Question about Dell 5100cn Laser Printer
Ear splitting noise
My 5100cn when printing envelops sounds like metal to metal brakes on a car. It was supposed to have been refurbished but by who I dont know. Can someone help me and my pets with this problem so I can keep working at home?
  • 3 more comments
  • bear6567 Sep 11, 2007
    It also does it printing letters but not as loud.Toner was installed by whoever refurbished it.
    The envelops are being fed thru thew MPF.
  • bear6567 Nov 02, 2007
    Both drum and fuser have been replaced and my loud noise is still there. Im so sorry I did not get another 3100cn.
  • bear6567 Nov 08, 2007
    Now this junk is printing red on almost all prints.
    Dell no help,guess I should have called the Chinese for help.Never again Dell.
  • 4 Answers
Do you have an envelope feeder optional assembly? Is the printer doing the noise only when you print envelopes? Did you changed the toner cartridge recently?
Posted on Sep 11, 2007
SOURCE:
Light thumping sound when turning,could this be brakes
Could be universal joints, struts, or wheel bearings too! Get underneath your car, put your front end on Jack-Stands for safety, and grab hold of the tie-rods and check for movement up and down. If they seem tight, do the same with your front struts... it's movement your looking for. Spin the front wheels with the wheel covers off and listen for noise. They should spin freely. Brakes usually make a scraping sound... metal to metal. Any thumping when you brake hard... like a panic stop is normal. The ABS brakes are supposed to do this.
Mar 21, 2015 | 1998 Ford Escort
Screechy printer
Hi, I work on Laser printers alot and often find that squeaking is caused by the fuser bearings going bad. Usually replacing the fuser is not a difficult fix, but can be a little pricey depending on the model. One thing to try before replacing the fuser would be to try replacing the toner/drum and making sure that is not the source of the noise. Hope that helps.
Sep 14, 2007 | Dell 5100cn Laser Printer
Printer will not print in color
Printer properties in "start menu" printing preff. (make sure you are not using a black and white driver) -Car
Apr 17, 2014 | Dell KDA1 Color Laser Printer 5100cn PC...
Front end grind
Sounds like a wheel bearing.
Feb 20, 2010 | 1995 Toyota 4Runner
My printer has started making a knocking sound
Haha, shouldn't be your wife this time :P It sounds like one of two things.
1. One of the rollers that pulls through the paper has come a little bit loose and therefore is starting to hit other things, causing said noise. This is why you only hear it when it when the printer is active
2. One of the rollers or gears has become stiff, and isn't spinning as should be. This could stop all printing all together, so it's unlikely to be this, but without looking at it myself, I couldn't say, sorry.
I'd advise looking at the rollers within the printer, to make sure they're not jammed, loose or stuck full of toner. Make sure you have the printer off for a while too, you don't wanna burn your hands off :)
Lemme know how it goes
BB
Oct 22, 2009 | Dell 5110cn Laser Printer
Printing #10 envelopes with 5100cn, using MPF. Set paper size to #10 envelope, output same, MPF set for envelopes. Printer display says load #10 envelopes, which are loaded. What do I do now?
You can download the manual for your printer here. You merely need to go to the word processor or program you're printing from and load the addresses and send them to the printer. Try just one as a test to make sure your margins and spacing are set up correctly.
For Dell specs on print media guidelines for your machine, see here. For a blurb about en velope loading, see here. All options here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 10, 2009 | Office Equipment & Supplies
HP Color Laserjet 2840 now makes ear-splitting whine every time
Did the noise start right after you replaced a toner? If so it must be a bad toner which is causing the gears to grind. If this noise happened out of the blue then it might be a bad fuser drive gear which is the gears that connect the fuser to the machine.
Jun 25, 2009 | HP LaserJet 2840 All-In-One Printer
Focus front brake grinding noise on frist braking in the mornring
Look for a metal tab at the brake. It's only supposed to touch (and make noise) when the brakes are worn down. Sounds like it's bent in too far.
Mar 25, 2009 | 2005 Ford Focus
Dell 5100cn Laser Printer Multipurpose Feed Problem
I had the same problem, my solution was:
1) Go into the Print dialog window, select your 5100cn printer and click the "Properties" button next to it.
2) Select the second tab, labeled "Paper Tray".
3) Select "MPF" from the "Paper Source" drop-down list.
4) Click the "MPF Settings" button and select "Envelope".
That should allow your program to print to MPF for envelopes. This needs to be done in your software, setting it on the printer's control panel didn't work for me.
Dec 17, 2007 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Logo
154 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
