Question about Microsoft Windows XP Home Edition
16 bit MS DOS Subsystem error
Everytime i start my computer, this message pops out: 16 bit MS-DOS Subsystem
C:\WINDOWS\system32\cmd.exe
The NTVDM CPU has encountered an illegal instruction.
CS:0541 IP:0206 OP:63 68 61 72 73 Choose 'Close' to terminate the application.
i dont know how to fix it and it's really annoying and i fear it can eventually harm my computer..please help me
  • 741 Answers
I found a website of people who have the same problem;as you will see Microsoft does not have a fix for it. The recommended fix is to backup your data and reload Windows.
http://www.techspot.com/vb/all/windows/t-5039-NTVDM-CPU-illegal-instruction-.html
Pls rate this solution.
Posted on Apr 13, 2009
16 bit MS-DOS Subsystem C:\ WINDOWS\system 32\wuauclt.exe The NTVDM CPU has encountered an illegal instruction. CS:Oe57 IP:fff8 OP:fe ff 57 Oe fe Choose 'close' to terminate the application repeated...
wuauclt.exe stays resident in the background and checks Microsoft website for the operating system updates.
Originally, wuauclt.exe is a legitimate system process that is located at C:\Windows\System32, but there are cases when wuauclt.exe is actually a disguised virus, Trojan or a worm.
If you find wuauclt.exe stored anywhere different from its original location, you should get really suspicious and scan your system for possible threats.
Search for the file and see if you have this in more than one location.
Your system might be infected.
Mar 06, 2011 | Toshiba Core 2 Duo Laptop Computer PC...
I executed simple C++ program but when i executed graphics program like to print circle,then the window closed and displayed a following message. 16 bit MS-DOS Subsystem C:TC BINTC.EXE The NTVDM CPU has...
If your operating system is win 7 or vista,
1,Locate c++ program file right click and goto properties
2,Untick or unselect RUN IN FULLSCREEN option.
Then your problem will be solved.
Jul 27, 2010 | ASUS M2N-MX Motherboard
NTVDM CPU fix
Hello there:
Something is amiss with your system.
That error message is associated with problems involving 16 bit
applications (Windows 3.x or MS-DOS) and both cmd.exe and regedit.exe
are full 32 bit Windows apps.
This sounds like it may be caused by an incomplete removal of one of
the trojans that blocks the use of Regedit.
You did not mention the specific products that you have tried. If you
have not previously used any of these you should try them:
Kaspersky Online Scanner http://www.kaspersky.com/virusscanner
Panda ActiveScan http://www.pandasoftware.com/activescan
Webroot http://www.webroot.com/
I highly recommend avg antivirus free version this is totally free and worked wonders for me
I hope that this is very helpful for you
best regards michael
Nov 16, 2009 | Dell Dimension 3100 PC Desktop
16-bit ms-dos sub system error while runing graphics programs on ntvdm cpu on amd athlyon processorTurbo c++The NTVDM CPU has encounterd an illegal instructionCS:d3e8 IPc180 OP:ff ff ff ff ff ff
HI,
Navigate to updatemgr.exe in C:\Programs\Common Files. Next, rename the file. Right-click it, select RENAME and rename it to, say, updatemgr.old, save the changes and click on OK. RESTART your computer and the problem should now be solved.
Please post back if you need anymore assistance.
Nov 09, 2009 | HP Computers & Internet
Turbo c not working....16 bit ms-dos subsystem error
There have been several changes in the way programs work. Windows xp does not
allow direct access to hardware resources to protect system integrity.
However you can try a few things
http://support.microsoft.com/kb/314106
http://support.microsoft.com/?id=165214
http://support.microsoft.com/?id=324767
Generaly speaking this error shows up when a program tries to use a
command.com file from an incompatible version of windows.
Alternatively login in safemode and use. it ll work fine. rate this!!
Aug 15, 2009 | Borland Turbo C++ 4.5 Full Version for PC
16 bit MS-Dos Subsystem Turbo C++ IDE The NTVDM CPU has encountered an illegal instruction cs:0000lp:flboop:of00640352 choose close to terminate the application
I too have a problem on my PC,when running the Turbo C programThe error message is:
16 bit MS Dos Sub system
turbo c++ IDE the NTVDM has encountered an illegal instruction.
At last i found the solution, and it is simple.
After installing your turboC follow the steps..
1) go to TC directory and open BIN.
2)In "BIN" folder you can find "tc.exe". Right click on "tc.exe" and click properties (and make sure that do not click on shortcut of TC.exe).
3)In properties there should be a tab called "screen", In that you will find "usage" option. There.. select "window" option instead of "full screen".
4) Then click "OK".
5) Now click "TC.exe".
6) It will open in window mode, if you want you can change full screen mode by pressing "ALT + Enter".
Thanks & Regards
Shravan reddy Konnela.
Jun 02, 2009 | Microsoft Windows XP Professional with...
Windows problem
Try this.
Right Click on your DOS program EXE file. Then go to properties and go to Compatibilty TAB. Click in Check Box for Compatibitlity mode and select WINDOWS 95.
Feb 10, 2009 | Computers & Internet
When i am trying to use c++ on my system it is giving me message the NTVDM cpu has encountered an illegal operation
Here is an explanation of what NTVDM is: The NT Virtual DOS Machine (a.k.a WOW, or Windows on Windows), is a Win16 subsystem that runs under Windows NT, which allows 16-bit applications to run as if they were being executed on a DOS machine, with that machine's multitasking and segmented memory model. Because the system is multitasked 16-bit DOS and Windows applications cannot crash NT. However, 16-bit apps within a Win16 subsystem run the exact same way as they do on a DOS/Win 3.x machine; therefore, 16-bit apps within the subsystem can crash one another, or the subsystem. To prevent this, you can launch multiple WOW subsystems as long as your program does not communicate using shared memory. Windows NT will not allow NTVDM to execute instructions that try to directly manipulate hardware or memory locations. As a result, some DOS and Windows 3.x applications (such as games) may not run under Windows NT.
Feb 02, 2009 | Computers & Internet
it is a virus on your computer by the sound of it, to do a fresh install, when you initally turn the computer on, put the disc in and hit either F8 or F2, maybe F10, dependant on what it says on the inital start up screen, change the boot option to disk then you can reinstall
Jan 24, 2009 | Compaq Presario S4020WM PC Desktop
The ntvdm cpu has encountered an illegal instruction
I took this from another web site:
Michael Chiew said:
What did you do before this happened? What were your last deeds on the machine before the pop-up appeared?
I think what you're referring to is NTVDM CPU, not NTDVM CPU. Am I correct?
What do you know about 16-bit and 32-bit applications? Well, 16-bit applications are those that must work within the DOS (Disk Operating System) environment, a real-mode arena. NTVDM stands for NT Virtual Dos Machine.
In Windows XP, as in Windows 2000, or Windows 98, there are 16-bit and 32-bit environments (real mode and protected mode respectively).
Windows XP can only operate in 32-bit mode. All 16-bit applications must work within its own theatre of operation, typically, the first MB of physical memory (ram). Conversely, 32-bit applications must function above the first MB memory line. If either of these applications happens to slip into "alien" territory, you get an error message like "something" has encounter an illegal instruction. In other words, the wayward application is trying to slip by the immigration checkpoint.
In your case, updatemgr.exe (I suspect updatemgr.exe is a 32-bit application) has in all likelihood wondered into the 16-bit arena. Hence, NTVDM CPU issues that warning.
Why do you continue to get the message. It's because updatemgr.exe incessantly misbehaves itself on start-up, always trying to load itself into a particular memory address where it is not welcome. Why the persistence? Updatemgr.exe has gone bonkers. It is either corrupted or damaged.
On the other hand, one cannot discount the possibility that NTVDM (NTVDM.EXE) is corrupted or damaged. So your problem lies with either updatemgr.exe or NTVDM.EXE, or both.
There are 2 things you could do.
First, establish who owns updatemgr.exe, Microsoft or some third-party owner. Second, rename updatemgr.exe and see whether the message goes away.
To establish ownership (and the function of updatemgr.exe), do a search for the file.
Click START, select FIND. In the FIND dialog box, type: updatemgr.exe. See the directory in which the file has lodged. In Windows Explorer, get to the file, right-click on it, select PROPERTIES. Who owns it? Is there an indication of its function.
Next, rename the file. Right-click it, select RENAME and rename it to, say, updatemgr.old. RESTART your computer. Do you still get the error message. Not likely.
To clean things up a bit, perhaps it is a good idea for you to replace the current NTVDM.EXE with a new copy. Find out where NTVDM.EXE is. Then, click START, select RUN. Type in the RUN dialog box SFC to run the System File Checker. Insert your OS CD, follow the prompts, extract a copy of NTVDM.EXE and send it to its place of residence. Of course, you should also replace a copy of updatemgr.exe.
That should eliminate your problem for good.
Dec 25, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows XP Home Edition Logo
1,051 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
