is discharged/recharged so to get 'the longest possible battery life' it is desirable to reduce the number of times a battery is recharged. One way is to use the battery until it is dead or near so another is to remove the battery from the charger when it's fully charged to reduce the number of times the charger refreshes the battery.
Dec 23, 2010 | Ryobi Multi-Volt Battery Charger
My Blackberry 8310 just "died"
The device is performing on low battery power and requiries full recharge possibly a couple hours. How to perform a device recharge
1. power off completely
2. connect to power source with cables provided, expecting to the last the duration of the full charge
3. a full recharge once the process is complete would display a message on the phone.
4. until then, do not unplug
Dec 03, 2010 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve wont turn on. it died then i took it home and went to charge it and the red light comes on for about 2 seconds then nothing happens and i cant turn it on
Does the phone come on while plugged in? To me it seems that the battery is dead. If you feel the battery is fine then you must visit the BB Service Center.
Aug 28, 2010 | RIM Blackberry Curve 8300
BB Curve 8900 cant turn on!!! Pls help
Try to Re-Charge your phone with electrical charger for 6 hr,
then try it
Jul 14, 2010 | RIM Computers & Internet
My Blackberry curve 8320 won't turn on it just has a battery icon with a red line through it on screen. The icon stays on with the backlight until the battery dies, A new battery was tried and problem...
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails, try another battery (a friends or one from your cellstore) to see if tat's the problem. If so, (a) retry step 2 but allow battery to FULLY drain then dry out again, (b) buy a new battery for $60 retail or (c) buy a new battery on ebay for a lot less.
4. Take in.
Jun 08, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Total power falure
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Sep 19, 2008 | Fuji FinePix S5000 Digital Camera
Wont turn on vivitar 5105s
Lack of use
the battery is completely flattened so will need a total recharge or has even died of neglect.
Get a new battery and use the thing.
Sep 01, 2008 | Vivitar Vivicam 5105s Digital Camera
Canon powershot g5 - battery charge
Take out the battery and put it back and than recharge again. Some times in case of G5 it happens that the camera battery is not properly charged and the indicator shows that its fully charged (i.e. Green light) In such cases battery need to be taken out and than put back again and recharged
Regards,
Zain
Dec 16, 2007 | Canon PowerShot G5 Digital Camera
GARMIN c550 will not turn on
There is an ISSUE with the DEAD ZUMO, however some of the are solved, and some need to be shipped back.
There are a couple of options.
1) remove the battery, keep power button pressed for a few minutes. install battery, try.
2) fully recharge the battery with the wall charger, try
3) With a fully charged battery, press and hold the + button and press the power button(hard reset).
4) hold thumb firmly on top left of touch screen and hold power button till it switches on(hard reset).
5) Try a different battery (fully charged)
6) Ship it to Garmin
Sep 08, 2007 | Garmin zumo 550 GPS Receiver
AT&T Blackberry Curve 8300 Smartphone Logo
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
