Question about RCA R52WM24 52" HDTV Projection Television
Need to replace rca projection convergence fuse fl231
I have the same problem and repair shop wants close to $400 to repair it..the fuse only costs .55cents can anyone walk me thru what i need todo to change out the fuse safely, is there any risk of stored energy or electric shock assuming my tv is unplugged..thanks
  • 1 more comment
  • stinkychili Apr 13, 2009
    I had a tv repaif guy come out and tell me it was the fuse and he wanted almost $400 to fix it, I wam electronics tech so I am confident I can fix it myself I found the fuse online and bought one, I just want to be sure that there is no stored energy on the board before I replace the fuse, can you give me a quick walkthru on the steps I need to take. thanks
  • mlawler1 Apr 16, 2009
    need to replace FL231 fuse on RCA model R52WM24 (auto convergence is out) any risk of stored power / possible danger?
    need guidence on changing fl231 fuse on RCA model R52WM24(auto convegence went out) any chance of shock do to stored power in flyback tranformer or other parts?
    President:
  • RCA Master
  • 1,779 Answers
Can you please give me the entire story behind this? You also stated you have the same problem, I would like to know if someone said it was just a fuse and why you think your's is just a fuse. Looking forward to hearing from you.
Posted on Apr 13, 2009
WERE CAN I BUY AND HOW MUCH IS A FL231 FUSE FOR RCA HD52W59
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 26.00. Its listed under the RCA repair kits as the ITC222 & ITC222A convergence option missing repair kit. Its available at www.tvrepairworld.com
Dec 29, 2011 | RCA HD52W59 HDTV Projection Television
Hi I have a convergence issue. Is there a place in NYC where I can purchase these replacement items: (1) FL231 micro fuse (1) DL231 Diode (1) CL230 radial Capacitor I repaired the initial...
This DLP model RCA tv have convergence menu disappearing is very easy to fix just replaced the convergence fuse FL 231 near the FBT also must be resoldering FBT too.U can buy this FL231 covergence fuse at Ebay.com.No,but u must have to have a soldering iron,a desoring pump or desoldering braids and know how to basic soldering?To replaced this FL231 convergence fuse near the FBT and also must resodering the FBT too for protecting the new FL231 convergence fuse.
Mar 02, 2011 | RCA R52WM24 52" HDTV Projection Television
HI my name is eric. my color on my rca 54 tv off how do i line it up
This tv have problems known as a convergence problems,it dead.The tv colors lines R,B,G mis alignments,have colors shadows or 3D pictures alike?U must have tools like a soldering iron,a desoldering pump or a roll desoldering braid,a roll of solders?Can u also do basic soldering?This RCA DLP tv used covergence FUSES.Yes,try Ebay.com to buy a convergence FL231 convergence fuses there are three of them the one middle useally alway dead.After replacing the FL231 Convergence fuse,near there a big black block of plastic that call the FBT,the high voltage tranformer.Resolders the FBT too.Will solved this problems.Or the tv shop,will cost like 200-300 for parts and labors.
Dec 28, 2010 | RCA HD52W59 HDTV Projection Television
52 in RCA rear projection television
Not haveing the convergence option on this set is a clear indication you have the fl231 fuse problem. this is a simple repair and i see it all the time at the shop. I would suggest you read the "fl231 fuse problem in the tips and tricks section of this website. others have repaired this for less than 10 dollars and about an hour. if you have any trouble be sure to let me know
Jun 04, 2009 | RCA R52WM24 52" HDTV Projection Television
Rca hd52w59 3d screen colors are seroperated no convergence
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 12.00 shipping is free. the parts are all listed under the RCA parts category.
http://servicemanuals.vstore.ca/
May 28, 2009 | RCA HD52W59 HDTV Projection Television
Can't find convergence on menu
Please consult THe fl231 fuse problem under the tips and tricks section. The instructions are simple to complete
Apr 12, 2009 | RCA HD52W59 HDTV Projection Television
i have found the reason for the fl231 fuse blowing is faulty solder connections on the flyback transformer is the main cause. I have came across only one bad signal board that cause this but this was very very rare 1 in 1000. This is a very specific fuse, .400 and it is recomended only to replace with exacte one. consult the fl231 problem in the tips and tricks section.
Jan 02, 2009 | RCA HD52W59 HDTV Projection Television
RCA 52inch Model R52WH77 HDTV
may i suggest reading the ariticle the fl231 problem in my tips and tricks section of my profile. YOu MAY have a 5 dollars 30 minuter fix. Determine if you have the convergence option under the setup option of the customer menu. if you dont then congratulations you have a simple fix. i you do have the convergence option and the autoconvergence then you might have other problems. and will have to troubleshoot further. If so ill talk you through some more. THIS set has NO stk convergence ics. my feeling is the fl231 which i see alot on this perticlar model at the shop
Oct 07, 2008 | RCA HD52W59 HDTV Projection Television
R56WH78 convergence problem
Get a new TV , i have had problems every year and now its off warranty, I will never buy an RCA again as long as I live,
May 13, 2008 | RCA R56WH76 Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
1,018 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
