Question about Philips Magnavox 51MP392H Rear Projection Television
How to change crtfluid
I have a 46" magnavox that i was told the fluid needs to be refilled i bought the fluid and need to know how to do it??
  • neonchris06 Apr 13, 2009
    its worth the risk i cant afford 300 bucks for a qualified tech i just want some specs so i dont break it thanks though i do understand i should have a someone in that field look at it
    Problem Solver:
  • 8 Answers
Only a qualified service tech should replace coolant fluid. I've serviced TV's for a good while, and I would not attempt this repair without a co-worker showing me precisely what to do. You have to remove the Picture Tube(s) to do this, and if they leak after assembly, your TV circuit boards could be totalled out. The coolant is similar to anti-freeze and is corrosive.
Posted on Apr 13, 2009
How much transmission fluid does it take when changing the transmisssion screen and filter?
When the pan is dropped and fluid is drained, to refill, it usually needs 5 - 6 quarts. When refilling, check the transmission fluid dipstick as you are adding the last two quarts. And also run the transmission thru the gears.
Oct 20, 2012 | 2003 GMC Envoy
My 60inc phillips magnovox has poor color, what do i have to do?
we just bought a 55 inch phillips magnavox and told it was working fine when we got it home and turned it on it was a red screen and was really foggy. we looked up some tv repair places and ONLY 1 told us it was the picture tube and to look down them with a flashlight for bacteria! sure enough the green and blue had it. so we found one place that would sell us the coolant fluid that you have to change the others could get it in or wanted us to bring the tv to them. we did it our selves the stuff was $17.00 a bottle or if we took it in it would be about $375.00. we have a great picture now and it wasn't as hard as all the other repair places said.
Dec 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Have 115,000 miles on car ..when for an oil change and was told I needed to change transmission fluid and power steering fluid....Cannot locate my manual...when do these fluids need to be changed and is...
Regarding the transmission, if you have an automatic, use genuine Honda ATF fluid only and only do a drain and refill. A power flush will damage the Honda Transmission. It should be drained and refilled every 60k initially, then every 30k afterwards.
Jul 30, 2008 | 2005 Honda Accord
Changing fluid in CRT's
You can go to the following site, under the repair kit catagory they have a CD that documents the step by step proceedure for coolant change in phillips / magnavox tvs with pictures. They also have the entire kit with 48 ounces of high purity coolant and the cd
Heres the link.
http://servicemanuals.vstore.ca/
Jul 11, 2008 | Televison & Video
Yellow tinge in picture how do I change the coolant fluid?
you need to remove the CRT from the set. the problem CRT is the blue CRT. after removing the gun leave the yolk inside. there is a drain plug on the side of the CRT remove it and drain into a hazard waist container and dispose of it as hazard waist according to your local regulations (ethylene glycol) very dangerous if ingested. use rubber gloves and becarefull of the CRT it can implode. after its drained you must take the lens assembly off the clean the CRT face. use 95% rubbing alcohol to clean the face and lenes of the gun. replace the lens assembly and refill the chamber with fresh fluid. replace the CRT assembly in the set. alien according to the service manual. check for leaks after warm up. if leaks accure remove the CRT and repeat the process but save and re-use the fluid reseat and clean all gaskets and make sure the screws are tight.
Feb 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Oct 19, 2007 | Philips 46PP9302 46" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
89 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
