Question about Maytag MDE3706 Electric Dryer
The dryer smells when running like a burnt smell. How can I take it apart to clean the inside?
Remove screws on front of dryer there should be four two at top and bottom under door .you will see your heating element you need to clean it very good then check yor hose on rear to make sure it;s clean and not clogged.. you will probley see a lot of lint.but take your time and good luck..vickie
Posted on Apr 13, 2009
Why does my dryer smell like rotten cabbage?
I would suspect your "green" concoction got into the lint that "lives" inside the machine. Unbeknown to you, dryers have a lot of lint inside that is never cleaned, it just builds up.
In the last 20 dryers I have repaired, about 10 had a shoe-box or two full of lint inside.
Perhaps the mixture you added made mildew or mold accidentally in the lint nest.
Also, if you are in a complex and you'all have shared exhaust, perhaps it is someone elses problem.
You could take your dryer completely off the circuit and close off the "shared" vent system.
Then , see if that makes any difference.
I suppose you could also try to run your dryer inside your condo for 5 minutes to see if the smell is coming from your dryer when it is not hooked up to anyone elses.
If the smell is from yours, you will need to completely dismantle your machine to get every trace of lint and smell out.
God bless your efforts.
Sep 11, 2015 | Samsung Dryers
The clothes are coming out of the dryer smelling burnt.
you probably have lint build up on the heating element. the lint will burn when the heater is on, and transfer the burning smell to your clothes inside. Probably time to take it apart and vacuum everything out .
Jul 20, 2011 | Dryers
Everything is working on the Dryer but it has a very strong. "Burnt" smell inside and it gets on the laundry. What is causing it to have that Burnt smell?
burnt smell like rubber or like lint burning whens the last time you delinted your dryer? A dryer should actually be delinted at least once a year maximum I personally delint mine every 4 months with a family of 4 lint doesn't just go on you lint screen and away it goes unscrew that bottom panel and with a flashlight have a look inside on the other hand if it is a burnt wire smell you probably want to look near the through the same spot but on the left side back where the heater is located usually one of the wires connecting to the heater ends up singeing or a thermistor blows out you will get this smell if you happen to have the model number i could send you a schematic of how it comes apart if you have any further questions message me back and please remember when our chat has concluded to rank how this opinion has helped it how im able to help others in similar situations in the future Thanks again Rick
Jan 21, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Burnt, scorched smell in the dryer
Remove the bottom front panel(2-3 screws along the very bottom. . Clean inside... Be really careful around the ignitor they are fragile but take care to make sure there is nothing inside the burner tube.
I hope this helps please let me know if you need further assistance.
Apr 13, 2010 | Amana ALE331RAW Gas Dryer
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
We moved the dryer in and turned it on. There was
Sounds like the motor shorted. Pull it apart and look for burnt wires and/or a burnt motor. The motor itself will smell burnt if it is.
Dec 13, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Clothes smell burnt
THERE SHOULD BE TWO SCREWS ON TOP OF THE PANEL UNDER THE DOOR ONCE YOU REMOVE THESE THE PANEL SOULD COME OFF
Sep 21, 2009 | Whirlpool GEW9200L Electric Dryer
Burning smell
Stop using the dryer! You are probably close to having a fire if you continue to use it. The whole vent system should be taken apart, cleaned, the heat limit sensors checked and the duct cleaned. Your dryer is overheating and is a danger.
Aug 11, 2009 | Dryers
Washer has burning smell and does not spin.
It sounds like your belt has burnt off. take the front off the washer or tip the washer back to check it. easy fix.
Nov 17, 2008 | Washing Machines
Dryer smelled of burning plastic, smoked stopped turning on
check the power cord itself, if you see on the back side of the cord a burnt or blackened spot then the cord is the issue
Apr 12, 2008 | Dryers
Maytag MDE3706 Electric Dryer Logo
145 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
