Question about HP LaserJet 1320 Printer
Border page error
Hi about 2 week when i order a file print in word with page border,it mess the bottom of border.
  • 163 Answers
Re: border page error
There is not any problem with your printer check the paper size only and adjust it
Posted on Sep 19, 2007
0 characters
3 Points
Bottom of borders missing
Check to see if your paper setting is A4 instead of 8 1/2 x 11. If so change it.
Jul 04, 2010 | Dell 924 All-in-One InkJet Printer
Borderless Printing Doesn't Happen
hi as you have set border less printing in publisher and on printer, have you adjusted the layout guides? on the blank page go to arrange, then to layout guides, adjust the numbers to atleast 0.25 (lowest it will go) and save then try printing, the but remember, hp still has a border due to the print heads position they do not travel over the print area like some printers do, you will always get a small white line no matter what...hope this helps
May 24, 2010 | HP Printers & Copiers
I have a hl 5140 printer and there are lines on the side of the page when it prints.
Hope I can solve your problem
The first thing is do you go to print preview before you print if you do and the line is there it might have something to do with your page border go to your page border and put on no border
It also might have something to do with not having your paper correctly in the printer make sure all your paper is the same in the printer and it is all straight
and correct at the time of print.
but my bet is that you have your page border on 1 side of your paperwhen you are doing a document up the top you have page borders make sure it is on no page border
I hope I helped
Jan 22, 2010 | Brother HL 5140 Laser Printer
HP4000n (Not printing borders on Excel and Word)
this is because your document content is out of range for your printer settings
clik on file - page setup and adjust your document properties from there
Jul 24, 2009 | Printers & Copiers
Problem with printing borders, and with cartridge.
Hmm, I got the same problem once in my university LABs.
What i do was the same you have done, but do try again because if "some side" of the border is not been printed, then its the "Border Setting".
Try using Ms Word 2007.(I guess you are already using it)
Goto Page Layout Tab > click Page Borders (Borders and Shading dialogue will appear) > Then insert a border, apply it.
Now again go there, and this time in the bottom right corner of the dialogue box, you will see Options button, click it.
Make the Margins Maximum (31pts) (Measure from : Edge of Page)
if this doen't work, then;
You can also change the margins but now (Measure from : Text)
But the first one works for me perfectly.
before doing this all also re-insert your blx/wht cartirdge.
  • If helpful, Kindly do Rate
Jul 18, 2009 | HP PSC 1410 All-In-One InkJet Printer
Setting margins on printer
Well, by now you may have found the solution, however, make sure that in MS WORD under File > Page Setup > A4 is selected, and if you still this prompt (error), just click on OK and proceed with printing.
The Laserjet Printers are capable to print upto 5mms from the edge of the border.
Mar 17, 2009 | HP LaserJet 4250n Printer
border cannot print bottom side
but you know you can print if you can do it
margin up to 1.29 of bottom that simple
Dec 29, 2008 | HP DeskJet F380 All-In-One Printer
Page setup for printing
In the file document you will find the tab called FILE. Click on it, and go to page setup. There you can change the edit the border or select the type of printing to A5, A3 etc.. And you can even also select landscape or portable. Thank you.....
Sep 16, 2008 | Canon imagePROGRAF IPF720 Printer
Problem with border page
check your page size and set it,your printer is ok
Sep 12, 2007 | HP LaserJet 1320 Printer
I can't get rid of the margins when i print something
I'm guess you are printing from MS Word? Click File the "Page Setup" Click the layout tab the far right then go to the bottom and click borders and select the NONE option. You should have your borders removed!! =) That is if that is the type of border you are talking about.
Feb 11, 2007 | Xerox Phaser 8500N Printer
HP LaserJet 1320 Printer Logo
185 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
