Question about Sony Handycam DCR-TRV140 Digital Camcorder
Sonytvr140 digital 8
When trying to use vcr or camera mode code appears c:31:22. what does this mean and how do I fix it?
  • Anonymous Jul 06, 2008
    "Have the capstan motor replaced"!?
    Apart from the fact that I have no idea what a capstan motor is, I am in a back-of-the-woods part of the south of Spain. Around here, plumbing is regarded as high-tech. I can just imagine taking my camera to the nearest electrical fix-it shop (if there is one it's probably 50 miles away) and asking them to replace the capstan motor (in my very bad Spanish). Might as well be telling them my particle accelerator is running slow.
    Problem Solver:
  • 36 Answers
Does the error appear when tape is inserted? Eject the mechadeck, take out the tape, try blowing hot air using hair blower for a short while, just to dry if there is any dew inside, if still the same, have the capstan motor replaced, thanks
Posted on Sep 14, 2007
I need to download the drivers to my computer so I can transfer the video's to my computer. Where can I download them, I tried Sony,but they don't work.
You should not need additional drivers. Digital-8 cameras will have a firewire port on them. Connect with a firewire cable to the computer and open Windows Movie Maker for PCs or iMovie for Macs. Using another movie editing application if you have one will also work.
Treat the Digital-8 camera as a non-controllable device, that means you will most likely have to start the camera manually to capture. Make sure the camera is in VCR/playback mode not record.
May 15, 2011 | Sony Handycam DCR-TRV480 Digital Camcorder
I wish to have the code number for my V7 to use the skymaster romote
In case you can't find your brand at code number list, please try with quick search.
1) Set the device that you want to control at POWER ON or VCR at POWER ON with tape loaded
2) Press and hold both, [SET] and aquivalent device key, until LED light shows
up, then release both keys.
3) Press [SET] again, the LED is blinking now. Start to page by pressing [POWER]
and check for any action such as POWER OFF or VCR start to play.
4) If your device has action then check other keys such as [CH +/-] or [VOL
+/-], if negative continue pressing [POWER] to search another code page.
5) While during paging a code was missed out you may press [SET] to change
the Forward / Backward direction of searching.
6) IF any key is not pressed within 30 seconds at search mode then unit will
quit and return to STAND-BY mode.
Check the code number that has called up to the keypad by pressing [SET]
together with (one after the other) the first three keypad digits:
For example, if is blinking 8 times, 1st digit of code number is [8],
blinking twice means 2nd digit is [2], blinking twice means 3rd digit is
[2], therefore, this code number is [822].
Power source: 2 x UM3 "AAA size" (Batteries located behind cover slide
Vipin Kakkar
Jan 14, 2011 | Videoseven L17PS 17" LCD Monitor
My Sony Handycam DCR-TRV480 needs to be put in VCR Mode...
our camera is similar to yours, the switch you switch it on with also goes the other way, this is the vcr mode
Nov 17, 2008 | Sony Handycam DCR-TRV480 Digital Camcorder
Dark screen on my video-camera Canon MV700i
I have the same problem, it appears that this camera is one of many cameras that have problems with the CCD (image sensor) have a look at this site for more info
I hadn't used mine for about 9 months, when I went to use it the screen was black with a bit of flicker. Canon are still fixing them if you're from the UK have a peep here -
Hope that helps
Jan 01, 2008 | Canon MV700i Mini DV Digital Camcorder
My VCR is in Safe Mode
Hello Mark352, What model of VCR do you have? is it a GE In the mean time try this: Unplug it from the wall for about a minute and then plug it in again. If this does not work, hold the VCR button down for 5-8 seconds this works on some units. Let me know if this works for you. Thank you,
Aug 26, 2007 | GE VG4270 VCR
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Focusing distance in macro mode
The Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
On a D-575 camera, The Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Aug 31, 2005 | Olympus Camedia D-395 Digital Camera
Sony Handycam DCR-TRV140 Digital Camcorder Logo
113 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
