Question about NEC Versa Premium Notebook
Touch pad faulty
What is the best way to open it up to replace the touch pad
NEC M540 versa
Can u guys help me?? i got a problem to take out the HDD.. my laptop model is NEC VERSA S3301.. i don't know how to open it!!
HDD is on the front side with the mouse sensor.if touch pad is most left then hdd is on right side and if touch pad is right most then hdd will be on left side.
you can find hdd by open the keyboard side.there will be two or four screw on th backside or bottom of laptop.open these screws then pull touch pad carefully.dont force it may be you open wrong screws rather then correct screws.
hdd always on the side of touch pad its now on you how to open it.
Jun 28, 2011 | NEC Versa SXi Notebook
Touch pad is not working?
Just check for the key combination on your key board (ex. Fn + F4 or F5..depends on the what key was designed for the touchpad), the touchpad might be locked.
If it is not locked, reinstall the touchpad driver, but it this still doesn't work, boot to Safe Mode to check if it does. Touch pad still not responding in Safe Mode would mean hardware failure.
Hope this helps.
May 25, 2011 | NEC Versa FX Notebook
Don't know boot up password. How do i go about unlocking it. Nec versa m540.
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Nov 09, 2009 | NEC Versa Premium Notebook
Touch pad isn't responding to double taps
It is probably damaged. Take it to a service center or call Tech support.
Sep 18, 2009 | Computers & Internet
Black screen after BIOS update
better flash the bios again, this time try a different version of the bios. but, if it wont boot from the new bios flash disk, then u just turned your computer into a paper weight.
Dec 29, 2008 | NEC Computers & Internet
Wireless stoped workn
Typically there is a tiny switch or button which lets you turn off the wireless capability manually - for "protection" in certain circumstances. You probably accidentally flipped this switch, pressed the button, etc. These are HARD to find but if you look carefully around the edges, and study the buttons you never use and don't know what they do, you'll find it.
Dec 27, 2008 | Computers & Internet
NEC Versa VY22X/RX-L TOUCH-PAD FAILURE
perpy,, this is brian ...the answer to your prob is to go to your nearest technician ,,or if your not afraid to open ur laptop,,just clean it,,maybe it is not clean or it may have a thick dust...just try it bro
Jul 09, 2008 | NEC Versa FX Notebook
Nec versa litepad
Here Try this website they were the cheapest here . Hope this is what you are looking for. should be the right one thanks for looking
http://www.pchub.com/uph/catf/SearchItem.aspx?ft=nec+versa+board&gclid=CPDF3O-VrpACFSBMGgodTANs8g
Dec 16, 2007 | NEC VL-PAD-933 Tablet PC
NEC Versa Premium Notebook Logo
99 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
