Question about Hoover Nextra HNT 2135 Top Load Washer
Hoover hdv fm tumble dryer
When you press the on button some thing makes a buzzing noise in side i replaced the on off button but it still makes that buzzing noise could it be the control panel?
  • 625 Answers
Only thing may make a buzzing sound is a relay not making up or a motor contactor not closing all the way.
Posted on Sep 12, 2007
SOURCE:
My dryer is not working and only making a buzzing noise when i press the start button
is the buzz more like a growl? if so, you probably have a bad motor. if it is truly a buzz, then try turing your timer to a different cycle. if the problem continues, replace the timer
Jan 22, 2011 | Whirlpool LER4634J Electric Dryer
Buzz noise behind dashboard 2001 GS300 LEXUS
The buzz noise is probably coming from the airflow controls turned off but being stuck in a particular mode such as vents and feet mode or winshield and feet mode, creating a buzzing noise while it is turned off. To stop the buzzing noise turn off the aircondition / heat by pressing the off button, next press the mode button for the fan controls to make the picture point to face only not feet or winshield, this should stop the noise.
Oct 01, 2010 | 2001 Lexus Gs 300
Drum will not turn and there is no heat.
This dryer has a circuit board that controls virtually everything. If it makes a buzzing noise when you press the power button to turn on the control panel, it's probably not going to be an easy fix. When you hire a professional, you avoid buying expensive parts that you might not need, such as a control board. If it makes a loud buzzing noise when you press the start button, it's possible that it could be a motor or belt problem. But again, I'd recommend a service call for this one.
May 25, 2010 | Whirlpool GEW9250 Electric Dryer
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
FREEZER BUZZING NOISE - Whirlpool refrigerator Model# ED5FHEXNS01
My whirlpool side by side makes a vibrating noise when in cool cycle I press at the back of the panel in the freezer side and it stops
Apr 10, 2009 | Whirlpool GS6SHEXNL Side by Side...
Amana gas dryer wont start. just makes a faint buzzing noise
The drive motor starting capacitor is likely dead. This can be tested if you are competent enough to take the thing apart and use an electronic multimeter. Otherwise it is a cheap part to replace, depending on how much the repair guy charges for labor and to be called out.
Mar 18, 2009 | Amana NDG5800 Gas Dryer
Refridgerator
IF THE BUZZING SOUND IS ONLY THERE WHEN THE MOTOR IS RUNNING THAT COULD MEAN ONLY ONE THING.YOUR PISTON IN SIDE THE COMPRESSOR IS NOISEY THE ONLY WAY TO SOLVE THAT IS TO REPLACE THE COMPRESSOR.BEST YOU HAVE A TECH TO ADVICE YOU FUTHER.GOODLUCK.MOHAMED
Jul 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Hoover Nextra HNT 2135 Top Load Washer Logo
291 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
jimorris77
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
