Question about Bosch WFMC6401UC
Access the filter for the drain.
How do I access the filter for the drain? My washing machine will not drain but is working in all other ways.
    Problem Solver:
  • 8 Answers
I believe there is a panel at the bottom of the front of the machine. It is held in place by a couple of screws that can be removed with a coin or screwdriver - they are not machine screws by larger in size and made for mortals to use. Behind this panel is a filter screen that you must clean; replace it and your machine should work OK. I would check your owner's manual, too, which I am sure has a better explanation of all this. Or Bosch's website.
Posted on Sep 12, 2007
2 Suggested Answers
  • 4 Answers
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
Posted on Dec 04, 2009
Where is my pump filter whirlpool duet front load washer
When your Whirlpool washing machine won't drain, there's a possibility that the drain filter is clogged. The drain filter is designed to catch lint, change, credit cards and all the other things that find their way into the washer. Whirlpool washer models that have a drain pump filter are easy to disassemble so that you can access and check it. Before you go to the minimal amount of trouble it takes to check the filter, however, take a look at the drain hose behind the washer to ensure it isn't kinked.
1 - Unplug the washing machine. Lift the front end and place two-by-four blocks under each foot to keep the front elevated. 2 - Unscrew the three screws at the bottom of the panel, using a Phillips screwdriver. Remove the panel. The drain pump assembly is directly in front of you, in the middle of the machine. 3 - Unscrew the knob on the drain pump by turning it counterclockwise. Hold a bucket in front of the pump while you remove the knob to catch the water. There may be as much as 2 or 3 gallons. 4 - Turn the knob over. The filter is on the back. Check the filter and remove any debris or lint. Replace the drain filter onto the pump. Screw on the access cover. Take the machine off the blocks and plug it in.
Dec 21, 2016 | Whirlpool Washing Machines
E1 F9 code front load washer whirlpool duet
When your Whirlpool washing machine won't drain, or is displaying the E1 F9 error, there's a possibility that the drain filter is clogged. The drain filter is designed to catch lint, change, credit cards and all the other things that find their way into the washer. Whirlpool washer models that have a drain pump filter are easy to disassemble so that you can access and check it. Before you go to the minimal amount of trouble it takes to check the filter, however, take a look at the drain hose behind the washer to ensure it isn't kinked.
Lavamat 74620 pumps out and does nothing no error codes? Door locks drain pump does nothing and no water fils motor does not spin. Is it the main control board? Brushes look ok on motor fan belt ok
Have you checked for anthing that has gone into the drain filter, there should be access to the filter via a small access way at the front of the machine either left or rihgt side at the bottom. Your instructon manual would give directions on how to access the filter location to check the filter is clean and should be checked regularly to keep your machine running correctly.
Dec 13, 2016 | Washing Machines
We already finished washing but the door of our washing machine remains locked. how can it be opened?
Hi.
If the door stays locked then there is water detected inside the machine.
You will need to disconnect power and to access the drain pump/drain filter to empty the water inside the machine. Water is emptied through the drain filter located in front of the machine at the bottom, behind the trim panel. If the problem occurs again the machine is faulty and must be repaired. Parts such as drain system, drain pump, pressure switch, door switch and control panel may be responsible for drain problems.
Check the position of the drain hose. Ensure that the height is as specified by the manual or you get siphoning and drain does not end.
Access the drain filter. With most front loaders this located in front at the bottom in a corner, there should be a trim or an access panel.Top loaders have an access panel at the back, or more commonly the pump is accessed from underneath, bending the appliance on one side and securing it.
The machine has a pressure switch. It is a sensor connected to a long thin rubber hose. The pressure switch is often in control assembly. Clean the hose and the switch. One way to test the pressure switch is by blowing into the switch, but manufacturers say this must not be done as you can damage a good switch.
The pressure switch is difficult to test in full. Testing is done either reading voltages while machine is working or reading Ohms at the switch with tub empty and full. For safety reasons I suggest users to avoid performing tests or maintenance that must be done with power on.
Most machines have a tech booklet tucked inside the control panel assembly. You take off panel that is held by a couple of screws and see if there is the envelope with the sheet
Here a page about drain/spin problem.
Start checking drain hose and drain filter. If machine is a front loader the drain filter access is located behind the door at the front bottom side of the machine.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 10, 2011 | Washing Machines
Water is not drained out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 18, 2011 | Washing Machines
When the washing machine is draining it starts to make a grinding noise
Hi.
Access the drain filter and check for foreign objects in there. In this model the access for the drain filter should be located at the front bottom of the machine, behind a trim. Other models have the access at the back. Disconnect power, locate access, remove cap, collect water using a container and check for blockage or foreign objects in there.
Regards.
Ginko
Aug 06, 2011 | Indesit W 123 Front Load Washer
My wont drain the water after washing
Hi.
The problem has been posted by mistake in kitchen ranges. I guess that we are talking about a washing machine or about a dishwasher. In case of a dishwasher, clean drain well and filter and check the setting of the drain hose at the back. If that is not enough, the bottom panel (or the kickpanel) of the dishwasher must be removed to access pump and check for blockage in hose connected to pump.
In the case of a washing machine:
Access the drain filter. With most front loaders this located in front at the base, there should be a trim or an access panel. In some case pump access is at the back of the machine or underneath. With top loaders the access is either at the back or at the bottom of the machine.
The machine has a pressure switch. It is a sensor connected to a long thin rubber hose. The pressure switch is often in control assembly. Clean the hose and the switch. One way to test it is by blowing into the switch, but manufacturers say this must not be done because you can damage a good switch.
Most machines have a tech sheet tucked inside the control panel assembly. You take off panel that is held by a couple of screws and see if there is the envelope with the sheet.
Here a page on no spin problem.
Jun 02, 2011 | Kitchen Ranges
Washing machine flashing oe
OE = Drain Error • Not fully drained within 10 minutes.
Check and clean the pump filter. The access panel is located on the front, bottom left of the machine. Place a towel under the front of the pump filter access panel opening before opening to catch any water that may flow out.
Check drain hose on the back of the machine for any kinks or blockage.
Dec 18, 2010 | LG WM1814CW Front Load Washer
Hi,My daughters washing machine (Hoover Nextra HNL 842) fails to empty after washing cycle.(error code 3). I intend to check the pump and float switch.I can access the pump through the bottom of the...
You should have a drain filter. They do become clogged and need to be cleaned out. If the draine filter is clogged you will immediately know it upon removal and inspection. If this is the culprit, be sure to show your daughter how to access it, remove and clean it and then to reinstall it. This can be quite frequent (8 to 12 months) depending on her environment, like allot of pet hair and things like that. Let me know if this is the culprit. By the way, you are going to have to bail as much water out of the drum as posible unless your model has an easy water shut off just prior to the filter. Otherwise, all the water left in the drum will run out of the filter assembly when you remove it. With any luck the filter is the culprit and not the pump.
Nov 21, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
Bosch WFMC6401UC Logo
96 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
