Question about Optics
Having Trouble Dialing in New Air Rifle Scope
Just installed a new scope on my Ruger Airhawk .177.It is a Hammer's
3-9x power.The issue is that when sighting in at 7.5 yards mygroups are 1.5 inches below the desired point of impact.I have the left,and right adjustment,or windage dialed in perfectly.I put 5 pellets into an area the size of a pencil eraser. The height dialis the problem.It's maxed out,so I can't raise the point of impact any further to hit my target dead on.I haveheard that springer,break barrel airguns usually have a slight downward angle of thebarrel,which is common from what I understand.The scope that came withthe rifle I had no issues with.I even tried installing the mounts from my original scope to see if that would solve the issue.No deal!if it makes a difference the original scope had a two piece scope rings,and the new one is a one piece mount.I just wanted to upgrade the stock scope..How can I correct this problem???
I had the same problem.. shimmed the rear ring by folding some aluminum foil and lining the whole bottom part of the ring. I think after all was said and done, the aluminum was about 12 slices thick. This gave me a little bit of elevation to play with.
Posted on Jun 29, 2009
I fixed the problem by shimming the rear scope ring.Now it's dead on! Hit a nickle at 60ft.!
Posted on Apr 13, 2009
Instructions to mount scope
PDF]OWNER'S MANUAL - Crosman
www.crosman.com/pdf/manuals/M4-177-515.pdf
Translate this page There are two different rear sight options for the M4-177 depending on which model you purchase.) Option 1- ... the airgun in any way inconsistent with this manual may make your ... Adjust the rings on your scope to match the measurements of the top rail. ... Toattach the sling at both ends push the sewn webbing loop end.
Crosman M4-177 Multi-pump .177 Pellet Air Rifle Table Top ...
? 24:29
https://www.youtube.com/watch?v=s_0grKCOmX0
May 18, 2012 - Uploaded by Replica Airguns
ReplicaAirguns.com - Crosman M4-177 Pellet-BB Multi-pump Air Rifle ... -Single shot - bolt action with manual advance magazine.... I particularly like the removable iron sights and full rail formounting a scope or red dot sight.
Crosman M4-177: Installing and Adjusting the Sights ...
? 8:38
https://www.youtube.com/watch?v=x8XKOmb41QA
Aug 28, 2012 - Uploaded by Crosman
A detailed look at installing and adjusting the sights for the M4-177 and sighting ... Crosman MK-177 Pellet-BB Multi-pump Air Rifle Table Top ...
Crosman M4-177 shooting rev
Dec 20, 2015 | Crosman M4-177 Air Rifle
How to repair a ruger air hawk .177
well for starters, there is no firing pin, second, without major machinery, you can't fix a spring powered air rifle, any of them. It is impossible, major jigs and fixtures hold these things while the spring is removed and replaced. You might try crossman, they do a lot of repairs.
Jul 30, 2012 | Umarex Air Ruger Air Hawk Air Rifle .177...
Scope wont track tried to shoot a square test and shot atrapazoid wouldnt track correctly at all shooting on a ruger 7mm rem mag
some scope wont do a square shot test,,but dont worry to much about this,, just clamp the rifle down and zero your scope ,,you get it dead on the rifle needs to be clamped down and not hand held
Nov 19, 2010 | Nikon Buckmaster 3-9x50 Matte Nikoplex...
I bouht a ncstar scope mount I cant figeur out on how to mount it.
Is it for a plain jane mini-14 or a Ranch Rifle. the mount and mounting process is different.
May 31, 2010 | NcStar Scope Mount RUGER MINI14 / MINI30...
How many ft lb of torque for scope rings
A typical torque setting for scope bases (on a steel reciever) is 30 in/lbs. The rings (steel) need 15-20 in/lbs.
For a aluminum receiver and/or rings, 15-20 in lbs is about max. I use 10 in/lbs with blue Locktite for aluminum receivers and rings.
Apr 20, 2010 | Redfield Ring and Base Sets for Knight...
The magnification adjustment ring on my Gamo Whisper worked fine at first, then was stuck between 3X and 5X. Now it is free again but the scope is not focused on the 3X and 9X settings, but is clear on 5X...
I'm not familiar with the scope, is it an air rifle scope? One stroke type? If not, the backwards recoil of the air rifle is tough on a normal scope, they aren't made for that type of abuse. They work fine with a normal recoil. That is why they started making air rifle scopes. I'm sure that the internals of your scope are damaged somewhat, you can take off the eyepiece no problem, you might find something in there, loose screw, missing screw, you never know, don't get too carried away with the dis-assembly, you'll never get it back together. It sounds like the magnification ring is messing with the focus of the eyepiece. Might just need some oil. Hope this helps.
Feb 28, 2010 | Caliber Gamo USA Hunter Elite .177 Air...
Ruger 22 pistol, Serial number 20476. Year made and value?
For the information you require you will need to take it to a gunsmith, or contact Ruger themselves.
http://www.ruger.com/index.html?r=firearms
Feb 03, 2010 | Weaver Ruger Mini 14 Rifle Elevated Scope...
Scope for ruger 10/22 carbine
Google SWFA ......they sell about 20 different brands of riflescopes, with pix, desriptions and prices. It's a good source for info, even if you decide to buy one of the same scopes at Walmart. Check out the Bushnell Trophy, Nikon Prostaff, and Tasco scopes, in particular.
Also, there is a website I belong to, originally started just for the Ruger 10/22 owners/fans. You can visit it and join for free at - www.RimfireCentral.com
We have a great bunch of guys and gals there, who can help you with questions on ANY type rimfire rifle. I'm sure you will love this site.
Jan 21, 2009 | Optics
Optics Logo
733 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
