Question about Intel Desktop Board D845GLLY Motherboard
No output on Monitor
Last week I cleaned my cabinet and started my PC it started directly after switching ON the main supply but there was no display on the monitor, the Green light was blinking but the Red light was not blinking. It starts directly after I switch ON the main supply. After a few tryouts it suddenly started & functioned normally, then I shut it down & again started it but it gave me the same old problem, Green light blinking but no display on Monitor. My hard disk was aslo rotating. I am really confused as if what could be the problem please help.
I have an Intel Motherboard.
  • 3,267 Answers
Check if any of the pins of the Keyborad PS2 jack. Looks loke during cleaning a few vital parts may heve moved. Unseat the RAM sticks and after cleaning insert it firmly. Check all cable and wires for snug tight connections. You could try to clean ur power switch too bt aerasol spray, but the main is the keyboard. Recheck for bent pins and/or any stuck keys on the keyboard. If evrything is OK and the PC still behves the same, try replacing the power supply (SMPS) with a properly functional one & if it works, simply buy a new SMPS and install it....sodeep
Posted on Apr 13, 2009
My desktop computer will display anything when turned on, and the fan and hardrive both make a loud constant noise.
Maybe you need a larger power supply depending on if you might have added more hardware such as a graphics card, or an extra monitor to your system. This sometimes results in an inefficient supply of power, making your fan to your power supply work harder, thus making noise.
Nov 19, 2012 | Gateway Computers & Internet
Dell xps 420 won't power up
i gotta know 1st what is ur system configuration..is all ur system is getting power on..is there any sound coming out of the system..
assuming that the bios has not been flashed in a wrong way & u r a professional..
before u proceed to complex checkups..check the mains power supply- the fuse/switch/wirings/power cords/other associate circuits..
probably itz either minor case of loose ram/improper ground/cmos battery..
or major case of faulty or defective smps/cpu/main board short/display adapter or card/monitor
..plz do check the following as in order:..
1) in power on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..
2) if u hv a graphics card, replace with a standby or onboard and see..
3) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
4) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
5) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistace n many more..resulting an increase in heat..
6) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
7) the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..
the 'oscillator and error amplifier ic', or pwm switching regulator circuit..look for defective protector-transformer/resistance(esp 4.7k)/mosfet..
8) if itz not the smps, then it must b ur main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above 1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)....
always better to seek advise from ur system admin/vendor....
Nov 12, 2009 | Dell XPS 420 (dxcwqc1_4) Intel Core2 Q6600...
My pc doesn't work
Nov 12, 2009 | HP Computers & Internet
Monitor will not power up. was working fine last night, and now is not working at all. Just black screen.
very incomplete thread..i gotta know 1st what is ur system configuration..is all ur system is getting power on..is there any light on cabinet glowing (the power n hdd)..is there is power light coming on ur monitor..is there any sound coming out of the system..or the set is dead..??..
considering that the system gets on but u get no display and assuming that the bios has not been flashed in a wrong way & u r a professional..
however, before u proceed to complex checkups..check the mains power supply- the fuse/switch/wirings/power cords/other associate circuits..
Nov 12, 2009 | LG Flatron 775FT 17" CRT Monitor
Monitor LED blinking--no display--How to open the cabinet
check the vga cable if it is attached properly to your computer. Make sure that the VGA cable is connected to the Video Card that you are using.
check in the manual if you need to install the driver first.
also check if the monitor will work to another computer. If not, Then you can check the VGA Cable and replace a new one.
Hope this will help you out .. =)
Aug 24, 2009 | LG Studioworks 700S 17" CRT Monitor
Hello, It depends on how you cleaned the computer. If you removed the card from the slot then it may not be reseated back into proper alignment. If it is onboard video then there may still be a bit of dirt across one of the chip contacts. The other option would be when you plugged the monitor cable back in, you may have accidently bent a pin on the plug. Make sure that all power to the computer is off for several minutes before disconecting the cable and then look at the cable end to see if one of the pins got bent. Carefully straighten it with fine needle nose pliers then carefully plug it back in. If this doesn't work then you may have created static electricity and blew out the video system. Hope this helps, RAC
Apr 13, 2009 | AMD (90613) PC Desktop
Sony Vaio Desktop Won't Start
hi
check your cmos cell, power cable,smps,main power supply of home,
check that *********** bord dony=t touch the cabinet.
check your bord circuit hitting event.
remove all pci card clear dust from it.
reattach all cards and connection of pc.
clean your processor case.
i think your pro is solved
Mar 25, 2008 | Computers & Internet
BenQ FP51g LCD monitor
Dear Friend:
There is a Switch transistor to power on -off the hi voltaje for lights. Check 15V from power source go to this transistor colector, Using soldering Iron, make a juntion between colector and emiter, to short 15V to Hi voltaje power. I´m fixing 10 monitor the same trouble. I will remove a liter transistor.
Late I will post here the driver transistor number, and the replace number transistor I will use.
Pictures , etc. Best Regard
Feb 16, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Mackee PPM808M 1200 How to set the equalizer
Each channel strip has its own 3 band EQ with knobs that effect the hi, mid, and low.
The mid is centered at 2.5kHz and gives you 12dB of boost or cut in either direction, the high gives you 15dB of boost or cut from 12kHz and up, while the low gives you 15dB of boost or cut at 80kHz and below. At their mid positions these knobs are flat (no cut or boost).
The PPM808M also has two 9 band graphic EQs in the Master Output Section on the front panel, Monitor EQ and Main EQ. These two EQs are the last thing in the chain before the signal leaves the mixer on either of these line outs (monitor line out, or mixer line out).
The 'Monitor EQ' effects output to the monitor speakers on stage (and power amplifier if the 'Power Amp Routing' switch is pushed in).
The 'Main EQ' effects the signal to the main speakers (or the mixer line out).
Each of these 'Master Output' EQs has a Rumble Reduction button which when pressed in engages a low-cut filter which rolls off frequencies below 75Hz and is designed to prevent 'stage rumble' from things like footsteps on the stage being picked up by stage mics. These filters are separate from the graphic EQs and the Main Rumble Reduction switch effects only mono channels 1-6 (not stereo channels 7&8). It also has no effect on the EFX to MAIN or the TAPE IN. The Monitor Rumble Reduction switch however does effect the EFX to MON signal.
Dec 31, 2007 | Audio Players & Recorders
MONITOR REPAIR HELP
The mains switch is a weak link on these, check this first. Also 1 of 2 33K 2W startup resistors in PSU goes o/c, check with DVM or if you have very high volts on main primary res cap this usually indicates a 33K has gone - change both. I've also had a small TO92 transistor hanging off the UC3842 failing causing no startup. A s/c HOT normally causes a blinking LED. note that AC cap IS charged, DISCHARGE BEFORE WORKING ON IT! Did you check for shorts in the secondary side of the p/s, horiz output? If there are none , look for the switching regulator. Check the support components. I've seen these with open solder connections on the coils in the PS due to that abominable glue they use...you'll see signs of burning/arcing on the inside of the cabinet, too. Good luck
Apr 09, 2006 | AcerView 78ie 17" CRT Monitor
Intel Desktop Board D845GLLY Motherboard Logo
81 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
