Question about Gateway MT3422 RTL Notebook
My fan is heating up, i need the proper way to open the fan.
I need the way you open up the fan on an mt3422. i can't find it online.
  • rebecca_hear Apr 13, 2009
    i already tried that several times. and i also tried buying a laptop mat to no avail. i want to know how to take out the fan and physically clean it.
  • keithklee May 11, 2010
    did you first try to use compressed air to the fan?
  • Gateway Master
  • 5,660 Answers
I can't find one either. Means to me, that Gateway really doesn't want anyone but an authorized dealer, or authorized shop to do this.
However, I can give you generic info, and perhaps this might help.
I repair laptops. Haven't had the 'fortune' to repair that many Gateway's. (Maybe this is a good thing, right?)
Access to the cooling fan is either down from the top, or up from the bottom. (Yeah, I know. Duh! Read on)
SOMETIMES, you can remove a few screws, and access a panel on the bottom for the cooling tube/heatsink, and fan assembly.
If so for yours, I suspect you would have seen this already, and wouldn't be posting a question on here.
Accessing a cooling fan from the top.
First remove the AC adapter, (Charger), if plugged in. Remove the battery. I advise at this point to buy a cheap ESD wrist strap, (Radio Shack has 'em), and connect the alligator clip to a good ground source. (The metal frame of an unplugged desktop computer would do nicely)
There is a plastic strip above the keyboard. It's right below the LCD screen. There may be speakers in it, and usually there are LED lights.
This plastic strip pops up. It has tabs that go along the bottom edge, and the plastic strip just snaps into place, because of these tabs. One uses a flat tip jewelers screwdriver, eases it down into where the edge of the strip meets the body of the laptop, and pops it up. (Pops up with a sickening sound. 'Crack' You'll think you have broken it. You could drive a truck over that plastic part!)
After you have one small place started, you work around the edge, until coming to the last, the strip pops out.
This may give you a little better description/view of what I'm talking about. http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M105/take-apart-notebook-1.htm (At the bottom of the page you will see Page1 :: Page2 :: Page3 :: Page4 :: Find another model Click on Page 2: Go to Step 9)
Another one, http://www.irisvista.com/tech/laptops/Toshiba-Satellite-X205/take-apart-laptop-1.htm (Step 7)
There may be wires to this strip, (Speaker and/or LED lights)
If so, you will see small connectors on the wires. These are male/female connectors, and you can take your fingernails and ease them apart. The connectors have different sizes, and pins. There is no mixing them up, when it's time to reassemble.
You should now see a screw, or screw that hold the keyboard in place. Remove them. I use an emply clean egg carton. I label each egg holder, for where the screws came out of. (Pretty 'Techie', huh? lol! NOT!)
The keyboard lifts up at an angle, and is removed at a 45 degree angle, away from you. BEFORE you take it all the way out though, remove the connecting wire harness!
Now you should see a metal shield. This is removed.
You should be at the area now, where you can see the cooling tube/heatsink/fan combo.
Two more links that may help.
1.http://www.youtube.com/watch?v=EWwejCKVGOY
2.http://www.notebookrepairguide.com/laptop-notebook-repair-service-manuals/
Posted on Apr 13, 2009
    Problem Solver:
  • 5 Answers
A super easy fix would be buying a laptop mat that has built-in fans to help cool your laptop.
I have a Toshiba Satellite A215 and it keeps shutting down and getting hot. I don't think the internal fan is working. Can this be fixed and is it expensive?
Replacing the fan on the CPU or the GPU, Graphics card, is actually very simple and the fan will run about $20 to $25 depending on what type of fan you get and where. Aside from a new fan you will need a small tube of heat sink compound. The fan just clips on to the CPU. Make sure you get a fan that is designed for your CPU type or it will not fit properly. For instance, if you have a P-3 CPU you can't fit it with a P-2 Chip or P-4 chip, they won't mount correctly and subsequently they won't work. When you go to Best Buy or the computer shop your to buy your part tell them what type of CPU you have and that you want the cooling fan and the heat Sink Compound to mount it with. They will be able to direct you to the proper fan Type. Also, while you have it opened up take the opportunity to use canned Air to blow the dust out of the machine. If you are doing what is called Over Clocking it is important that you know you may have burned the CPU out as this causes the CPU to heat up more than it would if you just had it installed for the proper speed. The old fan will be difficult to remove because the old heat sink compound will have formed a bond between the fan heat sink and the CPU itself. If you have to do any prying to remove the old fan make sure you do so carefully and make sure you clean the old heat sink compound off the CPU before you try mounting the new fan. When you apply the new Heat sink compound you want to place the compound in the center of the CPU and let the heat sink spread the compound out in a thin layer. This compound needs to be spread evenly so it forms a good bond between the Heat sink and the CPU itself to properly transfer the heat from the CPU to the heat sink so the fan can properly cool the CPU.
Nov 21, 2010 | Computers & Internet
Problem understanding
Ok i found your problem,What he was saying was to take the laptop bottom cover off and clean out the inside of dust and dirt,this can be done with a can of air which you can get at a local computer or staples store.
I doubt this is going to do anything since the laptop wont boot up.
Sounds more like a memory stick issue or a hard drive failure.
Have a look at the connections inside the laptop that everyting is connected.You can try cleaning it out but it may pay you to take it in for service.
Apr 14, 2010 | Gateway MT3422 RTL Notebook
GATEWAY mt3422 WILL NOT BOOT UP. Power light is
if your harddisk is ok than , u open your notebook motherboard and clean processor fan properly,,than again fitting your laptop than boot from cd rom (make sure that your cd rom is ok )
Cooler Problem ?
There are devices you can purchase which aids in pulling more air through the system and keeping it cooler. One which I purchased and am quite pleased with is by Antec. It is a dual fan unit that is powered by one of your USB ports. You place your laptop on top of the unit, power it on, and it works wonders at keeping your system free from damaging heat buildup and those annoying shutdowns!
There are other units made by other manufacturers available as well. Some more expensive, some less. I have always had good luck with products from Antec and their price was reasonable as well.
Jan 24, 2010 | Gateway MT3422 RTL Notebook
My MT3422 gateway will not boot up.
Sounds like an internal graphics problem then motherboard fault.
http://www.notebookforums.com/post2949935.html
Aug 03, 2009 | Gateway MT3422 RTL Notebook
Black screen will not boot at all
boot it, as it starts, keep tapping the F8 key,
should take you to, system startup utility,
take the top option
" last known good"
let it do it's thing
Reboot.
hope this helps
Regards
Richard.
Apr 20, 2009 | Gateway MT3422 RTL Notebook
Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Jul 19, 2008 | Dishwashers
Gateway MT3422/athlon tk-53 mal-function
some screen failure or graphics failure..
I think you need to send it back there you bought it.
CS.
May 19, 2008 | Gateway 7405GX Notebook
Gateway MT3422 RTL Notebook Logo
338 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
