Question about U.S. Robotics USRobotics USR5461 Wireless MAXg Router wireless router (S4199613)
USRobotics USR5461 Router loses wired internet connection often
My USRobotics USR5461 Wireless MAXg Router, often loses its wired connection to the internet. I have 2 desktop computers and a printer plugged into the router, all via RJ-45 cables and sometimes, I lose my internet connection. (Although this router has a built-in USB print server connection, I have never used it because I thought the RJ-45 cable might be faster.) To fix it, I unplug the power supply for a few seconds and plug it back in and it is fixed. However, sometimes, I have to fix it this way several times a week...other times, however, it is not a problem for several weeks. I have been using this router for at least a couple years and now, it is starting to have this lost internet problem often enough to be a bother. Its really getting annoying...Originally, I thought it was my RoadRunner cable/digital phone modem and after resetting that, the problem still existed. Now, I don't even bother checking the cable modem because the problem has always been the router. Is it possible that this router is on its way out? What is the service life of a router like this? Should I buy another? Any ideas? Thank you!
  • fappel Apr 13, 2009
    Thank you, deadman678, I'll give the firmware upgrade a try, first...before buying a new router. When I connect to my router page and check for an update for the firmware, I get the message that there is no update. However, after checking at the USROBOTICS web site, I see that there is an update, just as you mentioned. Thanks.
    Problem Solver:
  • 8 Answers
The router u have is a bit old, a router can keep going good if u keep updating it.
to update your router first log in to router
1)open a internet explorer and in address bar type in 192.168.2.1 it will open the page for router.
2) select the tab device
3) select check for update
4)the latest firmware for this device is 3.93.35.0.9
5) if u have lower than this u need to update which would solve your problem
6)if update is available click continue it would download the file on to your computer
7) now click browse and select the file then click upgrade
hope this will help u
8) it shuld take a minute to upgrade
if u want to go for a new router this would be my suggestion
wrt54g2 by linksys
F5D7230 belkin
both these are good devices i can tel u this since i m using them
Posted on Apr 13, 2009
I have been looking to build a good professional opinion on the topic. Your post got me a step further in the right direction. Many thanks :-)
<a rel='nofollow' href="http://www.firstbroadbandinternet.com/broadband-internet.html
">Internet service Alberta</a>
Posted on May 17, 2012
I have a U.S. Robotics USRobotics USR5461 Wireless router
heres the online installation manual http://www.usr.com/support/5461/5461-ug/index.html
see configuration tab - You will not be prompted to login the first time you connect to the Web User Interface during the initial setup. During the Setup Wizard procedure, you will be prompted to create a user name and password to log on to the router. If you create a user name and password, you will need to use these whenever you want to log on to the Wireless MAXg Router. The user name and password are case-sensitive.
------------- so if you cannot remember the username and password - you will need to reset to fsactory condition and reset all the settings in the router for it to work with your ISP again
the reset button is on the back - RESET Button: To restore the factory default settings, use a paperclip to press in and hold the RESET button for five to ten seconds. If the RESET button is pressed for less than five seconds, the Wireless MAXg Router will reboot.
Apr 24, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
My US Robotics USR5461 Wireless MaxG router needs to be rebooted quite often (sometimes once or twice a day) to get internet access back. The status page says it's connected to the internet but I can't...
Considering the frequency you have to reboot the router to get it to work may indicate a glitch with the WAN gateway.
I recommend fully resetting the router and setting the wireless network up again.
You should be able to reset the router using a pin and sticking it in the pin hole on the back of the router near the power source.
Thanks,
Pat
Jan 03, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
I have a US Robotics usr5461 wireless router. It
You might want to check your firmware version to make sure you have the lastest.
BETA Firmware Version 3.93.35.0.9This firmware fixes the following issues:
  • Printing issues with CUPS version 1.2.
USR5461a-v4.3.93.35.09.usr 1.8 MB 06-05-08
Firmware Version 3.93.35.0.8This firmware fixes the following issues:
  • DST (Daylight Saving time) Firewall issue with how IAC (Internet Access Control) works.
  • PPPoE server disconnect/reconnect
  • PPPoE inactivity timer
  • PPTP client disconnect/reconnect
  • backup/restore settings
Note: If upgrading from Version 3.91.37.0.3, follow these instructions before proceeding.
  1. With a thin tool, such as a paper clip, briefly press the RESET button on the back of the router.
  2. Wait about 30 seconds.
  3. Continue with instructions below.
Important: To ensure a successful upgrade, please perform the firmware upgrade from a client that is physically wired to the router. A wireless client may become disassociated from the router during the upgrade process resulting in an incomplete upgrade.
  1. Download this file to a temporary location on your computer's hard disk drive.
  2. To upgrade your USRobotics Wireless MAXg Router with all operating systems, open an Internet browser and enter the router's IP address. The default IP address of the router is 192.168.2.1
  3. Enter your User name and Password. Click OK.
  4. Click Device in the main menu.
  5. Under the "Upgrade Router" section, enter the location of the USR5461-v3.93.35.0.8.usr file in the text box, or click the Browse button to search for the file. Then click the Upgrade button to begin the upgrade process.
  6. When the upgrade process is complete, the router will reboot. To re-establish a connection with your router, wait approximately 15 seconds and click Continue.
USR5461-v3.93.35.0.8.usr 1.8 MB 10-25-06
Dec 31, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
I can not on to the internet, i cant install
Are you trying to install the router?
It is very easy.
Click Here for step by step solutions
Oct 28, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
My router will not allow me to connect to the internet, when the computers are plugged into it, it worked fine last night.
Try to do a power cycle. unplug the power to the router and the modem for 30 seconds. After that power on the modem first and wait for all the lights to go solid, then power on the router. Check your connection again
Jun 21, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
I have a laptop which I have a wireless connection for. My desk top speed is fine, wireless speed is little to none. When on the internet, the initial connection is fine and fast but then I get an hour...
Try to change the wireless channel of your router to 11. This kind of problem is normally caused by wireless interference,. You can do it on the router's admin page
May 07, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
Wireless
What are you trying to connect to?
Jul 04, 2008 | U.S. Robotics USRobotics USR5461 Wireless...
Laptop wifi cannot find usr model 5461
I use the windows wireless zero program which all I read is the best for wireless and aliminates conflicks
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 30, 2007 | U.S. Robotics USRobotics USR5461 Wireless...
U.S. Robotics USRobotics USR5461 Wireless MAXg Router wireless router (S4199613) Logo
935 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
