Question about AMD (90613) PC Desktop
No output on Monitor
Last week I cleaned my cabinet, then switched ON my PC it started but there was no display on the Monitor, the Green Light was blinking giving an indication that it has started but the Red light was not blinking. After a few try outs my PC suddenly started but then again when I Shut down the PC & again started it gave me the same problem. Now my PC directly starts after switching on the Main Supply but there is no display, my hard disk is also functioning. I am confused as of what could be the problem please help.
  • AMD Master
  • 5,660 Answers
You cleaned the computer case out with a can of compressed air for computers? You had the computer unplugged from the surge protector? You touched the metal frame of the open computer case, to relieve your body of static electricity?
IF so, then I suggest the power supply is bad. It is weak. There is just enough power to light lights, and spin fans, but not enough to turn the processor on.
At first, the power supply was just strong enough to turn the processor on, after you repeatedly pushed the Power On button. (Sometimes unplugging it from the surge protector, waiting a few seconds, then plugging it back in and pushing the Power On button, will get it to start)
Now it is so weak, that it just lights, lights, and spins fans. The harddrive is just sitting there spinning.
ALL the lights use about 1 Watt of power. EACH fan uses 2 to 3 Watts. (Yes, even the power supply fan will spin) The harddrive just sitting there spinning the platters inside, uses about 5 watts.
A processor uses 55 to 125 Watts! Depends on the make and model.
Since the processor isn't running, the harddrive just sits there and spins. Makes it sound like it's running.
NO processor, there is nothing to find the Boot record on the harddrive. Nothing makes the read/write heads on the arms inside the harddrive, go across the platters, and read the info.
No Operating System is found. (WinXP is an example of an O/S)
No computer running, there is no signal to the monitor. The monitor is blank.
Solution? Replace the power supply.
I'm a tech. A computer power supply is about 70 percent of computer failure. Power supply's have a 'Life Cycle', just like all the computer haqrdware components.
The 'weak link' of a computer power supply, are the Electrolytic Capacitors inside it. When these go bad, they develop a gas inside. (Hydrogen gas)
The gas pushes up on a seal, and Electrolytic paste oozes out.
So much paste loss, and the capacitors operate at a weakened state. Too much paste loss, and they fail.
Weak Electrolytic Capacitors, make weak voltage power rails inside a computer power supply.
Here is one reason for Electrolytic Capacitor failure.
Capacitor Plague,
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 13, 2009
    Novelist:
  • 90 Answers
Hello, It depends on how you cleaned the computer. If you removed the card from the slot then it may not be reseated back into proper alignment. If it is onboard video then there may still be a bit of dirt across one of the chip contacts. The other option would be when you plugged the monitor cable back in, you may have accidently bent a pin on the plug. Make sure that all power to the computer is off for several minutes before disconecting the cable and then look at the cable end to see if one of the pins got bent. Carefully straighten it with fine needle nose pliers then carefully plug it back in. If this doesn't work then you may have created static electricity and blew out the video system. Hope this helps, RAC
Display not working but system functioning
tried with other monitor just to ensure if the problem is only with in the monitor. if the same problem, the cause it could be the inverter board for screen back light which has component being shorted.
Aug 15, 2012 | Samsung SyncMaster 713N 17" LCD Monitor
Picture on monitor comes on then goes off in a few seconds after start up but green light on monitor stays on
For that when you power up the computer pressF8 key 5 to 6 times then you can see safe mode and other menu.
enter in "Enable vga mode" then go to display property and change screen resolution to 1024*768 .
But if you are not able to see any display then open cpu cabinet and reattach the RAM memory then pull cmos cell from motherboard for 10 minutes.
Reattach PCI card or cga card if any.
Make sure motherboard is not ground with cabinet.
Also reconnect both connection to harddrive.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 12, 2010 | Compaq Presario 5000 PC Desktop
My monitor has no display at all
very incomplete thread..i gotta know 1st what is ur system configuration..is all ur system is getting power on..is there any light on cabinet glowing (the power n hdd)..is there is power light coming on ur monitor..is there any sound coming out of the system..or the set is dead..??..
considering that the system gets on but u get no display and assuming that the bios has not been flashed in a wrong way..
probably itz either minor case of loose ram/improper ground/cmos battery..
or major case of faulty or defective smps/cpu/main board short/display adapter or card/monitor
..plz do check the following as in order:..
1) in power on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..
2) if u hv a graphics card, replace with a standby or onboard and see..
3) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
4) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
5) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistace n many more..resulting an increase in heat..
6) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
7) the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..
the 'oscillator and error amplifier ic', or pwm switching regulator circuit..look for defective protector-transformer/resistance(esp 4.7k)/mosfet..
8) if itz not the smps, then it must b ur main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above 1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)....
always better to seek advise from ur system admin/vendor....
Nov 12, 2009 | Dell Dimension 4600 PC Desktop
NO Display
time to replace the monitor, u fried the board, been there done that
Jun 20, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
Check if any of the pins of the Keyborad PS2 jack. Looks loke during cleaning a few vital parts may heve moved. Unseat the RAM sticks and after cleaning insert it firmly. Check all cable and wires for snug tight connections. You could try to clean ur power switch too bt aerasol spray, but the main is the keyboard. Recheck for bent pins and/or any stuck keys on the keyboard. If evrything is OK and the PC still behves the same, try replacing the power supply (SMPS) with a properly functional one & if it works, simply buy a new SMPS and install it....sodeep
Apr 13, 2009 | Intel Desktop Board D845GLLY Motherboard
Red Green stripes on IBM Thnikpad T60p tft monitor
Those are dead pixels if you want to get rid of them you will probably need to replace the monitor. They will probably charge you an arm and a leg to replace it so you might get a second quote from Computer repair shop.
Jan 31, 2009 | IBM Lenovo ThinkPad T60p Notebook
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
No display on monitor only orange light
Normally the orange light should turn green when everything is a go. Often the problem of orange light is not really the monitor but the PC. There is not video output from the video card and the monitor in sensing this assumes that the cable is unplug and thus does not switch on (green).
The sure way of determining which is at fault is to try and use a different monitor to your PC (as well as the cable). Should problem persist, then it is the PC that would need to be checked. On the other hand, if the PC works with another monitor, then you have just verified that indeed the monitor is defective.
Should you have verified that it is the PC, suspect would either be the video card and/or the memory sticks. In some instances cleaning with a pencil eraser the little gold pins of either the video card and/or the memory sticks helps.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 26, 2008 | AOC LM 720 17" Flat Panel LCD Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
AMD (90613) PC Desktop Logo
144 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
