Question about Epson TM-U220 Matrix Printer
Receipt printer TM-U220 not working
Tried everything, changed the ports, changed the cable. Don't know what to do next ...
    Novelist:
    Champion:
  • 254 Answers
After looking at the description of this printer, the following suggestions: 1. This uses an external power supply- is the printer power indicator lit? If not, then perhaps the external power supply is dead, or the connection where it plugs into the printer is broken. Sometimes the connector can itself be broken, or where it solders onto the circuit board, causing a dead condition. A break in the wire also. 2. If printer is getting power- check the paper path for something foreign lodged- a torn piece of paper etc. 3. There should be a paper present sensor somewhere also, which checks if the unit is out of paper. There is possibly a lever which contacts the paper- check if this lever is broken or stuck. 4. You could try printer on a different computer, to narrow the problem to either the printer or to the computer/cash register. 5. Have you checked the software? Is printer properly setup (drivers), and set as the default printer? Does a printjob appear in the queue? Lastly, there could be a problem with the electronics, which would require technical repair, or replacement of the unit.
Posted on Sep 12, 2007
Epson UB-U03II not working
I had huge issues with my TM-U220. It does not play well with a Centronix-to-USB cable or with Windows 64-bit. I played for AGES to try and get it all to work.
I installed the USB device driver[1] I was able to print the Test Page proving that the connection between Windows and the printer sort of worked, but when I tried printing anything from Unicenta POS, it always failed.
I finally bought a new Centronix-to-USB and a new parallel port card, used Windows 32-bit, and problem solved.
They key is to uninstall everything, including searching through the Registry to delete everything.
[1] https://pos.epson.com/developers/techresdetails.htm?ProductPK=545
May 30, 2014 | Epson TM-U220 Matrix Printer
Epson tm-u220 not printing receipt info, but printing random symbols
Hello
Try to re install the drivers. Uninstall the old drivers first
Oct 03, 2012 | Epson TM-U220 Matrix Printer
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
Epson TM-U220 not working with window 7
download this driver APD-406aE i did it and it is working perfect with my windows 7 on a TM-U 220B
Jul 07, 2010 | Epson TM-U220 Matrix Printer
User Intervention Required Message Epson TMU375 receipt printer
Got to start/settings/printers and faxes .saelect epson 220 printer go to properties and select ports.Change ESDLPT1 port to lpt1 port and uncheck enable bi directional option .Apply and o.k.printer will work fine
Dec 30, 2008 | Epson TM-U220 Matrix Printer
TM-U220 sometimes fails to print
Maybe the USB cable or the port on the PC or PRINTER is defective. First try a different cable, then try another open USB port to see if it works there. Also, the POWER CORD for the printer may be loose or defective, or maybe one of the printer DOOR INTERLOCKS may be intermittent, or not closed properly.
Nov 25, 2008 | Epson TM-U220 Matrix Printer
Problem setting up TM-U220
print the self-test, push the feed botton while powering on...
you can see there the serial interface...
baud rate, data bits, parity, stop bit etc...
then go to the printer and faxes,
right click the epson driver and click properties...
go to the ports window...
click on the epson tm u220 reciept.
click configure port...
adjust the baud rate as same as in the self test...
it works...
May 22, 2008 | Epson TM-U220 Matrix Printer
How to eject cash drawer pos
Open the Cash Drawer
Hex code
<1B><70><30><40><50>
Apr 03, 2008 | Epson TM-U220 Matrix Printer
My Printer EPSON TM-U220 does not print....HELP!!!!!
Change port to Printer port Lpt1 not the esdprt. then uncheck enable bidirectional support/ Restart computer and then try to do a windows test page
Jan 14, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Nov 27, 2007 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer Logo
254 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
