Question about Maytag Atlantis MDG7400AW Gas Dryer
Dryer stopped working after 2-3 minutes
My dryer is 3 years old, I have put in a load of Towels. I mean the dryer was stuffed and suddenly it stopped working. When I opened the dryer, there was a burning smell.
Not sure what is the problem, I am constantly cleaning the lint from the link filter, but never cleaned it thoroughly from inside the duct.
  • 1 more comment
  • aseem_nar739 Apr 13, 2009
    I'm certainly planning to get a duct cleaner, but how to start my dryer.
    Are you saying that cleaning the duct will fix this problem?, or do I need to take a look at something else too.
    I already tried unplugging and replugging the dryer, but that didn't work. Dryer's light is on, but it is not working.
    Could this just be a fuse issue?, if yes where can I locate the fuse.
    Or do you think this is something else?.
    Thanks for your help!
  • aseem_nar739 Apr 14, 2009
    Can anyone else help me with my problem?
    Problem Solver:
  • 5 Answers
Go out and buy you a duct cleaner. It looks like a dome shaped broom. Clean your duct from the outside and if you can from the inside. Also if you use fabric softener sheets, clean your lint filter with soap and water periodically (every 3 months would be optimal) to remove the clear residue the dryer sheets can leave behind.
Good Luck!
Posted on Apr 13, 2009
  • jacobawood Apr 13, 2009
    Newer dryers can come with failsafe relays to shut down the dryer before it burns down your home. If you want to try unplugging and replugging your dryer, or possibly checking the circuit breaker it is on, you may find your problem with the power issue. Otherwise a spontanious powerdown could be a much worse problem than a little bit of lint.
I had a bunch of verywet towels because my sink was leaking, and I put them in the dryer and it worked for a few minutes them stopped. What might be wrong?
Good Morning Friend,
I understand that you had a bunch of wet towels, and put them in your Frigidaire dryer, model# FGQ332ES. I see that your dryer worked for a few minutes and then stopped. There could be a possibility that the wet towels were too heavy from all the water in them. I suggest that you spin the towels out in your washer first and then move them over to your dryer. If you are still noticing the dryer working for a couple of minutes and then stopping, I suggest giving your appliance a hard reset. You will do this by either unplugging your appliance or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored start it on any cycle. If your dryer is still shutting off after a few minutes, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to shut off after a few minutes. Hope this is helpful.
-Best regards-
WP
May 14, 2014 | Frigidaire FGQ332ES Gas Dryer
Lg dryer stop heating after i stuffed it witha blanket front load gas dryer Tromm 3 years old. I completely cleaned it, but still won't heat I can fix it with your help
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | LG DLE2514 Electric Dryer
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
Dryer stopped running after 10 minutes
Take off the back, there will be a oblong fuse, it has two little wires, replace it.
Jul 14, 2009 | Dryers
Whirlpool Gas Dryer takes 2 or 3 cycles to dry clothes
did you check ALL lines..in and out for clogs!?
Mar 15, 2009 | Dryers
HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
158 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
