Question about Sanyo DS27510 27" TV
Im getting p!$$e{} off
The video and channel 3 words stayed on the tv I got it off once but it came back on I tried everything but it wont come off please help me.
  • 579 Answers
IS their a STATUS button? Press that. It should cycle off the CH03. ONe of the buttons will do this.
Posted on May 31, 2009
I dont have the remote and im trying to put on cable or channel 3 but the settings on the tv wont allow me to do that
go to cable input, go up one channel, if that won't work, scan for channels but make sure your cable box is on
Jan 15, 2015 | Sansui Televison & Video
Tv wont get channel signal
1- Have you tried a different input cable?
2- maybe try using the set top box tuner?
3- check the input setting on TV?
Good luck
Dec 11, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Im trying t0 program a Phillips TV with a RCA niteglo universal remote.
there are several. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
Codes:
0154,1174,0062,0204,0004,0184,0208,0205,0206,0207,0189,0183,0199,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0140
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 29, 2009 | RCA Universal Remote 3 Device Remote...
My nintendo 64 wont workon my tv!!
First you must be sure that the connection on your tv is securely connected.
Mar 08, 2009 | Nintendo 64 Console
Dtv box
the box broadcasts through channel 3 thus you have to set your tv to channel 3 to pick up the signal. There is a menu to use once you get a singal to pick up the channels. You may also want to call the 1800 number on the back of the remote, they will wallk you through the problem.
Jun 16, 2008 | Insignia Digital-to-Analog Converter for...
Channel 3
most TV will allow manual entering of numbers on the remote.
if you have the remote try typing "03" thats Zero Three on the remote.
you might have it in video mode like vidoe one or s-video there different mode for a tv. check on the remote for source or TV/VIDEO button, to make sure the TV is in TV mode.
also on the TV itself there should be a menu button some TV have RESET option. look for that
or just goto the WEBSITE of the manufacture of the TV set im sure they have ONLINE manuals too.
Good Luck
Jun 14, 2008 | Curtis-Mathis CM19011 TV
Concierge series 25" wont stay on channel 3
If Im not mistaking , some of Zeniths TV sets cannot be unplugged or disconnected from the wall. It will delete the memory and I guess the default channel is Channel 52.. I didnt know you disconnect the set in the ? you asked before. To stop this simply plug the set into an always on wall receptical and turn on the cable then the TV set. your going to need to do this order of operations as I know Zeniths will detune and you wont get any color sometimes if you turn on the TV then the cable. Sorry nothing you can do short of getting another set. Good Luck
Jul 30, 2006 | Zenith C27A24T 27" TV
You have to have the original remote. Then go into the menu under channel set-up. punch in channel 3 press add. The punch in channl 52. then press delete. Or turn on the cable box and go to auto tunnin g and let it do its thing. Im sorry , but if you dont have the original remote with a menu button your going to have to live with your problem. Good Luck
Remote not working correctly
It all depends on what and how the cable box is connected . Do you have an outside or inside antenna connected? If you have a cable box , why would you want to go to another station on your tv? Does the cable box have an rf output that connects to the tv through he antenna input on the back of the set? If so the tv should stay on a station to recive the stations thru the cable box. Didnt the cable tech explain how to use the system?? If you dont understand how to use the cable you should, for sure call the companey, and see if they can explain how they hooked up your sysytem as theres many many ways to do this. If you have the owners manual what im about to explain is in there too. On the tv remote theres a button called menu, press it once. Use the up and down arrows to scroon down and highlight the setup . press the ok or enter buttonpress the right language,then search for channels. When this is over then exit out of the menu, and try switching channels. If you still dont have any channels you gonna have to find out whats connected to your rf input as channels wont come in if theres not the right source connected. GOOD LUCK
Jun 18, 2006 | RCA G27303HP 27" TV
Sanyo DS27510 27" TV Logo
63 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
