Question about Bell Sports Scout Jogger
Bell stroller left back wheel
Our back left wheel is riding at about a 45 degree angle to the earth's surface...not so condusive to a smooth stroll down to the market. help! the bell co. says they have no replacement parts and haven't made the stoller for over 2 years...so basically - a fine farewell to me and a hearty 'good luck'! it's a great stroller and would love to keep it - two bike shops were inept at attempting to remedy the problem, perhaps someone here can help a new mom out!
  • Anonymous Sep 11, 2008
    Back tire is angled, as from defect or wekness in the plastic housing supports that bolts tighten to, to keep it in proper position. Looking for source to order replacement parts. Looking for Bell stroller web site, but have not found yet...
  • sophie
    sophie Feb 28, 2019
I have same problem... I took the main bolt out that holds the plastic pieces to the metal frame, that holds the wheel assembly on that side. I pulled it off and found that the aluminum frame had actually ripped, broke a metal section off under the plastic area... Looks like the frame would have to be re-welded to function again... Take that area of your wheel apart, and see what is hiding beneath the plastic covering... Good Luck...
Posted on Sep 11, 2008
SOURCE:
How do I prevent the front wheel on my Stroll Air Zoom from locking on its own?
Contact direct, ask if there is a recall?
The Best Quality Single and Twin Strollers for your Twins
Amazon say it is discontinued, which is never a good sign.
Stroll Air Zoom Stroller Black Discontinued by Manufacturer
This review is not good.
I would NOT recommend this product to my worst enemy. It is NOT worth the $ they are charging, doesn't stand up to the 'elements' of the environment, and the company provides ZERO customer service.
Jul 07, 2017 | Cars & Trucks
How to mitre corners
using a set square , The angle if 45 degrees is machined into the handle draw a line at 45 degrees across the surface you wish to mitre cut
clamp a piece of timber along that line and use it as a guide to cut with the circular saw
Apr 27, 2016 | Saws
I did a 45 degree bevel cut with my Dewalt portable table saw and now I can not get the blade back to a 90 degree position, any thoughts?
Did you check to see if the saw has a locking nut on the front of the bevel gauge handle? Its possible you just locked it into position and forgot to unlock.
Oct 05, 2014 | Dewalt Saws
Bosch Glide Miter Saw get stuck at 45 degree bevel to the left
Adjusting the miter angle involves two cast surfaces sliding against each other. If those surfaces have some irregularities, high spots on the two surfaces will bind against each other. You may have to disassemble the rotating table from the base and do some filing or grinding.
Dec 29, 2013 | Makita Tools 12" Compound Miter Saw -...
Our stroller shakes when pushing forward (very badly - would shake the baby out of the stroller if we had her in it), but if you pull the stroller back it appears to cease shaking. Is there something...
You don't mention what make / model you have. Try turning stroller upside down ( without baby in it *-) ) and spin each wheel to see if it runs freely. Try to rock the wheels from side to side to see if there is any play in the axel. On a flat smooth surface do all wheels touch the ground? If the front wheels swivel do they rotate freely without any side to side play? Some strollers have nuts you can adjust others just have Silver domes. Try tightening nuts till wheels get tight then back off just enough so they spin freely try taping domes on tighter using a large socket from a socket set and a hammer so the pressure is around the edge of the dome and not in the centre where it would dent. Silicon spray is the best lubricant for strollers.
May 09, 2011 | Bertini Baby Gear
Sit 'n Stroll Stroller
The manufacturer should be able to help you with any replacement parts that you may need.
http://www.tripleplayproducts.com/napsac.asp (800) 829-1625
Good Luck! from Moms Just Know
Oct 21, 2008 | Safeline Sit 'n Stroll - Shoreline...
Quinny Buzz front wheel.
Hi they are not very good on rough ground, you can buy all terrain front wheels on ebay.
Oct 06, 2008 | Quinny Buzz Jogger
Finding the length of a triangle
might try
(54tan)/45
I don't have a calc that will do it or I would try it and see.
Jul 31, 2008 | Office Equipment & Supplies
How do i unfold a zooper tango double stroller?
There's a locking mechanism on the left hand side about mid-way down just under the armrest. You need to pull the plastic lock off of the pin and then unfold according to the "fold" instructions included in the manual.
Apr 18, 2008 | Zooper Tango Twin Stroller
Bell Sports Scout Jogger Logo
297 people viewed this question
Top Bell Baby Gear Experts
Sheldon Dedek
 Jojo
Jojo
NOEL
NOEL
Are you a Bell Baby Gear Expert? Answer questions, earn points and help others
