Question about Garmin iQue 3600 GPS Receiver
GARMIN ique 3600 - need spare part
I need the 2-lead foil that supplies the backlight power to the display. ANybody know where to get parts or spare-part units?
  • Teachcool
    Teachcool Dec 13, 2007
    I replaced the battery in my 3600 and now the backlight doesn't work. Any suggestions on how to correct this?
    Novelist:
  • 233 Answers
EBay or other online sites like that, search for sold 'as is' for parts.
However you can't have mine... it works just fine. ;>D
Posted on Nov 01, 2007
  • Eil?fur Bj?rnsson Mar 23, 2011
    Adviceable to use elastic glue to hold the jog wheel together and oil based elastic glue can be used instead of the black rubber ring around the antenna. Tape can be used to hold the power button. The red and black wires into the display broke on mine and I got a piece of a cable with many multithred wires, in many colors, and the same size as in the iQue, at a radio shop.
I have a Garmin iQue 3600, I was changing the battery, when opened the unit the switch marked rec esc on the side of the unit flew apart.I need a diagram of how to reassemble it. Thank You
iQue 3600 Undo engl.V.6 Release
Hallo -
I mistakenly IQUE3600 my system 5 at the english version 6 updated, now I have a white screen,
there's nothing more.
Please help
If your IQUE -Problem is not reparabel - I would sale it, for repair my
If your Garmin is beyond repair, I would rate this unit as a spare part for my broken
Buy
Wenn dein Garmin ist unreparierbar, ich würde dieses Gerät als Ersatzteil für mein kaputtes
kaufen
Oct 26, 2010 | Garmin iQue 3600 GPS Receiver
I just changed the battery on a garmin ique 3600 and the backlight won't come on. Any tips?
Most likely you broke one or both wire from the backlight to the circuit board. Open the unit up and look for a black and red wire. Both should be soldered to the circuit board. LED's are used for the backlight and so it does make a different that the back and red wire are soldered to the circuit board correctly.
Oct 04, 2009 | Garmin iQue 3600 GPS Receiver
Need ground wire reconnected
You need to solder the wire or wires back on the board. There is a red wire and a black wire used to power the backlight. They go to two solder pads on the board that are near each other. You should be able to see where the wire has broken off. If you don't have the equipment or haven't done this before ask a friend.
Apr 22, 2009 | Garmin iQue 3600 GPS Receiver
Garmin ique 3600 backlight does not work.
When you opened up the unit, you probably loosened one of the wires. Look to see if there is a small, short black wire and a small short red wire attached to the screen and soldered onto the circut board. They control the back light and one of them may be loose or disconnected. It can be repaired if you have a fine enough soldering tool.
Apr 11, 2009 | Garmin iQue 3600 GPS Receiver
Backlight for palm ique
Did You try holding dowm the on/off button for 3 seconds after you turn it on?
Mar 19, 2009 | Garmin iQue 3600 GPS Receiver
No backlight on my Garmin IQue 3600
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
If your problem still continues then you need to take your gps to near by shop to get it repaired .
Feb 03, 2009 | Garmin iQue 3600 GPS Receiver
My Garmin ique 3600 won't come.
Hold POWER button down while pressing RESET button
Aug 04, 2008 | Garmin iQue 3600 GPS Receiver
Repair center for Garmin iQue 3600
dont send your ique 3600 to raytech electr.i leaving at 5 min. from there and last week they tell me they dont repair the ique anymore they send back all there part to garmin they had to much problem with them good lock
May 25, 2008 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
158 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
