Question about IBM ThinkPad R40 2722 Notebook
Computer does`t recognize psp
Well when i connect my psp via usb cable my computer it does`t recognize it
  • anis710 May 25, 2009
    Hi there & good day,
    I have the same problem.
    When ever I plug in the usb as I normally do (when it is ok), now my pc only display some folders I cant understand such as: data, font, vsh, dic, kd .. wonder what all these means. Where did all those familiar folders (ISO, VIDEOS etc etc) goes to.
    Appreciate if someone can assist.
    Thank you
    Anis@Malaysia
Try to use another usb connector cable with your psp. It has some lost connection...maybe the data connector is loose. USB has 4 pin(pc side) the voltage supply for power and the data pin..just try.. if it doesnt work...checked if your in admin account because some hardware cant be installed if your not the admin of the pc.
Posted on May 20, 2009
My computer dosent run my psp program with a usb cable so i can sync anything in, how do i make it recognize my psp
When you connect your PSP to your computer, it won't recognize the PSP immediately. After you connect the PSP, you will have to navigate to USB Mode on the XMB. Your computer will recognize your PSP as a mass storage device.
Good Luck.
Mar 18, 2011 | Sony PlayStation Portable (PSP) Console
Dont kno how to put music and videos in my psp
Putting music or videos on the PSP is a fairly simple and straightforward process.
What you'll need:
  • a mini USB to USB cable (to connect the PSP to the computer)
  • a memory stick (to store your music and videos)
Instructions:
  1. Put the memory stick in the PSP.
  2. Connect the PSP with the mini USB to USB cable to the computer
  3. On the PSP, go to the settings menu and select "USB Connection."
  4. Your computer should recognize that a device has been connected to it, open up the device (your PSP) inside a file viewer, such as windows explorer. There should be a few folders here one named Video and one named Music.
  5. Add the music and video files to these folders, and press O(circle) on the PSP to end the USB Connection.
  6. If all has gone right, and the files are the correct formats, you should be able to enjoy your music and videos on your PSP.
Mar 13, 2011 | Sony PlayStation Portable (PSP) Console
Laptop will not recognize psp
Hi lawolf77,
If your laptop wont recognize your PSP there might be a connection problem between the two. So you need to check what's causing the problem. There are several ways to check if PSP and your computer are properly connected, one good example is by checking the connectors and the device setting.
If you want to check some configuration on how to connect your PSP to your PC please try to follow these steps:
1. First, connect your PSP to your PC using a usb cable.
- please make sure both ends are properly intact.
2. Using the left and right directional button find "Setting", then scroll down or up to find the "USB CONNECTION".
3. USB CONNECTION will display after you pressed the x button.
4. Please wait until computer detects the USB connection. After that it will show the drive for your PSP. usually F: or G:
5. Click on your PSP drive letter.
6. Now you can determine if your PC recognizes the PSP, just access the root folder and try to put some files on it.
Hope it helps.
Thank you for using FixYa.
Feb 08, 2011 | Sony PlayStation Portable (PSP) Console
My laptop wont recognize my psp at all!
Normally when you connect usb from your computer it will automatically detect you psp.
The otherway is connect your psp using usb cable to your computer and then go to setting and choose USB mode. it will automatically view the folder of your psp.
Nov 27, 2010 | Sony PlayStation Portable (PSP) Console
HOW TO ADD MUSIC TO PSP
Adding music is rather simple. First, you have to connect your PSP to your PC via a USB Cable. Once it's plugged in, click on USB Connection on the PSP Menu. Your computer will recognize your PSP and ask what you want to do with it.
Open up your PSP folder and open the folder called "MUSIC". Open the folder on your computer that has the music you want to add. Click and drag the files over to the PSP. Once the transfer is complete, disconnect your PSP and goto the Music tab on your menu and select "Memory Stick''. All the music you uploaded should be accessible.
Jun 20, 2010 | Sony PSP-3000 Silver Console
My pc does not read my psp, how do i fix it.? do i need to install a psp driver.? where do i find such driver for free.?
Hook up your Sony PSP to your computer via a USB cable. Turn on the PSP and put it in "USB CONNECT " mode (it should display the words "USB CONNECT" on the PSP display during the entire time you're transferring files, and plug it in if you don't have a fully charged battery).
Apr 02, 2010 | Sony PlayStation Portable (PSP) Slim...
How can i download music on to a psp?
1. Connect your PSP to your PC via the USB cable.
2. On your PSP's menu, go all the way left into the Settings menu.
3. Scroll up to the USB Connection menu and click X
4. Your PC should recognize your PSP. You can then access your PSP's installed memory stick just as you would any other drive. Let's say, for example, your PSP is now drive G:\ on your Computer. On your PC, click into drive G:
5. Click into the PSP Folder. If this folder does not exist, you can create it by clicking File --> New --> Folder
6. Click into the MUSIC Folder. If this folder does not exist, you can create it by clicking File --> New --> Folder
Oct 28, 2009 | Video Game Consoles & Games
Computer wont recognize psp?
try a different computer or different usb cable.
Jan 10, 2009 | Sony PlayStation Portable (PSP) Console
USB fails to recognize my PSP
what are you trying to do? connect it to the computer?
if so try a new usb cable. if that dont work look inside the female ubs jack on the psp make sure all the pins are there. see if it wiggles any.
you might need to replace the ubs port on your psp. which is a soldering job.
contact us for professional help. United.Gamez@Gmail.com
May 24, 2008 | Sony PlayStation Portable (PSP) Console
Psp
* Make sure you have inserted a memory stick, and enable the usb connection via settings=>usb connection
* Check the usb cable, or simply find another one to try if it works.
* If there is a memory stick inside the psp and the psp can recognize it, then you most probably have a problem with your cable or usb port.
* if there is a memory stick inside the psp and the psp cannot recognize it, as well as the computer, then you are most likely to have a failure with your memory card.
There are too many possibilities, maybe you can give me details straightaway, so more people can help you.
Dec 26, 2007 | Sony PlayStation Portable (PSP) Console
IBM ThinkPad R40 2722 Notebook Logo
169 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
