Basic "no disk" error
SANYO DVD 5100 Hello Display showed "no disk" error. -tryed to clean the lens with a cotton swab -tryed to adjust a little potentiometer or variable capacitor next to the optical pickup: that make things going worse as the red spot disapeared completely Thank you
  • electropics Apr 14, 2009
    yes Sir, it does, I tryed another audio CD that is OK on another CD player, same problem : "no disk" & eject it
    Thank you
    Ok, this is what I was thinking about.
    Thank you.
  • 916 Answers
Ok first let me ask you does this happen with all discs?
Posted on Apr 13, 2009
  • machadojr_fe Apr 14, 2009
    Ok you said you have tried to clean and you have tried adjusting the potentiometer. These would be the first things to try and test the player with. After doing this if it still does not work the lens itself needs to be replaced.
Kec dvd 3
hi there.
it might just be a bit of dust on the inside laser.
Step 3 Laser Lens Cleaning
  1. Locate the lens on the disc drive.
  2. Make sure that there is no dust on or near the player and area you are working on. ...
  3. Dip one end of a cotton swab in rubbing alcohol.
  4. Lightly dab the swab on the lens. ...
  5. Let the lens dry before replacing the top plate of the DVD player.
  6. or just buy your self a disc cleaning laser disc.
  7. How do you clean the laser on a DVD player?
    To maintain your DVD player, occasionally unscrew the player's case, so you can get at the lens to clean it. You need a screwdriver, canned air or a soft brush, a foam swab or camera-lens cleaner, and lens cleaning fluid from a camera store
    read up some more at this link.
How to Maintain Your DVD Player dummies
Dec 08, 2017 | Cars & Trucks
Incert dvd read out sats NO
Hello
This usually happens when the DVD or laser lens pick-up has become dirty.All you need to do is
1. Check the disk for scratches.
2. Make sure the disk you are using fit the correct format specified by your DVD player.
3. Clean the laser lens with a DVD laser cleaning disk.
4. Insert a correctly formatted undamaged disk into your player,listen to see if it begins to read the disk,if it continues to make no sound.
5. Open the DVD player carefully and clean the lens with isopropyl alcohol and cotton swab.
6. If none of these solutions works out then a professional repair technician will be able to tell you if fixing your DVD player is worth the money.
BEST OF LUCK
Jul 13, 2010 | Toshiba SD-K760 DVD Player
Bad disk error no matter what disk is played.
try a cotton swab and len cleaner. rub a small amount on the laser eye and then dry it off. do thus several times. be careful and don't put to much on the cotton swab. it don't take alot
May 01, 2009 | Televison & Video
VCR will play, DVD returns disk with"check disk"-will not accept
Dirty or defective laser lens. try manual cleaning of the lens if you know how to open the unit top cover. manually clean the lens using cotton swab gently rubbing it in circular motion. blowing of air to remove dust will not really help clean the lens.
Jan 03, 2009 | Samsung DVD-V4600 DVD Player/VCR
Cannot read discs
this dvd sucks. I just bought it around 5 months back and it as working fine till now. Now no matter what kind of disks i try to play on it, it has a common answer. " the disk vant be played".
i guess the problem is with laser reading lens. u may try to the following guide but i am going to dump this machine to samsung service stations as it is still covered by warranty.
it sucks wont buy this brand again.
Step1 Make sure the laser pickup lens is actually the problem. There are a wide variety of reasons that a DVD player might not read a disc efficiently. The disc could be scratched or dirty, for example. Test the DVD player with a disc that you know works before trying to clean the lens. Step2 Purchase or borrow a lens cleaner disc and try it first. You can find these things really cheap at any large department store. They usually get the job done well. However, you may need to clean the lens manually if the store-bought cleaner fails. Step3 Remove the outer casing of the DVD player. Remove the screws that mount the top casing onto the bottom of the DVD player and slide the top casing off. This will expose the DVD deck, which houses the laser pickup lens. Step4 Find the lens. The lens will be glass and under the DVD clamp. The lens will probably have a blue tint to it. If you are having trouble finding the lens, you could shine a light on the components and watch for the reflection. Step5 Use a cotton swab and some isopropyl alcohol to gently wipe the lens. Just a quick scrub will do. Dry the laser pickup lens with the other end of the swab. Step6 Give the lens a few seconds to dry and replace the covering of the DVD player. Test the efficiency of the player. If necessary, repeat the process. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 29, 2008 | Televison & Video
Disk error
That means that the lens are dirty, and the unit cannot read any disk.
Try first cleaning the lens using a lens cleaner kit (the ones with liquid cleaninc solution), like the one here :
Allsop Ultra Pro Lens Cleaner for CD, DVD and Game Consoles
Ifthat does not work, then you will need to access the lens inside theunit by opening the cover and accessing the lens pickup, and gently clean lens by using isopropylalcohol and ultra soft soft cotton sticks.
Here is how the lens look like:
Nov 07, 2008 | Sanyo DVW-6100 DVD Player/VCR
DVD Error sony handycam DCR-DVD108
Reformat DVD and clean Lens with soft n nice quality cotton swab.
Jul 22, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Disc Skips
The non-technical answer would be that the lens needs to be cleaned. This is the first step for this type of problem. There are many things that can get the disk drive lens dirty like smoke, incense, dust, moisture. Open the unit and open the DVD cover. You will see the lens that reads a DVD. Get a cotton swab (the ones for cleaning out ears) and some isopropyl alcohol (rubbing alcohol) and moisten the cotton swab with the alcohol (moisten not soak) and gently (I mean, do not push hard or scrub hard) rub it on the lens. Now with a dry cotton swab, do the same. Let it dry for a minute (longer if the swab had more alcohol and it might have dripped down) and close the unit. Now try to play DVDs and let us know if it worked. Thanks.
Jun 19, 2008 | Cyberhome CH-DVD 300 DVD Player
Not playing dvds? samsung dvd_r 130
Jun 18, 2008 | Televison & Video
Dawoo DVD Player showing No Disk error
you have dirty lens, try to cleaning with 100% cotton buds. or you have damage laser eye, or broken flex ribbon wire, but first you have to do is to cleaning the lens with cotton buds.. if not reading after you clean the lens! change the laser eye and flex ribbon wire.
Aug 31, 2007 | Daewoo DVDS151 DVD Player
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
